Page 1383 of 2773 FirstFirst ... 3838831283133313731381138213831384138513931433148318832383 ... LastLast
Results 20,731 to 20,745 of 41593
  1. #20731
    9th June 2012 - 18:32
    Bucket Sidecar
    palmerston north
    Fat cunt...
    Kentucky Fat Cunt?
  2. #20732
    You might as well throw in minimum weight into the rumour mill as well...
    TZ's comments above are concerning, last thing we want is constant rule changes for a class that has had minimum interference over the years. Personally I'm not really a fan of the 110cc rule, however if it enables more people to have more fun - then success..
    Other rumours heard are splitting the classes (bikes with GP running gear) and even opening up a post/classic bucket class... TZ - I look forward to having a catchup and a brew at Tokoroa.
    I heard its all electric by 2017.
  3. #20733
    16th November 2005 - 07:48
    I just lost count
    The District of Waipa
    First time in years that I have felt qualified to comment on the content of this thread.
    ... yes that would be fair, kitted up Rider plus Bike = 220kgs min, do away with that light bike skinny kid advantage, level playing field and all that.
    Now you re talking
    Quote Originally Posted by TALLIS View Post
    Now we are talking Rob! I think 190kg is fair (don't ask where I got that figure, and there's no hidden agenda)
    Fucking light weight racers
    no no no 200kg (-; that way we can still have kfc
    I do like KFC
    I have already started buying the extension cords
    Pumba is a wise man.
  4. #20734
    21st March 2014 - 22:00
    Hanau, Germany
    air correction jet
    Red line best power with the original main and 1.25 air correction jet. Blue line, 1.45 air correction plus bigger main jet.
    Great to have such a clear result of what can be achieved by adjusting the air correction jet to bend the fueling curve.
    TeeZee: I remember you did some tests on the dyno some (100 ) pages back. Do you still know which page you showed the results? And do you had a chance to use a A/F meter at that time?
    Juergen
  5. #20735
    13th September 2014 - 05:14
    '76 RD-400C
    The Emerald City
    Quote Originally Posted by TZ350
    The history of Racing is littered with good ideas that have effectively been banned because others have been to lazy or technically challenged to keep up. In Buckets, part of winning is building something special, and in this class I think attempts to limit that are wrong.
    Bravo!
    Will you make a place in the class for this guy?:
    https://www.youtube.com/watch?v=GLLs_KnT0Lk
  6. #20736
    Juergen
Name:	Thread Tools - View Pictures.jpg
    No sorry, but under "Thread Tools" which is near the top right hand side of the page, you can "View Thread Images" and sort them into 70 per page. When you find an interesting image click on the N/A sign to see the post, there are more than 7,000 images.
    When I was playing with EFI I did use a A/F meter but with a 2T there are traps as the A/F reading is seemingly rich when the trapping efficiency is not good, like when you are moving away from peak torque or well out of the power band.
    The A/F meter accuracy seemed at its best when the rpm was at peak torque, every where else it indicated varying degrees of rich but was not. Frits put me on to this, the indicated richness was just air/fuel being blown through the exhaust port and lost down the pipe the remaining air/fuel that got trapped in the cylinder burnt correctly, all the air/fuel was of the correct strength for good combustion just some was not trapped and consequently lost and looked to the meter like the engine was running rich when in fact it was not.
  7. #20737
    So, HCCI, how good is that. I've just been reading up on the ignition process (google it) and it turns out we have been heading down the wrong track with spark plugs all this time HCCI process is best at everything ...... accept being able to control it under all engine conditions
    There seems to have been a lot of research on this process and only Ryger appear to have cracked it, and they still run a spark plug. Imagine having a non direct injection engine running with no spark plug, model engines do it with compression adjustment to get the timing crack on. Be it at only constant RPM. Thoughts anyone?
  8. #20738
    16th September 2015 - 06:10
    Harley SShovelhead
    USA
    From what I have read HCCI has been the next big thing for 30+ years. Lot of controls needed making the usual complexity of a modern ECU 4 stroke OEM auto engine even more complex than it already is, and yet it still only works at part load. HCCI might work in the Ryger at just the right conditions, but working under all conditions without extensive ECU controls and such, only in dreams I think.
  9. #20739
    It is highly unlikely that the Ryger is running full load HCCI. Remember, Honda could not do it on a two-stroke, and the Car companies can not either. HCCI is a part load thing, and usually utilized to improve fuel consumption in the lower part load area. By the way, although many car manufacturers have road tested HCCI in prototypes on the test bench and on the road, there is not a single car on the market being sold which uses HCCI, afaik.
    If the Ryger should be working without a spark plug at some high rpm / high load areas, then it is much more likely preignition than HCCI. If it needs a smaller radiator despite more than usual power, then it can still have a more efficient burn compared to conventional engines, but that efficient burn won't be what is usually called HCCI or CAI.
  10. #20740
    So, HCCI, how good is that. I've just been reading up on the ignition process...
    Do you think it will be a good idea to dump the same HCCI information overload on the rest of the gang here Neil? Oh well, here y'all go. Bring your own aspirin.
    EDIT: after trying to upload three times I discovered that the maximum permitted file size for ZIP-files is 2MB. My HCCI.ZIP is 22,2 MB....
  11. #20741
    It is highly unlikely that the Ryger is running full load HCCI. Remember, Honda could not do it on a two-stroke.
    Compared to the Ryger engine, full load HCCI is not the only thing Honda could not do on a two-stroke .
  12. #20742
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Honda had success with EXP-2 in the 1995 Paris-Dakar rally, but then what?
    "In 1995 Honda re-entered the Paris-Dakar with a bang. The EXP-2 was a radically new and different motorbike, equipped with a revolutionary 400ccm two-stroke engine. After two weeks of racing the african dessert Jean Brucy finished 5th overall and first place in the under-500ccm class."
    http://www.honda-museum.com/honda-exp-2/
    I'm very much looking forward to the Ryger debut.
  13. #20743
    United Kingdom
    Smile
    Frits, could you store the large file using Dropbox, or a similar free cloud service, and share the link?
  14. #20744
    Then the management overruled the engineers. "Honda is a four-stroke company" ...
  15. #20745
    And I like that fact just as much as you do But I do give them credit for at least using HCCI in a racing two-stroke engine. Nobody else does. Or am I wrong?
There are currently 70 users browsing this thread. (0 members and 70 guests)
