How long are you working at those amps? You may find the handpieces are rated for those amps for a 60% duty cycle and using it inside an enclosed space is only going to shorten that.
May be that for that application you do need a water cooled handpiece. These look reasonable: http://www.trademe.co.nz/business-fa...-993191072.htm
A question for anyone who knows about pipes: Is it feasible to make the tailpipe de Laval nozzle out of aluminium alloy? Any idea of the temperature at the tailpipe of a 50?
Its a good idea, I think you could be right, pity I didn't think of it when I still had the old horizontal motor chassis, the new chassis has the motor steeply angled down at the front and would be totally un-suitable. Maybe someone else with a more conventional layout might be game to try the experiment and post the results here.
Hello, i have been a silent reader on this forum for a long time and now I cannot control my curiosity. I was wondering if someone had any news about the 'ryger' type engine. First time I heard of this engine and the specific claim of 30000rpm my mind flashed 'forced induction'. Seeing the pictures and no immediate devices to provide this I have to believe the system has to function like the old dkw engines from around 1930. (At least the principle must apply).
Link to dkw engine: http://www.kfz-tech.de/ZweitaktmotorA.htm
The left 'piston' is actually a pump, but what if it was a real piston. Would explain the aluminium riser plate on the ryger.
I am very interested in your thoughts about this. I just like mechanical mysteries.
If this was allready mentionend in the thread I am sorry for reposting.
Found interesting piston in some old cache page in google. Does anybody know if this is from an existing engine? My guess would be no. Looks like dkw principle to me.
Would explain how they are able to get mixture above the piston at such high rpm, also dampening the piston forces on the downstroke at high rpm.
Would also explain riser plate and shorter rod.
Still not sure how they reduce emmisions, oilfree 'mixture' or making sure no fresh mixture escapes through the exhaust port?
Ken here knows quite a lot about that piston
http://www.kiwibiker.co.nz/forums/sh...post1130919423
http://www.kiwibiker.co.nz/forums/sh...post1130920630
Some interesting ideas in those posts. Was going to post some drawings of my own but then i found the following 3d rendering. https://youtu.be/7UfMPi-jUz8
(So I do not need to hurt your eyes with my drawing skills)
The 3D rendering all makes sense from the info we have seen in the original patent, except for one small point.
How does a conventional 54.5mm stroke crank with a 90mm rod spin to 30,000 rpm.
I have said this before several times,its never been done before - so why is it now suddenly possible, some other trickery hasnt been revealed to us yet.
PS - re TIG torches.
You need 150A to do anything worthwhile, such as inside an Ex duct, or welding up a cylinder head insert.
This is only achievable at a continuous rating with a water cooled hand piece, air cooled just cant get rid of this amount of current especially in a confined space.
Hello Wobbly,
What do you think is the limiting factor. Mechanical or piston moving faster than flame front?
_tig torch advice:
Spot on with torch advice. Aluminium (cerainly large pieces) suck the heat away from point where you're welding. So you need to input a lot of heat to get your puddle. Also, I like to preheat cilinders on an electric heater plate to 300° fahrenheit. This reduces the time to get the weld started.
The issue is purely mechanical stress levels at 30,000 rpm with a 54.5mm stroke.
Even worse is the super short rod that will put severe side load on the piston support rod thru the plate.
This rpm gives a mean piston speed of 55 M/Sec, and today with current technology,approaching 30 is considered extreme.
From the reading I have done, flame front propogation speed isnt an issue, and anyway the Rygers peak Hp rpm is only 17,000
so its outright combustion efficiency at 30,000 isnt going to affect that result.
There are currently 200 users browsing this thread. (0 members and 200 guests)
