Page 1412 of 2776 FirstFirst ... 4129121312136214021410141114121413141414221462151219122412 ... LastLast
Results 21,166 to 21,180 of 41626
  1. #21166
    Quote Originally Posted by dtenney View Post
    Frits: Just to make sure i understand.......I should taper the edge of the rotary valve so the oil will not get scraped away but will flow under the valve?
    You got it David. You want the disc to go aqua-planing. or in this case: oil-planing.
    Both sides of the disk? Or just the crankcase side?
    Both sides. But why would you give preference to the crankcase side? Usually the outer disc cover suffers most from wear. In theory you don't even need the inner surface.
    If the disc eats into the crankcase side, it means the flow is still pushing the disc inward when the port closes. In other words: the disc closes too early.
    Or, and this is a big or, the inlet tract is too long, causing a big amount of inertia in the inlet flow; it will be reluctant to start flowing and just as reluctant to stop.
    Shortening the complete tract may solve the wear problem and boost the power as well.
  2. #21167
    Hmm. So why the dramatic increase of peak power? Temperature fooling the pipe?
    Not sure, it could be that the blowdown is improved with the dam and allowing a higher rpm ceiling. With the first "Exhaust Dam" tests we tried different main jets but over a wide-ish range there was not much difference. So we tried to keep everything consistent by not changing the ignition timing or main jets etc, we just ran the same setup. The piston is showing a bit of real heat in the crown. Not to sure whats up with that but I am very interested to see what happens when the "A" transfers get re angled across the piston crown.
  3. #21168
    Next move is to start opening up the "A" transfer ports and pointing them more towards the center of the cylinder for more power by taking advantage of the short circuiting blocking powers of the exhaust dam.
    Tread very carefully here; don't try it with your best cylinder.
  4. #21169
    We would love it to be a stunning success but know it is a bit way out there, so we are sort of emotionally prepared for final tragedy, and count on having picked up some useful gems along the way.
  5. #21170
    But I feel I must add here, that my whole perception of dyno testing was changed by Jan stating that alot of the pipe testing that was originally done
    was invalidated in that the jetting wasn't optimised for each change of dimensions.
    What he was saying is that if a pipe affected the egt due to its design, then the power change was due to the egt change - not the actual efficiency ( or not ) of the actual pipe.
    I have taken this on board and for some time EVERY run I do I aim to jet for exactly the same peak power egt.
    A small change in reed stiffness will absolutely change the egt number, and if you dont then rejet to achieve the target, then the temp change is causing the power difference - not the reed change.
    I shoot for 650*C on a KZ2 for example as this is what we see for best power.
    Now I am starting to use Lambda, to achieve a target A/F ratio.
    Both methods, are in effect approximating what should really be done to do this properly, that is measuring air and fuel flow to generate a max power BSFC number.
    But anyway, what I am saying is that just doing a dyno run, making a change and then not rejetting - is a waste of effort.
  6. #21171
    And here we were thinking we were doing it properly by changing only one thing,
    I will talk with chambers about getting some good EGT gear. ...
  7. #21172
    2nd August 2011 - 11:11
    Connecticut, USA
    Wobbly
    sent you a PM....pls confirm it went through.
  8. #21173
    TZ, I badly worded my post.
    I meant to say dramatic increase of revs at peak power.
    Its like you've chopped an inch out of the pipe. Either the jetting requirement is different, or the dam is well overheating locally and you might not see the benefit if you cool it with more petrol as if it were cast in. Maybe, just something to consider.
  9. #21174
    21st March 2014 - 22:00
    Hanau, Germany
    Lambda measuring
    Hey Wob, what type of lambda sensor do you use (I assume wide band sensor, right)? Do you just take the millivolt signal or do you have a controller taking care on the heating and the signal conversion? I had an ETAS system in the beginning, now using the WBO2 setup...
Name:	ETAS LA4 004.jpg
ID:	318329Click image for larger version.
Name:	Data Logger TZR250 (1).jpg
  10. #21175
    25th August 2010 - 04:40
    RD350 YPVS F2
    Europe
    Cool
    Maybe we will soon know whats inside the ryger engine...
  11. #21176
    Hi David, yes I got the PM with your home address, but not an email.
    The Lambda I use is from Innovate Motorsports with a Bosch heated wideband, and it can read out in various formats.
    It will convert directly to A/F ratio, Lambda Number, or 0-5V, I use the A/F ratio as an input direct to the dyno datalogger so as to see
    the power overlayed with A/F as well as deto etc.
    The probe is in the front of the muffler,with a threaded insert that sits right on top of the perf tube.
    It has a gauge reading out A/F, but you for sure havnt time to watch that when doing a dyno run.
    One take on the dam idea affecting the top end so much, is that is exactly the effect you see by putting a 75% nozzle in the duct exit when running a sim.
    This is why I thought the next step should be to extend the floor right out the flange face.
    Gaining all that top end means you have an option to redesign the pipe for better mid, or use the overev capability and use the pipe to make even more power up top.
    The Ryger homologation is due to be published publicly by the CIK on the 1st Jan.
    I will be onto the site all day looking for the info we all are screaming for.
  12. #21177
    This is what I use: http://www.ecotrons.com/products/wid...ler-alm-gauge/
    The controller output is configurable and you can connect an injector input to it for rev information. Supplied with software to monitor, record, and control. I have mine setup just to monitor the lambda with the gauge but another output is being fed to the ECU and the Lambda is recorded along with other ECU parameters during engine operation. Hopefully today I will start(again) with autotuning using the lambda output to the ECU and a brake dyno type of thing to hold certain revs and load. Cool little feature where the system automatically tunes itself for lambda=1, or with the flick of a switch it tunes to a "desired" lambda in another table with a range of values over various loads, throttle positions, and revs
  13. #21178
    Just had another look and saw this: http://www.ecotrons.com/products/alm-diesel/
    Might be more resilient in the 2-stroke environment, if that's a problem.
  14. #21179
    Ryger Crank ?
    Frits posted this in Foundry Thread
Name:	linear rod crank.gif
    Looks a bit like a copy of Flettners crank
    https://youtu.be/-2AhNvDFNlQ
    "Linear rod crank, no cams, no scotch yoke, just a crank within a crank. Each crank offset is 12.5mm, total stroke is 50mm. Not over hung, fully supported. Clicking sound is the rod touching the case at the bottom, will sort that next time it's apart. TF 100 case
    So if somewhat different than the Ryger we also can have a oil less top end with HCCI that could technically rev to approx 30,000 rpm."
  15. #21180
    I now think it is the sort of lean heat rpm you see when turning the PJ off. Not sure it is a good thing in this case, anyway those extra rpm disappeared when we jetted up so I think your suspicions may be right.
There are currently 25 users browsing this thread. (1 members and 24 guests)
