Page 1421 of 2776 FirstFirst ... 4219211321137114111419142014211422142314311471152119212421 ... LastLast
Results 21,301 to 21,315 of 41629
  1. #21301
    26th August 2015 - 15:32
    1980 Yamaha RD/H2 750
    Ballina N.S.W.
    whilst driving around this vast country. thinking about all aspects of life...
    has anyone put a power valve on the bottom of the of the exhaust port?
    I've assumed that the short circuiting from the A port to the exhaust port mostly happens in the lower rev range?
    If not, then, nevermind
    Yeah, funnily enough crbbt, I did raise the notion of such a device back in post# 21005..
    Dunno if its been tried, since in general PV's concern themselves with the top/opening of the exhaust,
    perhaps some H. Ricardo sleeve-valve work considered the lower port issues in the past, if not variable nozzle ducts..
  2. #21302
    Quote Originally Posted by G Jones View Post
    We use RGV coil - or a clone of it - massive spark even at zero RPM
    If possible could you please post a photo and some pointers of where we could get RGV or Clone RGV coils, many thanks TeeZee. Team ESE would like to use them with their Ignitecs too.
  3. #21303
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    coils
    http://www.nology.com/
    http://www.thetuningworks.co.uk/stor...7af1b7e6ff50fe
  4. #21304
    31st July 2005 - 11:15
    a shed full of crazy shit
    Talk to Liam Venter @ fastbikegear. He has the Nology coils in stock.
  5. #21305
    23rd November 2014 - 22:11
    used to race TZ350 and Rotax
    London , UK
    Gordon, yes using that needle and tube combination.
    In the photos of Meteor Pistons, the ring groove looks to lower than a Yamaha G piston, is this the case ?
    Are all the piston dimensions the same as std Yamaha ?
    I'm interested in the RGV 'clone' coils, where can I source them in UK ?
    When you said 'might not be necessary' , did you mean new crankcases are still available, or someone has plans to make billet sets ??? Sorry for all the questions. Just curious. ..
  6. #21306
    5th September 2015 - 07:44
    2001, Aprilia, rs250
    Holland
    Homologation new KZ engines 2016
    Well, DEA has decided to do something different
Name:	DEA 2 cylinder.jpg
ID:	318631Click image for larger version.
Name:	DEA cylinder.jpg
    Why opening the C port at the bore ?
  7. #21307
    Quote Originally Posted by Jvenni View Post
    looks like a wind up mate
  8. #21308
    My guess: so the ends of the piston ring will have less of a torture when passing the C-port floor (if there is no floor, you can't hit it).
  9. #21309
    I haven't seen a triple boost port before, or indeed inlet of that splayed size, presumably towards the transfers.
    but the boost is interesting if modifying an old cylinder if it were effective.
  10. #21310
    Piston life would surely become an issue with that gaping hole ?
    And you just know that the first thing anyone's going to do is radius the transfers/bore edge...
  11. #21311
    Yeah it's got boysen ports as well, presumably with the studs partially obscuring the flow.
  12. #21312
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    It is no triple boostport, it is a divided B-Port like in Suzuki GT250 or old Suzuki RM125 Cylinders.
    Triple boostports have been used by Malossi on their MHR Team Bigbore because of the limited space for the B-Port (studpatern).
  13. #21313
    Why would DEA make a cylinder reed for KZ2 when they already have a case reed KZ2 engine ?
  14. #21314
    The pictures added by Jvenni show a cylinder for Vespa Smallframe.
  15. #21315
    Ahh yes the first picture makes that more clear.
There are currently 170 users browsing this thread. (0 members and 170 guests)
