That looks like a nice job on the RZ cylinders.
But possibly not needed nowdays as VF have a new reed for the Banshee that is a big step ahead of the VF3.
The RZ needs plenty of inlet capability when tuned really hard, but the CPI Cheetah cylinder had CR250 size reeds ( 68mm wide )
that needed to be offset outward to make them fit.
Calvin and I had a major disagreement about this, until I fitted the smaller 60mm CR125 VF3 ( looks the same as your NSR reed )
and offset them back onto the cylinder center, with a 6mm stuffer plate down one side to equalise the flow.
This change made +5Hp, and the CR125 reed is capable of even more than the engine could mangage.
So bigger in this case for shure wasnt better.
Ok so you dont want to set the powervalve you want to set the ignition timing, my understanding was the early krs had 2 steps and needed a battery which you have removed, is this a development class bike or a Cams150 bike if it is a development class bike then you should only run stock timing.
There is no mechanical advance on the ignition , the powervalve is mechanicaly operated
The mechanical PV mechanism is almost always set by the tension of a spring resisting the movement of balls up a ramp.
Its easy to shim the spring to make it open later ( looks like the KR is opening way too soon ).
But the issue then is that it may be fully open at a later rpm, but the more you shim it, the faster it opens.
This is usually not whats needed.
Its easy enough to set a PV from scratch, do the dyno run with it locked down. then one with it locked up, and one in 1/2 open position.
Overlay the graphs and the 3 points are then easy to plot.
This will be impossible to replicate with a mechanical servo.
But using the EXUP motor off an R1 its cheap and easy to add an electronic setup driven by an Ignitech.
When people put pipes on an R1 they always dump the EXUP, so they are available off Ebay for chips.
Honda also did a cable servo PV in 2004 on the CR125, so those bits will work as well.
Here is the setup on a KTM250.
Ok, another RG50 run on the dyno.
Blue line = exhaust dam plus a nozzle that was 90% of the open part of the exhaust port window. Red line = no dam and nozzle that is 90% of the total exhaust port window.
Green line, our original best with an 85% Ex, no dam and no nozzle but since then we tried to improve the flow direction of the "A" transfer port windows. We are waiting on the delivery of a decent porting tool so we can shape the "A" port properly as we suspect our previous efforts have only made them prone to short circuiting.
I'm giving you another week to get to 6hp.
If the lesser result was due to (more) shortcutting wouldn't the revs go down instead of up TZ?
CAMS bike. I have no idea where the battery would be connected. One wire comes from the magneto and goes straight into the coil. There is no CDI box or rectifier. The only possibility is the CDI (which must be very small) is built into the coil itself. Only one space lug to the coil and an earth.
The bike as a Tyga Performance exhaust so I'm guessing the pipe and the mechanical advance are not quite synchronised.
Cheers Wallace
Of course an electronic power valve governor is preferable to a centrifugal one (and let's not even mention a pneumatic one). But if you are compelled to use a centrifugal setup, a highly progressive spring could help. Space permitting you can approach that with a second, shorter spring, floating inside the original spring, which will give you a two-step spring constant.
Reality is going to kick you in the face, Wallace. No matter how good a rider you are, one day someone will block your line and you'll lose one second getting back into the power band. And in racing one second is like a week...
There are currently 173 users browsing this thread. (0 members and 173 guests)
