Page 1437 of 2776 FirstFirst ... 4379371337138714271435143614371438143914471487153719372437 ... LastLast
Results 21,541 to 21,555 of 41630
  1. #21541
    I see auxiliary exhaust ports. Didn't the CIK papers say only one exhaust port?
    That's the bottom of the Cylinder Larry........I don't see any Aux ex ports (but I might have that wrong)
    I only see one and a lot of transfers
    http://www.kiwibiker.co.nz/forums/at...7&d=1453240236
  2. #21542
    11th August 2015 - 01:42
    Henderson Ne USA
    RYGER speculation
    The picture is not real clear but could swear I see auxiliary ex ports also. Just as suprising is a lack of evidence that any valves exist in the "valve plate"......... Kermit Buller
  3. #21543
    Quote Originally Posted by 2005bully View Post
    I went back changed the contrast on the pic and yeah not so sure...........A shadow or well I have no idea?
    Last edited by husaberg; 22nd January 2016 at 14:43. Reason: pic removed as it seems it was inadvertantly posted by frits?
  4. #21544
    Attachment 318990
    Is it an aux exhaust port , or a port to tap off exhaust for reuse/hcci purpose as it seems to be above the bridged exhaust port
  5. #21545
    Frits, is this the homologation engine or an early development engine ? are they the same ?
  6. #21546
    Clearly we are looking at parts that don't necessarily all come from or go into the same engine.
    I think the auxiliary ports either side of the main exh port aren't exhaust ports (the doccos we have seen indicate one exh port only), but some form of blowdown ports. There is lots of energy in the exhaust to do something with. Remember the 30:30:30 rule. There could be 60 hp (45kW)or so to provide some charging function as an alternative to using a tuned pipe, or possibly both together. I reckon a 60 hp supercharger (not that it is) would have to be very useful in increasing the power of a 125.
    The Ryger could be the way to harness it.
    OK Frits, we're thankful for the first feed of breadcrumbs, and they tasted good, so looking forward to the next snack.
  7. #21547
    5th January 2013 - 13:23
    89 KX500
    USA
    The port that comes down from the reed cavity to the base gasket surface appears to almost dead end at the base plate. The open area cross section would only be the thickness of the base gasket.
    Clever how the cylinder pilots on the base plate to ensure concentricity.
  8. #21548
    Ok, I will calm down and not get angry.
    The point I was making was we could beat the best in the world, if you raced Biland in his LCR Krauser what do you think would happen after 20 laps
    around Taupo - wet or dry.
    And I dont want or need the " business ",I post on here to pass on 2T knowledge very few people have.
  9. #21549
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    We appreciate that Wobbly, the more we learn the more we realise how little we know, thanks.
  10. #21550
    9th June 2012 - 18:32
    Bucket Sidecar
    palmerston north
    I would get my arse kicked like most of the people on the planet would be.
    But boy would I send him packing with his head between his legs in a game of table tennis...
  11. #21551
    United Kingdom
    I think it could be an early development engine, the front studs look longer than required. However regarding the ports, the homologation document will include a drawing showing position of these.
  12. #21552
    Attachment 318990
    and about a cm to the left of the yellow circle looks to be the other end of the duct you mention.
  13. #21553
    Let's start with some crumbs to wet your appetite.
    Attachment 318966 Attachment 318968 Attachment 318965 Attachment 318967
    So, a heavy but solid topped looking piston. That fits in a tube for linear motion. A ridiculous amount of inlet area. Conventional transfer area but with sharp holes on the inners.
    My brain hurts.
  14. #21554
    The spacer plate is a consumable like the piston.
  15. #21555
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    nice picture of a german built vril 1
    i'm over buckets
There are currently 229 users browsing this thread. (0 members and 229 guests)
