Page 1442 of 2776 FirstFirst ... 4429421342139214321440144114421443144414521492154219422442 ... LastLast
Results 21,616 to 21,630 of 41630
  1. #21616
    5th January 2013 - 13:23
    89 KX500
    USA
    I find it hard to believe there is no side view of the piston; only a top view.
  2. #21617
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Another observation from the homologation documents regarding the piston. There is a 1.0 mm radial drilling between the two piston rings that connects to the cavity within the 36 shaft or rod of the piston, which is also connected to the wet sump. This might mean that they use some suitable 2 stroke oil in the sump, which would then be a consumable, albeit very small (maybe).
    Has anyone thought about the assembly sequence? Maybe the piston is of a passive 2 piece design.
    Can't believe the CIK approved documents with the various inconsistencies or errors between the drawings and the pics.
    The piston has a gudgeon pin cover, retained by two screws. Not sure what they to at other end of gudgeon pin, but another cover there would make sense to me, though no screw holes are shown for one on the drawing.
  3. #21618
    30th April 2009 - 15:26
    TAKA by TAS MOTOR
    42­° South
    Ryger Piston
  4. #21619
    8th July 2013 - 11:01
    2001, Aprilia, RS250
    Oz
    Good to see people are honouring Frits' request to not repost the images he inadvertantly posted....
    Hope that little error didn't cost him too much per his NDA
  5. #21620
    Yep, we can see what you have said, but how would you tighten the 2 screws (M3,4 or 5) if these were under the spacer plate which can't be raised high enough. Maybe it can, dunno. I guess we'll have to wait for the real doccos so we can have some accurate drawings to scale off. Unfortunately we might not get the full piston drawings as these traditionally are never included in previous CIK doccos.
  6. #21621
    I take your earlier point about the gear ratios and pipe being unchanged for all intents from the motor it's based on. You're inferring that this version isn't intended for 30,000rpm...
    Assembly sequence ain't difficult. Put the plate onto the piston and push it as far up as it will go. Offer that lot onto the top end of the rod and insert pin. I'd point out here that the unseen other end of the pin bore may actually be blind...Insert whatever retainer is used and put the slide cover on. Lower plate into top of cases. Barrel should then go on as per conventional assembly.
    I'd assume that the piston lubrication provision you point out should allow a much reduced oil content in the fuel....
    Edit - posts crossed Ken, looking at the pics I reckon the plate will go high enough.
  7. #21622
    11th August 2015 - 01:42
    Henderson Ne USA
    Ryger piston
    Nothing here
  8. #21623
    Quote Originally Posted by 2005bully View Post
    In regards to the piston construction. In the bottom picture the piston appears to be machined from a single billet. In the top picture where the piston is installed in an engine, the inner tubular part of the of the piston that extends into the spacer plate looks to be of a different material. Or is it just plating giving it a different appearance? It would make for simpler top end rebuilds if the top of the piston was separate and removable from the bottom. Kermit Buller
    I note the inner "tube" part of the piston has two rings running on it. Any colour difference i'd hope is plating.
  9. #21624
    89 KX500
    USA
    Rings
    My guess is Teflon rings.
  10. #21625
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    It is getting a little big bit silly now....
    "Image protected by non disclosure agreement"
    The homologatin papers are there so one should stop that secrecy shit now. it is ridiculous.
  11. #21626
    23rd September 2015 - 05:11
    does Playstation count?
    USA
    So it seems that the posted homologation forms don't reveal much. As others have stated, this is probably not the ultimate version of the Ryger's developments. There are several things missing from ideas we saw in the original patent. Most notably, the "lower cylinder" now lacks the circular reed petals and instead uses a more traditional reed block on the "upper?" cylinder. Of course, many ideas could have been improved upon or scrapped in the nine years since it was originally published. We'll see if there is more information to come in the near future. I guess we'll have to just wait and see.
    Some things I noticed on the homologation form:
    Although the piston's top is a standard 54mm with two rings, the lower piston comes in at 36mm and no ring grooves. Instead, the lower seal is made by two continuous rings (no break at one end) that are clamped into the lower cylinder. These rings transition very smoothly into the lower cylinders' bore (36.00mm rings, 36.15mm bore).
Name:	lower piston clearance.jpg
    The purpose of the lower set of ports is lost to me in this configuration as there are no ports in the lower cylinder to allow passage of air through these ports. The illustration doesn't match the photo as there are no secondary exhaust ports in this cylinder (as the shape in the exhaust cutaway would indicate) and the cylinder doesn't sit in a stepped groove on the lower cylinder (as is depicted in the illustration).
Name:	lower cylinder.jpg
    Several of the other pictures do not resemble their illustrations as well. The cylinder, for example:
    Extra C-port? Spacing?
    I'm starting to wonder if this is the actual homologation paper or some elaborate hoax just to troll us. These pictures maybe range from several periods of the development cycle or the illustrations are just crazy (then what's the point of having them?!?). As for the original (deleted) pictures, I'm sure I'd have a lot to comment on but out of respect for Frits and the Ryger group, I think I'll forget them. We should probably focus on the engine currently being presented.
  12. #21627
    I hope Ryger is not too hard on Frits (NDA) as Ryger has done very well out of Frit's involvement, without him, this would just be a big joke, ie pictures contradicting themselves.
    I challange Luk F to show us this engine (in these Homologation papers) to do 30,000 RPM AND 70HP AND 80% less emissions than a normal twostroke. I don't think he can. The main engine is being held back and clearly some technology, for whatever reason?
    But like everyone else here I WANT TO BELIEVE also.
  13. #21628
    And noe one has discussed the ignition, HCCIWTF (guess for yourself) or how this engine starts below a million revs.
  14. #21629
    The limited amount of trying to figure this out by pics, it appears the biggest "new" technology is an almost 0 crankcase volume.
    That appears to be the "magic"
  15. #21630
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    Blah
    jonny quest:
    I agree with you. I finally figured it out, even the oil separator. The very small crankcase, or should I say ,
    lower cylinder volume must be the key. I'm sure the HCCI has alot to do with it also. My question is about the small oil hole in the piston? If that is what it is.
    Wobbly, this could be your grandson's new lawnmower engine.
There are currently 121 users browsing this thread. (0 members and 121 guests)
