It stopped suddenly on the track.
Ok, you have fooled me, what have you done with the piston ?
I have a small shelf for 'Offerings to the gods" but there is nothing to display in this case.
Under construction amazingly by an 18 yr old ......the yoof of today and their computers![]()
It's my belief that the exhaust skirt of Ryger terminates in the spacer plate. The clearance slot in spacer plate does not open up into crankcase.
Are you all in agreement?
2t institute, show us more of that twin, looks exciting! Are the cases 3d printed at this point?
Probably did it on his phone.
Is this the same engine shown at Milan?
http://www.visordown.com/motorcycle-...led/28510.html
Would make a very cool bucket motor..
Hi,
no, it is not the same engine.
You can follow the project here:
http://www.2t-special.it/forum/viewt...hp?f=14&t=5065
Ok,, i almost 'get it', but still ainīt convinced.
Just to much of a gamble here.
'off' pipe it wouldnīt work good if tuned to work good 'in pipe' and vice versa.
If holding engine revs stabe at one rpm for hours it might work.
But in a shifterkart who is very dynamic in revband and different exhausttemps all the time, rpms altering all the time.
Nahh..
No wonder they seem to seize on track.
If you're considering that the slot/gap I was talking about was the slot for exhaust side piston skirt, I was misunderstood. Look at the drawings and calculate a bit. You'll figure it out what I meant.
Originally Posted by Me; P. 1453
Originally Posted by SwePatrick
E: Nice graphs nasone32! Could you make those calculations at 12krpm and 6krpm?Originally Posted by Me
There must be some kind of vacuum in the crankcase approaching TDC maybe 0.8 to 0.9 on the scale, to me it looks like at 10000 rpm its all backflow from the exhaust to the crankcase the entire time you have circled, and at 15000 rpm there is back flow from the exhaust to the crankcase most of the time you have circled. Just sayin...
I can appreciate that a 2 into 1 twin cylinder would be a different beast than a single.
Hey Motley, you must be looking at the screen thru broken Warehouse glasses.
On the LH side of the pressure sweep the ratio is above atmospheric right up to EPO, then on the RH side as we get past EPC the ratio is below
atmospheric the whole time ( apart from a small upward bump at 10,000 ) - for both the 10,000 and 15,000 traces.
I can see atmospheric pressure no sweat through my warehouse glasses but I don't think the pressure in the crankcase is atmospheric at that time (BTDC), I put forth that the pressure in the crankcase is probably 0.8 to 0.9 bar BTDC. If flow is from the crankcase to the exhaust then the exhaust pressure has to be below 0.8 to 0.9 bar, and I dont see that at all at 10000 rpm and only for may 25-30 % of the opening time at 15000 rpm.
Is there a crankcase pressure trace that shows otherwise?
Still not convinced, As iīve got my own dyno with logging of heat in exhaust i have tested a lot with different temprature in pipe, Isolating pipe etc etc etc.
And a red line thoughout all tests is that every pull is starting with about 200-250degree celsius(5000rpm) and ends up with 450-640 degree depending on setup.
This results in severeal hundreds of rpm difference were engine hits 'stop' in pipe.
And also a lot of difference where the peak power is.
If i got about 620 at end of pull the peak power is at ~12800rpm.
And if i delete isolating i end up in about 450degree, and the peak power is at 11700-11900rpm
This is a ~1000rpm wide area, a quite huge difference in tuned length of pipe.
Therefor i say off pipe, the pipe tunes at an another rpm than 'in pipe' due to dynamic change of heat.
That means that reflecting pulse arrives at different crankdegrees when heat is changing.
Rgds.
