I'm guessing that's not the way to do it then
This would still be possible to use the paper scratching in solidworks to measure for the chordial widths, No?
Not sure I understand this part, care to elaborate? Thanks Wob.
-Sketchy
-Sketchy
I'm going to have to do it as per case one. The cost involved of building up and re-plating cylinders is a great deal of work. I'm hoping that it will be possible to keep the duct radius in a good shape after porting.
I do have the luxury of having a couple of knackered cylinders that I can cut in half to get a better look at the existing geometry as well as have a practice on that first.
In the diagram the A width is way smaller than measuring it like B.
If you take B and roll it out flat the circumferential length will be way wider again,and has no relevance at all to what we
need in EngMod.
You can measure B easily in the SolidWorks model by picking the two vertical port edges and using the measure function.
One of the width options will be the chordal distance.
But A must be measured using bent,ball ended dividers,in the direction of the duct flow actually in the cylinder,unless you have got clever and have modeled the
transfer ducts as well.
When you select T port in the Exhaust page, at the bottom it asks for the duct side exit angle C.
This is pocket exit angle, and done right it makes a huge difference to power in a T port.
Thanks heaps guys for the info, very helpful! I see that I am going to lose quite a few hours in this program!
Thanks for pointing that out Frits, I hadn't noticed that it didn't have a balance shaft! Rod and I rode his TZ125/AM6 bucket in the 2 hour in November to 3rd place. After that I couldn't feel my right foot and left hand from numbness and that does have a balance shaft. Rider comfort is high on my priority list after learning the hard way how much time there is in it on both my bucket and NX4 RS125.
I've test ridden 3 air cooled 125cc buckets with no balance shafts which although they went like rockets, vibrated like hell. If I had a choice, I'd get away from that as much as I could in a freetech bike where you have so much choice. Anyone care to suggest other alternatives to the KTM SX, AM6 and Derbi?
You've commented a few times about the appropriateness of using a RS125 chassis for a freetech 50 bike Frits, I'd love to continue that conversation but maybe without clogging the ESE thread. I'll ask the question on the race chassis thread![]()
I have a simple tool: a set of feeler gauges converted to an inner compass. Grind two of the feeler tips like in the drawing and you're done. You can even still use all of the feeler gauges.
I insert my compass in a port from the inside of the cylinder bore, push the legs against the duct sides, and then pull the compass back so that the legs are pushed towards one another. That way it is easy to find the minimum cross sectional width. Finally I measure that width with a caliper.
Here are some sketches to go with that remark.When you select T port in the Exhaust page, at the bottom it asks for the duct side exit angle C.
There must have been something wrong with the timing of that AM6's balance shaft then. The AM6 can be quite civilized, vibration-wise.
I don't know all the engines that could be considered, but Derbi seems to be the most-chosen engine, preferably pimped with a KTM 50SX cylinder or an Emot cylinder.
Did I? My intention has rather been to comment on the inappropriateness of an RS125 chassis, or any other 125 cc chassis for that matter.You've commented a few times about the appropriateness of using a RS125 chassis for a freetech 50 bike Frits, I'd love to continue that conversation but maybe without clogging the ESE thread. I'll ask the question on the race chassis thread
They are simply too heavy for a decent 50 cc racer. Anyway, see you there: http://www.kiwibiker.co.nz/forums/sh...chassis/page43
Frits, I believe some longer time ago you mentioned how to define the size of the radius of the upper ExPort.... Was that something like approx. 4% of the bore?
YEAH i'm back to engines! today i enlarged the conrod window a fair amount. on the manual mill.
Also a little picture of the 52mm cylinder. Still have to round that edge inside and lot of porting to do. But i'm not planning to use this cylinder anyway. it's 100cc max and this would give 101,8cc.
So i'll stick with the 50mm bore and 95cc.
Unfortunately the regulations have changed to allow for 100cc, it was 95cc the year i designed the engine. otherwise I would have gone for a 50x50 instead of 50x48.
at that time most people was using 52x44 (94cc) because it was the most common "long stroke" for the stock crankcase. so they made the rules to suit that.
That's unlucky because i'm leaving behind a 5% of power.
and also a pic of the frame.
Lookin' good!
I love these little sprint bikes.
Is this a snowmobile sprinter?
There are currently 164 users browsing this thread. (0 members and 164 guests)
