Page 1472 of 2775 FirstFirst ... 4729721372142214621470147114721473147414821522157219722472 ... LastLast
Results 22,066 to 22,080 of 41611
  1. #22066
    17th September 2013 - 01:07
    SWE
    Here are some sketches to go with that remark.
    Attachment 319566
    The radial approach apply to a single exhaust port as well, right?
    If not, I have more adjustments to do.
  2. #22067
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Is this a snowmobile sprinter?
    No I think it is a quad bike frame make for sprinting. I think the yanks call them sand dragsters.
    . . . That shit's Nasty.
  3. #22068
    its a sand sprinter . i havent installed the swingarm and a-arms just yet
  4. #22069
    indeed that's what it is in yankee terms. I wanted to make some crankcases and use two ktm 250 or 300 cylinders but that's well beyond the budget. not to mention I wouldn't know where to start in designing them
  5. #22070
    Right. But you should concentrate on that second picture (repeated below). The 20° difference between direction angle and position angle means that the outflow is not 100% radial, but this approach should give the optimum between maximum outflow and minimum duct volume.
Name:	exhaust outflow concept.gif
  6. #22071
    I've been out on my GG300 all day. A V twin of it would be a well useful engine.
  7. #22072
    SWE
    Thanks Frits!
    The "20* rule" was new to me and why I asked.
    Will add it to the todo-list.
  8. #22073
    2nd August 2011 - 11:11
    Connecticut, USA
    Wobbly
    Sent an email to your new email address. Did you get it?
  9. #22074
    christchurch
    looks like Ruaumoko is stamping his feet again... keep safe ..
  10. #22075
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Jan and Frits has stated more than once that single cylinder two strokes are vibrating themselves to pieces.
    The normal cure is a balance shaft that has some mass and eats some power.
    As I read their sermons ultimate power from a twostroke is limited by blowdown time area.
    If we make two halfsize cylinders the combined limitarea is 1.26 times as big.
    The last 125 gave around 55 horsepower and one of the NSR500V 250 ccm cylinders around 80 horsepower and not 110 as one could suspect.
    Two small give more than a single big.Surprice.
    If the gg300 is nice a V twin with two 120 cylinders will drive just as nice ,be less mass,sound different and will not give driver chronic shaking.
    A V2 90 degree twin with the two conrods side by side on a single crank throw have from birth a better balance as a fourcylinder fourstroke inline.
    The argument that each cylinder must have sepparate crankchamber is maybe nonsense.When the pipes are doing their work it is surely not true.
    This can be a very ligth and narrow engine if the two pipes can somehow be united to one system.Nobody has done it and gain is very beneficial for all mankind.One carb,one crank,two pistons and cylinders and one exhaust will also make unregulated aircraft engines better and safer.
    Is there any law that says that buckets shall have one cylinder only?
  11. #22076
    No, just must be based on a road or trail engine. Not many 100cc twins around now, also will always be a parrallel twin at that. You may make a V twin but that would take some time and money, so far deemed not worth it. There have been twin cylinder buckets in the past (one had four pistons) and Suzuki twin engines used. I would like to see a tandem twin RV 100cc built, that might win a few dyno races I guess it boils down to time and money, no factory race teams here so the budget will ultimatly control the scope of develoment. Ideas are cheap
    Dave, where were you riding the GG300? Aria?
  12. #22077
    Got bored and decided to redesign the bypass thermostats I have used for years and just run out of.
    They will fit all 2T bikes from 50 to 500cc and the bypass is set to start at 42*.
    Up to this temp the water circulates from the pump,thru the cylinder and back to the pump,allowing the engine to get up to temp
    on the warmup lap.
    You can use the biggest rad you can fit and the temp stays at around 50*C with no tape in the coldest conditions., as the thermostat element cycles up and down
    regulating the bypass flow.
    I spent alot of time CAD designing the thing to make it real easy to CNC from stock bar, and it can be anodised any colour.
    They still cost 200USD from RSC,and I reckon they are worth 1/2 that.
    If interest is good enough I will get Flet to hoover up a bunch.
    Also working on a speedshift sensor based on the Bazzaz unit as used on Superbike shift rods, with a proximity sensor that plugs straight into an Ignitech.
    Those are 230E, and again I would say 1/2 that is reasonable.
Name:	Thermostat Assem.JPG
ID:	319609   Click image for larger version.
  13. #22078
    13th September 2014 - 05:14
    '76 RD-400C
    The Emerald City
    Shaking . . . heard a news item this morning, are you South Island guys all okay???
  14. #22079
    The GG 3hundy will win no dyno day contests, it is pretty tardy in performance terms for a road racer. But a couple in a super light road bike with say 80hp with that lazy unstoppable spread.
    Local moonshine ride. Roots tyres but close by.
  15. #22080
    31st July 2005 - 11:15
    a shed full of crazy shit
    Love to see a few more twin 100s they do sound great.
    Here's Scotties twin (again) two MB50 barrels watercooled.
    Up to this temp the water circulates from the pump,thru the cylinder and back to the pump,allowing the engine to get up to temp on the warmup lap.
    I'd be interested in both? Love my current bypass I purchased from you and have two other twostrokes...
