Page 1478 of 2774 FirstFirst ... 4789781378142814681476147714781479148014881528157819782478 ... LastLast
Results 22,156 to 22,170 of 41608
  1. #22156
    sounds to me like jan is still king and rsa is still most powerful 125 on the planet
    A shame there is no class for it anymore.
  2. #22157
    They still run 125's with moto3 in BSB, the lease on a RSA125 might be a bit steep though
  3. #22158
    So the Ryger makes as much power as TZ350's GP125 they could have saved a bit of money doing this, I would not doubt Jans opinion his friends may be well connected in the 2t world.
  4. #22159
    31st July 2005 - 11:15
    a shed full of crazy shit
    International help needed.
    Rules....
    Given the international presence on this page - im hoping someone maybe able to help.
    (Sorry TZ for going left field - but it is two stroke related).
    We are current writing some club rules for the inclusion of 250GP bikes (being twin cylinder two stokes GP not production) in our club series: given they are no longer part of our national manual of Motorsport - we are required to generate a set of supplementary rules for the 2016 season and permits.
    Our fantastic national body can't seem to recover our documented national rules for consumption and reuse.
    And I can't seem to find my older versions of NZ rules (was hunting it out for comparison around buckets) - in a box somewhere....
    Would anyone internationally (or here in NZ) have access to technical rules for 250GP bikes and/or point me towards somewhere/someone whom might be able to help (rather quickly)...
    Cheers
    Brent
  5. #22160
    23rd September 2015 - 05:11
    does Playstation count?
    USA
    Rules....
    http://www.usgpru.net
    This is the premier organization for 125/250 racing in the USA. Go to the download section and there's a rulebook. More closely tied to club racing but follows the former Dorna-like professional experience. Hope that helps.
  6. #22161
    14th June 2009 - 15:13
    suzuki
    europe
    250 gp fim
    Rules....
    Cheers
    Brent
    http://www.spelregels.eu/rules/motor...ING_GP_Eng.pdf
    FIM technical rules for 2009 season.
  7. #22162
    Magics thanks Gents - a little more full on than I was expecting - but the key elements are there to hack into our wider rule set..
  8. #22163
    13th April 2009 - 22:30
    Maico Bimota 250
    KR150 Piston Wear
    Hi Chaps, I'm at a loose end here. Both KR150s exhibit the same wear patterns after an hour or less of racing.
    Bike 1 new pistons (x2) in the original coated bore with a loose fit but within spec
    Bike 2 new piston in a new cast iron bore with new tight (correct 0.05mm) fit.
    Bottom of pistons shows no signs of overheating underneath the piston crown.
    Bike 2 also had a really serious deep score mark where the rings ends meet.
    Bike 1 uses TTS and bike 2 uses Spectro Platinum XS. Both bikes are using the standard auto lube system.
    Open to suggestions.
    http://www.marshland.co.nz
  9. #22164
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    my 250 twin did that to my pistons more one of the 2 pistons , i got sick of it and sold it , turned out it was leaking seals and sucking in air making it run lean ?
    i'm over buckets
  10. #22165
    Or water .... water breaks down the oil film.
  11. #22166
    Ring gap a bit tight causing score of bore and if it runs good with throttle then maybe the pilot jet is small, or an air leak, both making it lean on overrun and the piston trying to nip up causing the scuffs on the pistons. Do not re use the pistons once this happens. A careful measure will show they have changed shape, permanently
  12. #22167
    Piston is not uncovering the eye ports at TDC are they?
  13. #22168
    Maico Bimota 250
    New bearings, conrod and crank seals in both motors.
    The original bike had 40K on the clock and the piston and bore looked ok. As these are still running the standard ignition, ie no retard at max RPM, (I think) could it be that this is causing the overheating issue when used as a race bike and max RPM most of the time?
    PS this is at Ruapuna full track so they are being given a good workout. .
    Thanks Wallace.
  14. #22169
    19th June 2011 - 00:29
    don't know if the original KR150 piston has holes in it's skirt, but a KR1 piston has them to lube the bridge between main and aux exhaust ports (which gets realy hot). I'd drill some holes in the skirt :
    and if you use a piston with the ring pin in the C-port, you could also drill holes in the skirt between B and C ports.
  15. #22170
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    Exh main port looks high placed compared to transfers , is the bottom part of it in level with piston at TDC?
There are currently 31 users browsing this thread. (1 members and 30 guests)
  1. Spetro
