Page 1493 of 2774 FirstFirst ... 4939931393144314831491149214931494149515031543159319932493 ... LastLast
Results 22,381 to 22,395 of 41606
  1. #22381
    Are there any supplementary "tricks" for minimizing carb vibration and fuel frothing?
    Are horizontal shakes better than vertical for the carb too?
    Hmm... The vibrations may have gotten worse after I restricted the sideways movement in the engine mounts to eliminate flying belts.
    Kevin Cameron discussed (An itailian ducati tuner I can't think of his name edit later it was Actually Gordon Jennings own Aermacchi 250 ) in TDC 1. He was using lead weights on remote float bowls on Ducatis etc. The fuel was vibrated away and formed foam with air at certain frequencies. The theory was to tune to a complimentary frequency or harmony by trail and error much it like a guitar or piano.
    I have seen it done with British bikes with TT and GP carbs as well. These generally have a separate mount to isolate them further. from memory the square matchblock float chambers are worse but they may have a pivoting float rather than a pole slider float valve.
    (Note the pommy bikes had solid mounted carbs as did the Jenning Macchi.)
    Maybe you inlet rubber is just too hard.
  2. #22382
    Tuning carb weight to a different resonant frequency sounds interesting.
    My Inlet rubber is pretty soft, at least when warm.
    I suppose it doesn't help that my crank is kinda light, and without a flywheel there's not much Inertia to dampen the vibrations. Then there's the steel rotary valve too.
  3. #22383
    Maybe its too soft?
    You could perhaps stick some hose clips on the float bowl, or try sticking on some wheel weights, It can't hurt (unless get hungry and nibble on the lead )
    Do you have a pole slider carb float or a flap valve one?
    I am pretty sure almost all the GP bikes that were rotary valve (I think) had poles floats. I muse they were less affected by tilting the carbs)
    Wob has also previously mentioned they had problems with he front facing carbs on the BSL500 until they were converted the floats to pole sliders due to the front driving under brakes (and viva versa)
  4. #22384
    Mount car-tire balanceweight´s on carb.
    and have the carb isolated from engine with rubber.
    Good luck!
  5. #22385
    Maybe its too soft?
    Good luck!
    It's an Oko pwk, so flap valve, isolated with rubber mount already.
    Good idea with the tire weights, I'll try that or something similar and see if it helps. How about less weight, I could try removing the "velocity stack" first to see if that has any effect, maybe stick on a pod filter too.
    Does changing the balance factor matter much for the engine, or is it mostly to minimize the "electric" sensation of riding a vibrator?
    What I mean is does my carb/engine care if the vibrations are horizontal, vertical or anything in between?
  6. #22386
    Maybe I could attach a rubber piece with some mass to it onto the carb, should act like a damper soaking up the vibrations?
    Just like how you dampen drum skins with tape and other stuff to remove unwanted frequencies.
    Frits, do you remember what balance factor was used in the Rumi?
  7. #22387
    Maybe I could attach a rubber piece with some mass to it onto the carb, should act like a damper soaking up the vibrations? Just like how you dampen drum skins with tape and other stuff to remove unwanted frequencies.
    No I don't. But for the balance factor it doesn't matter if the cylinder is pointing up or down. All that counts is the deviation from horizontal (and the way it is mounted in the frame, and the frame's stiffness and inertia in horizontal and vertical directions).
    About the various float guidance systems: In the Aprilia disk-valve racers the floats were pole dancers. Mikuni also employed pole dancers, though their carbs did not appear on disk-valvers. Keihin used hinged floats on their Honda works carbs.
Name:	Dellorto VHTC 42.png
ID:	320261   Click image for larger version.
ID:	320262   Click image for larger version.
Name:	Keihin 39 kit 2.jpg
ID:	320263   Click image for larger version.
Name:	Keihin SPJ 06.jpg
  8. #22388
    No I don't. But I think for the balance factor it doesn't matter if the cylinder is pointing up or down. All that counts is the deviation from horizontal (and the way it is mounted in the frame, and the frame's stiffness and inertia in horizontal and vertical directions).
    Ok, thanks anyway!
    I'll tear down the engine and check what the factor is now, then go from there. (read: balance it to what wobbly suggests)
  9. #22389
    17th September 2013 - 01:07
    SWE
    Ok, thanks anyway!
    Note to self 2: Check balance factor of the new Rito crank.
    Thanks for the reminder adegnes.
  10. #22390
    29th January 2015 - 09:21
    kart
    wellington
    mufflers
    Wobbly
    kartsport NZ have just made the latest CIK muffler compulsory for anyone running a KZ2 regardless of the year the pipe and engine were homoligated . The importer of the mufflers is giving 2 options for sale a mid range and a top end muffler . I would have thought that if a pipe is designed correctly with the correct stinger dimensions then the muffler should not have any impact on engine performance .Am I correct in thinking this ??
    cheers
  11. #22391
    Ha ha, an assumption is usually an error waiting to be revealed.
    On a KZ2 the muffler core/stinger makes a huge difference.
    There are ( or was ) 2 types, those with the perf slightly larger than the stinger OD ( what I would call a normal type )
    and another that had a perf around 40mm ID.
    The big core muffler is identical up to peak power, but past 13,000 the power curve simply flattens out, without diving off into a vertical line
    at say 14000.
    By using thin inserts in the front of the stinger, and varying the length of stinger inside the muffler core I gained nearly 25 Hp at 14,000
    ie it was 15 Hp that became 40, rolling down from a 47.8 Hp peak.
    Its legal also to machine back the spigot face of the cylinder to shorten the pipe, if you happen to want it to spin the 15,000 - who wouldnt.
  12. #22392
    16th September 2015 - 06:10
    Harley SShovelhead
    USA
    Quote Originally Posted by wobbly
    Cool, can you describe what you are referring to.
  13. #22393
    OK, so here is a sketch in the style of DaVinci.
    I varied the insert ID in 0.2mm increments,balancing the power output with deto level and jetting on the dyno.
    There are 2 stinger sizes available, I started with the larger size, and this tube with the step formed by the insert makes more power than does
    the smaller tube stinger on its own.
  14. #22394
    Right you are with the Keihins, some further pics of the NSR500's.
    I do wonder though if the float pivots were mounted the other way around to close off on hard braking.
    I can't remember if they were $25,000 or $100,000 US
    I will post Wobs Quote (when I find it)
ID:	320274Click image for larger version.
ID:	320275Click image for larger version.
ID:	320276Click image for larger version.
ID:	320277Click image for larger version.
ID:	320278Click image for larger version.
    I found it
    http://www.kiwibiker.co.nz/forums/sh...post1130134206
    The air solenoids on the RGV/RS250 type Keihin carbs are there for emmission and air fuel correction at part throttle settings.
    One feeds air into the primary circuit to lean off the mixture at just off idle conditions and the second one feeds air into the emulsion tube to lean off the mixture at higher rpm/part throttle.
    The switching points are set by the ECU depending upon rpm and TPS position.
    The F3 race kits blocked these off, and used a different jet setup for high perf usage.
    The KR3 had special carbs on a few bikes, as they had nightmares trying to get the Keihins off RS125 Honda to work running around the wrong way.They used a pump around system to keep the fuel level at a constant height.
    I finally figured out what was happening when building the BSL.
    The floats were being pulled down under hard braking - flooding the bowls.So I had CNC bowls made up with floats from TMX carbs running on rods, instead of pivoting.
    This was posted on another thread Turbo CR500
    Looks neat
    http://sandiego.craigslist.org/csd/mcy/5481564457.html
  15. #22395
    30th November 2015 - 17:36
    kawasaki kr150a
    New Zealand
    kr150
    at a bit of a loss at the moment.
    wallace and i are putting a new ignition onto my kr150 using an ignitech dc-cdi-p2. its only in the testing phases at the moment. idles beautifully, it has a nice clean signal on idle. but when the revs get up a bit the signal is getting a lot of noise and around 6000 the ignition starts jumping between 6000-17000rpm so going on the rev limiter. the way the pick up is at the moment is that its getting a signal off a small hole in the flywheel, probably a balancing hole. so rather than having no signal then a pulse, im getting a signal then a pulse of no signal, is this still good enough way to have it set up?
    any reason why the ignition would be jumping up and down the revs so much?
    i may not have explained this quite right but its best as i understand it
    soz for crap pictures it was dark and my phone is shit
There are currently 65 users browsing this thread. (0 members and 65 guests)
