Page 1499 of 2773 FirstFirst ... 4999991399144914891497149814991500150115091549159919992499 ... LastLast
Results 22,471 to 22,485 of 41592
  1. #22471
    . I was thinking a light twostroke with lots of power and a paddle wheel one for the driven front wheel as well
    Turns out the F1 was all 4 strokes, so had some time to help Neil with the design. No charge.
Name:	Fletto mudrun.JPG
  2. #22472
    Now that my new bike is nearly ready I need to develop a new Alpha-N fuel injection map. The axis's of an Alpha-N map is throttle position TPS and RPM. The steps between cells need to be in even steps. That is not even RPM or TPS steps but even changes in engine load.
    "Torque" is largely related to the motors Trapping Efficiency of the air passing through it.
    "Delivery Ratio" is everything when it comes to quantifying airflow through a two stroke motor and it is the air flow that needs fuel added to it in the correct proportions. Trapping Efficiency is the measure of how much of this air/fuel is trapped to be com-busted.
    Initially I thought changes in Torque could be used to represent changes in engine load and could be used for developing a fuel injection map. Well that might be Ok for a four stroke but now that I have tried that approach I now think that Delivery Ratio is the more suitable measure for developing a two stroke map.
    Air flow (Delivery Ratio) through a throttle is not linear. The greatest changes happen between 20 - 40% throttle opening.
Name:	EFI - TPS Map 2 008.jpg
    The first requirement is to find the throttle openings that corresponds to even Delivery Ratio (air flow) steps.
Name:	Delivery Ratio 1Ex80atdc RSpipe+20mm.JPG
    Then I modeled these throttle openings in EngMod2T and got a reasonable correlation and reasonably even layer of Transfer Efficiency steps in the power region of the simulation.
    This information at each TPS position and RPM point should make a handy start for developing the new map.
    The rest of the simulation data (all 12 of them) are posted on the Ecotrons thread. Because the Transfer Efficiency graphs are probably similar to any performance 2T with a few adjustments to the rpm points the numbers may make a useful start to any 2T Alpha-N map project.
    Once I started to understand how EFI worked it was relatively easy to get full power runs but it was quite hard to develop a map that is good for part throttle and transition from full throttle to closed and back to open again. This has been the biggest issue holding me back from having a track ready EFI bike.
    Now to map it all out.
    Simple in XL
    Attachment 320596
    Attachment 320597
    Job done, now to see if it actually works.
  3. #22473
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    Wobbly (or anyone with experience on oils) any thoughts on Penrite oils for 2T compared with other stuff for racing purposes?
  4. #22474
    19th June 2011 - 00:29
    Look it up on youtube, Aria mud run.
    great fun
    the things men invent to do with motorcycles
  5. #22475
    30th November 2014 - 11:08
    69 kawasaki avenger
    brisbane
    desaxe
    re the offsetting the cylinder. does this give a straighter push on the crank as in a tangent if done to excess. if this is so the effective stroke [crank pin to crank center line] during the power stroke which is where the power comes from. the piston to rod angle would be reduced giving less friction. no idea if this is true just a thought from a humble follower of this great forum.
  6. #22476
    Quote " if this is so the effective stroke [crank pin to crank center line] during the power stroke which is where the power comes from ".
    What power - as far as we know to date,there is no proven power to be had with DeSaxe cylinder or piston offset.
    Anything gained from a more linear push on the rod/or less friction is seriously affected by non optimal port timing asymmetry.
  7. #22477
    Great work!
  8. #22478
    13th April 2009 - 22:30
    Maico Bimota 250
    Quote Originally Posted by 1948rod View Post
    Here is quite a good explanation. More offset more vibration.
    https://rideapart.com/articles/free-...ders-explained
    http://www.marshland.co.nz
  9. #22479
Name:	WorkFile Map 39A  16-03-16 RAM_MAP_LdTp_Tps_N.pdf
    This is what my new Alpha-N map looks like. Pretty pleasing to see the map is mostly even steps in the 7,000rpm and above area.
    WorkFile Map 39A 16-03-16 RAM_MAP_LdTp_Tps_N.xls
    And the spread sheet with the original EngMod simulated transfer ratio data and the calculations for developing the new Alpha-N map.
    Hopefully get to try it on the dyno soon.
  10. #22480
    Interesting to see what can be done with EngMod. Looking forward to seeing how it turns out, should be good ....
  11. #22481
    6th March 2015 - 23:42
    1976 RD 250 Yamaha
    Waterless coolant
    Found this due to a search for other stuff.
    http://www.evanscoolant.com/faq/general-questions/
    If you use this would it isn't a watercooled engine
  12. #22482
    Quote Originally Posted by sispeed View Post
    It would also be illegal in most forms of circuit racing, the reason being that spilled water will only temporarily wet the track but spilled non-water coolants will make the track unusable for days.
  13. #22483
    1976 RD 250 Yamaha
    Makes sense not to use it on a track.
    Was more of a joke for the Bucket aircooled rule
  14. #22484
    Yes that's it right there.
    Somone has to have a serious go at the mud run don't they? AND it has to be a loud high powered twostroke.
    Rurual NZ, you should see the kids afterwards all playing in the mud, the fun we had
  15. #22485
    Mud fun ... yum ...
