Page 1502 of 2774 FirstFirst ... 50210021402145214921500150115021503150415121552160220022502 ... LastLast
Results 22,516 to 22,530 of 41606
  1. #22516
    17th September 2013 - 01:07
    SWE
    Ok, I think I got it now!
    Sorry adegenes, I didn't get that you got the resulting masses AFTER performing the "add washers" step.
    I'm slow today...to.
    The numbers so weird it tricked me.
  2. #22517
    adegnes, when adding mass to the little end (to make it "stay in any crank position") you will get a higher balance factor %, not a lower one.
    So the linked explanation is correct, but I think you have misinterpreted it a bit.
    I think I didn't explain my process good enough. When I arrived at the stage where you're supposed to add weight to the small end to balance the crank my small end was already too heavy.
    I can't find anything wrong with your conclusion. Sounds like you will need a couple of heavy metal slugs - or an angle grinder.
    Still makes me wonder: who on earth built the crankshaft like that?
    Apparently Doppler does...
    What I was expecting to find was too much counterweight, cause this crank is typically ment for 70cc "racing" cylinders.
    Obviously they didn't give a shit, or they just don't have a clue.
    I'll start with removing the aluminium slugs in the balancing holes and go from there.
  3. #22518
    No worries!
  4. #22519
    SWE
    So much for "high level brand" parts...
    Less than 25% is weird on its own, but can the up side down orientation of your cylinder make things more noticeable/worse?
    Need to check my Rito. Guess the answer can be anything between here and eternity.
  5. #22520
    I also find 12.6-12.8 to be a good range to aim for up top, then slightly leaner around 13.5 at mid throttle and mid rpm, and leaner again around 14 at low throttle and low rpm
    Sounds logical to me, as rpm increases, so does the trapping of fresh charge. So you might actually have the same A/F ratio inside your cylinder during the whole rpm range in reality.
  6. #22521
    frits you staying safe over there ? sounds like all hells breaking loose in that neck of the woods
  7. #22522
    Checked the stock crank, clocked in at 55%.
    Why Doppler, why!?
  8. #22523
    19th June 2011 - 00:29
    Frits lives in another wood, it's my wood that exploded
  9. #22524
    Yes I think so to, and is why trying to get the AF meter showing the correct reading had me chasing my tail.
  10. #22525
    Thanks for asking Peewee. France and now Belgium were hit hard by those bloody idiots; the Netherlands were spared so far.
  11. #22526
    1st June 2011 - 14:39
    Honda NC50
    Straya
    Trying to run 12.5 at low/mid rpm will run very badly, way too rich. I aim for idle around 14-14.7 then progressively get richer from there with the numbers I posted earlier, up to 12.5 around peak then if everything is working at the right rpm itll naturally lean out in the overrev to 13+. Seems to work very well on most bikes. The exact number at each rpm/ throttle point will vary for each individual engine though, that's when you've just got to listen to what the engine is telling you and decide if it want more or less fuel.
    I'll try to post up an example of the matrix of afr vs rpm that I record on the Dyno.., might have to wait til Tuesday though due to the public holiday.
    Due to the nature of a carb low rpm/high throttle will always run leaner than the ideal numbers and high rpm/low throttle will run richer than the ideal numbers. With EFI you'd probably want to get rid of the low rpm/high throttle lean condition but keep the high rpm/low throttle rich condition for protection during deceleration.
  12. #22527
    Great Thanks, it will be a great help.
  13. #22528
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    did not know your all taking A/F in here
    i'm over buckets
  14. #22529
    I prefer Nitrus but you know how killjoy the rules are .....
  15. #22530
    GPR150
    palmertson north
    hell yes , got some of that here , had it from my rc days , waiting for it to turn green then biff it on the ground to see if it does blow up lol
    i'm over buckets
There are currently 300 users browsing this thread. (0 members and 300 guests)
