Page 1511 of 2776 FirstFirst ... 51110111411146115011509151015111512151315211561161120112511 ... LastLast
Results 22,651 to 22,665 of 41629
  1. #22651
    Yes i agree that the injectors do give you a good indication of whats going on via the duty cycle.
    But the " plenty " of people that select the main jet without any data get easily beaten by people that change jets 3 times a day based on RAD,and the
    dyno best power data..
    We won the Kart Nationals at Easter, as our main competition, a European factory driver with the best engines money can buy,selected his main size
    by guessing.He poled it,but detoed an engine to death the next cool morning,he had to change engines then ran well rich in the final just to ensure he finished.
    We changed jets every race,based on the weather station,and the piston looked brand new after 60 laps of racing.
  2. #22652
    But the " plenty " of people that select the main jet without any data get easily beaten by people that change jets 3 times a day based on RAD,and the dyno best power data.
    I expect that is very true.
    The Ecotrons EFI has barometric and air temperature sensors for automatic fueling compensation so hopefully once I am on the money with the dyno the ECU's auto compensation will give pretty much the same results as changing the jets 3 times a day.
    I feel very comfortable with tuning the EFI system for maximum power, above 50% throttle position that is relatively easy.
    The problem I am struggling with is at the low end, if this was a carb then the EFI bit that is challenging me now is the area covered by a carb's pilot jet and transition to the slide cutaway.
  3. #22653
    I feel a hybrid coming on.
  4. #22654
    Yes possible, if the "24 carburetor or equivalent" actually has to flow fuel too then a hybrid could make sense.
  5. #22655
    25th February 2014 - 01:31
    mostly GG 280 trials
    right HERE
    is there any chance to vary the fuel pump pressure with RPM and/or TPS? It may be slow to respond but enable a lot more tuning options.
  6. #22656
    Quote Originally Posted by dark art View Post
    That might be possible, cars have a simple way of varying the fuel pressure in relation to manifold pressure by plumbing the back of the fuel pressure regulator into the manifold, a bit like the old vacuum advance/retard setup of last century.
    Flettner used this trick by plumbing a car pressure regulator into the expansion chamber so as the bike came on song and pressure in the pipe built up it increased the fuel pressure.
  7. #22657
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    wonder if a bleed off useing a solanoid valve tap in back to the tank would lower pressure
    i'm over buckets
  8. #22658
Name:	EFI fuel pressure regulator and fuel rail.JPG
ID:	320874Click image for larger version.
Name:	EFI fuel pressure regulator.JPG
    A cars fuel rail with variable pressure fuel pressure regulator. The hose at the back of the regulator plumbs into the inlet manifold plenum.
    The varying pressure in the manifold plenum varies the fuel pressure in the fuel rail so that a constant un varying pressure differential is maintained at the injector nozzle for consistent fuel delivery.
    By plumbing the regulator into the chamber we can use this feature to increase the fuel pressure as the pressure inside the expansion chamber increases as the two stroke engine is getting up on the pipe and starting to make real power. Flettner used this feature on his Kawasaki running E85 fuel.
  9. #22659
    18th July 2015 - 16:21
    2015 Avanti
    Ryger Failures
    Can anyone enlighten about any Ryger failures, if they do fail, what is failing ?
    Thanks , Neil L
  10. #22660
    Thanks , Neil L
    No one is saying nothing!
    It has been speculated piston to rod connection failure but it's all hear say.
  11. #22661
    Thanks , Neil L
    Pretty sure (with all due respect) its failings tend to fall into the Expectations vs Reality category.
    It should be remembered it took until the 1960s for the conventional two stroke to consistently beat the diesels. So there is still plenty of time for R&D on the Ryger.
  12. #22662
    13th April 2009 - 22:30
    Maico Bimota 250
    means everyone is saying something.
    I presume you mean
    No one is saying anything or
    everyone is saying nothing!!!
    http://www.marshland.co.nz
  13. #22663
    Maico Bimota 250
    Attachment 320857
    A fuel injector has a tuning range just like this jet kit has. And just like when you get down to the smallest jet in the kit and still need to go leaner you need a smaller jet kit or injector to move to the next lower tuning range.
    That is my problem with the current small injector, it is just not small enough to give me the tuning range required to handle the minimum fueling requirements on high rpm over run on a closed throttle. I need the next smaller injector (kit).
    Send me one and I'll make you a smaller set.
    Cheers Wallace.
  14. #22664
    1st June 2011 - 14:39
    Honda NC50
    Straya
    May I ask why you're not using a wideband O2 to tune this area?
    It would be relatively straight forward with a wideband and a brake dyno.
  15. #22665
    May I ask why you're not using a wideband O2 to tune this area? It would be relatively straight forward with a wideband and a brake dyno.
    Why a brake dyno? Then you would be developing an engine for a set of circumstances that it will never see on a race track.
    Going through the revs on an inertia dyno and registering revs, torque and lambda simultaneously is an excellent way of establishing an injection map.
    Besides, running constant revs on a brake dyno with too little fuel or too much ignition advance may kill your engine, whereas it might survive on an inertia dyno.
There are currently 208 users browsing this thread. (0 members and 208 guests)
