Page 153 of 2773 FirstFirst ... 531031431511521531541551632032536531153 ... LastLast
Results 2,281 to 2,295 of 41591
  1. #2281
    Looking to improve power by reducing crankcase temperature.......
    With this copper/heat shield stack I hope to add extra cooling to the barrel and keep the heat from transferring to the crankcase for a cooler incoming air/fuel charge.
Name:	Under Cly Copper Fins.jpg
ID:	207814   Click image for larger version.
Name:	Under Cly Copper Fins 2.jpg
ID:	207815   Click image for larger version.
Name:	Under Cly Copper Fins fitted under the Barrel.jpg
  2. #2282
    Copper has twice the thermal conductivity of aluminum.
    So, very clever, the copper head gasket forms a cool squish area and extends out to be an extra high efficiency cooling fin..........
    I think that if I can reduce the heat uptake of the exhaust into the cylinder and get the lower cylinder fin to run at less than 100 then the head will run less than 80 and that would be very good as I will be able to tune it closer to the power output of a water cooled motor.
Name:	Cooper Head Gasket and Cooling Fin.jpg
ID:	207817   Click image for larger version.
Name:	Under and Head Copper Finning.jpg
  3. #2283
    Ducting cooling air to the head and barrel.............
    ducting for cooling the head, we want 26 - 28 rwhp from this engine next year.
Name:	Ducting to the Head.jpg
ID:	207819   Click image for larger version.
Name:	Ducting to the Head 2.jpg
  4. #2284
    Finds some real info on port shapes and shares it with us............like he does with all the good stuff he finds on the net....
    The main things that make more power, are, and in order of priority (1) the primary transfer tangental angle, (2) the inner transfer port radius, (3) the main transfer port axial inclination, (4) and main transfer port open size and shape. All high lighted in pic 2.
    Get a copy of the paper from here:- http://www.2stroke-tuning.nl/media/pdfjes/porting.pdf .
Name:	Ports the features that affect Power.jpg
ID:	207821   Click image for larger version.
Name:	Ports Best Power-2.jpg
ID:	207822   Click image for larger version.
Name:	Ports Power Curve.jpg
  5. #2285
    Finds on the dyno that retarding the ignition extends the RPM of his bike about 500 and that Ignitech programmable ignitions could be the go......
    What I would like is the fixed ignition curve to 10,500revs then have the retard kick in for over rev to 12,000.
Name:	TZs retarding ignition-1.jpg
ID:	207824   Click image for larger version.
  6. #2286
    Shows us how to improve the flow through a 24mm carb..................
Name:	Plenum Carb Drawing.JPG
ID:	207826   Click image for larger version.
Name:	Plenum 28-24mm Carb.jpg
ID:	207827   Click image for larger version.
Name:	Drawing Carb-02.JPG
ID:	207828   Click image for larger version.
Name:	Keihin 24-28.jpg
  7. #2287
    TeeZee's clever plenum chamber ideas to get around the restriction of a 24mm carb................
    ………could this work? a 24mm carb feeding into a plenum chamber and the 34mm rotary valve inlet feeding directly from the chamber to the motor. That way the motor sucks full atmospheric pressure through a high flow 34mm bell-mouth and at WOT the restrictive 24mm carb has much more time to refill the plenum.
Name:	Plenum Drawing.JPG
ID:	207830   Click image for larger version.
Name:	Plenum  Valve Cover Bellmouth.jpg
ID:	207831   Click image for larger version.
Name:	Plenum Inside.jpg
ID:	207832   Click image for larger version.
Name:	Plenum on the Bike.jpg
  8. #2288
    And did it work?..................Yes Sir, it sure does...............and starts so easily too.......
    ta da!
  9. #2289
    Happy Birthday Dad.......We Love Your Work............
  10. #2290
    Some of the fast Buckets and Riders at Mt Welly......the team are looking forward to seeing you out there again and keeping them honest....
Name:	Quick Bucket.jpg
ID:	207876   Click image for larger version.
Name:	Fast Bucket2.jpg
ID:	207877   Click image for larger version.
Name:	Fast Bucket3.jpg
ID:	207878   Click image for larger version.
Name:	Fast Bucket4.jpg
ID:	207879   Click image for larger version.
Name:	Fast Bucket5.jpg
  11. #2291
    4th February 2005 - 07:32
    Rattlecan blue
    Wrong. You've got me in there and I'm far from fast.
    The rest of them fair hook along though.
  12. #2292
    Hi Henk, I have started getting my 50 together, with Thomas's help I should be ready for the next meet, how much do you need to do to get your 50 on the track?
    I got the new slicks from Fi5hy, I figure that the F5 class should be real fun while I get the F4 ready for Taupo..........
Name:	RG50-01 Left Side.jpg
ID:	208261   Click image for larger version.
Name:	RG50-01 Front Brake.jpg
ID:	208262   Click image for larger version.
Name:	RG50-01 Right Side.jpg
ID:	208263   Click image for larger version.
Name:	RG50-01 Rear Brake.jpg
ID:	208264   Click image for larger version.
Name:	RG50-01 Slicks.jpg
  13. #2293
    Rattlecan blue
    Not a lot realy but with the trickery you have going on there you'll be battling for first while I'm strolling around in last.
    My 50 is a bog stock MB.
    Probably won't look at it this month since I'm a bit busy ayway and will be concentrating on putting the FXR motor back together in a way that it hopefully doesn't explode again.
  14. #2294
    At the mo, there is only three F5 riders that regularly turn up and they are all fast guys. If no one else gets out there I will be riding around at the tail end all by myself.
  15. #2295
    Remember that guy who was building an electric bucket, well check this out, this electric job has some real punch...............
    and then there is the old school sound of heavy metal...................
    and then there is this one that sounds a lot like TeeZee's bucket...............
