Page 1532 of 2776 FirstFirst ... 53210321432148215221530153115321533153415421582163220322532 ... LastLast
Results 22,966 to 22,980 of 41630
  1. #22966
    http://i1056.photobucket.com/albums/t380/uniflow/th_f9_zps30a41b19.mp4
    An old piece of (poor) video, the F9 when first set up with EFI and the ball valve. RV slide is also installed and operating here.
    Husa, help, I've installed the video wrong? I think. I guess I'm just showing the ball valve at work, if only free running.
    I am not finding it
    oh wait I did
    http://vid1056.photobucket.com/album...ps30a41b19.mp4
    here are most of your videos
    https://www.youtube.com/user/GerbilG...lf_id=1&view=0
    https://www.youtube.com/channel/UCeS...B1bDRW2iuXe25Q
  2. #22967
    27th January 2011 - 11:30
    asdasd
    AKL
    Unsure if anyone would be able to see these but a mate just posted some good shots of the Suter 500 on facebook:
    https://www.facebook.com/seth.devere...5123468&type=3
  3. #22968
    When I first tried the plenum it gave a dramatic boost in torque in the rpm area below the original peak torque curve. Basically it plumped up the area of the torque curve that is negatively affected by the pipe resonance working against the engine's exhaust port timing.
    I guess this was a resonant effect between the size of the plenum, it's inlet and the engine's crankcase volume and inlet timing working together to prevent the pipes out of step pressure wave, pushing the fresh mixture back down the transfers, well maybe???.
    The positive effect on the torque curve by the plenum was so marked that I am keen to explore it further. I have an idea that a two chambered plenum could work, one for this torque boosting resonance and a butterfly that opens to another chamber when a different plenum volume is required. Or maybe a variable length inlet runner, or combination of both.
    Attachment 321919Attachment 321920
    But first, to be able to use a plenum without the fuel drop-out issues that you get with an outside the plenum carb, I have to perfect the EFI system. If I can't do that I will look at putting the carb inside the plenum itself and feed it with a pump around bypass fuel system like they use on Karts.
    so the fuel drop- out is caused by the fuel becoming stationary within the plenum?would having some kind of turbulence within the plenum keep it homogenised, or even being able to keep the fuel/air mixture circulating somehow , somwhere?
  4. #22969
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Does anyone know a stream / internetplatform where I may watch the Suter racing on the Isle of man this evening?
  5. #22970
    25th February 2014 - 01:31
    mostly GG 280 trials
    right HERE
    IOMTT website says that most coverage come from itv4. Superbike and senior will be at 4 june.
    http://www.iomtt.com/TT-Info/The-TT-on-TV.aspx
    Of course, after a few days youtube and facebook will be full of it.
  6. #22971
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    https://twitter.com/drobinson97/stat...40889879285760It looks like they have some problem with setup of bike
    57 21 Ian Lougher Suter/Suter Racing Technology 2 19:29.388 116.153 (Last year Anstey managed to do 126mph lap on 1992 YZR500)
    But that sound
    Last edited by Mental Trousers; 6th June 2016 at 22:00. Reason: Bad naughty forum user. Don't use iframes and definitely don't fuck them up!!
  7. #22972
    6th March 2016 - 23:52
    Vespa
    Thailand
    Reading Dyno Graphs
    Hi all together
    I´m new here and just amazed about the knowledge and experience shared in this Topic.
    I´m happy to learn a lot more again.
    Maybe you can help me if there is a talk about dyno graphs and their interpretation,what has to be changed to get a better curve.
    Thanks in advance
    Bye JOchen
  8. #22973
    Isotropic Polishing.
    A short extract from a University study into Isotrop Polishing that explains the process.
    Studies in Isotropic polishing Short Version.pdf
    Isotropic polishing. https://www.facebook.com/SuperFinishingLtd/
    I always wondered if Isotropic polishing was snake oil, but now I am a believer. In short, a normal polishing method would remove material, but Isotropic polishing is a material exchange process.
Name:	Before Isotropic  Polishing.JPG
ID:	322021Click image for larger version.
Name:	Isotropic Polished Crank.JPG
ID:	322022 before and after Isotropic polishing.
    So you wind up with a shiny thing that is still dimensionally the same size as it was. I was particularly interested in how the process would affect the tungsten and alloy plugs in my crankshaft and what the finish on the oil seal surface would look like.
    Isotropic polishing can be applied to dimensionally critical surfaces like the big end bearing surface in a 2T connecting rod and pin.
    As I understand it, bearing surfaces are a ground finished with a fine but distressed layer at the surface, same with gears. Isotropic polishing being an exchange process both removes and replaces this distressed layer with a smooth and finely polished layer. This smooth finish noticeably reduces friction between the sliding surfaces.
    Anyway it can be done locally here in Auckland:- Isotropic polishing. https://www.facebook.com/SuperFinishingLtd/
  9. #22974
    Help
    Help, I am unable to make new posts or reply to other people's posts in the normal way on this thread. I can do everything in the normal way on other threads but not this one. I can't just select "Reply to Thread" or Reply with Quote" and start entering text like is normal. I first have to do a work around which is post a picture and without left clicking the mouse inside the edit screen, just randomly enter text then save it. After that little palva I can then go back and Edit the Post and enter the text I wanted to.
    Help help......
  10. #22975
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    Help
    Help help......
    Testing....
    ...Looks like it's your end mate.
  11. #22976
    Wob PM'ed me, that he is having the same issues.
  12. #22977
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    The end of the world is near lol
    i'm over buckets
  13. #22978
    2nd April 2012 - 00:54
    Yes, you could connect a boost bottle to the inlet tract, directly upstream of the inlet disc. But what good would it do? It would only swallow mixture that should have been entering the crankcase in the first place, but that didn't make it because the inlet closed too early.
    The long column of mixture in the elongation tube has a lot of inertia which means that it is reluctant to start flowing towards the crankcase. And once it is on the move, it should be allowed to continue filling the crankcase as long as the flow direction is positive, which in turn means that a long inlet tract also requires a long inlet timing. You don't want that because at certain revs it will give a lot of blow-back. Keeping the inlet tract and the inlet timing short will result in a forgiving easy-to-jet engine.
    Don't worry about harnessing the pulses in the inlet tract; it would require a tract length of about two/thirds the length of the complete exhaust system (two/thirds because of the lower speed of sound in cold mixture versus hot exhaust gases). In an inlet tract (and even more so in transfer ducts) the pulses are reflected to and fro so many times that they have lost most of their energy by the time they could finally do something good. Bottom line: keep the inlet tract short.
    Frits is it possible to have to short of a inlet tract for a disc valve engine ?
    If so would you explain the issues, complications & tell tail signs please.
  14. #22979
    Help
    Help help......
    Ok. Issue is there's an iframe that gets dropped over top of the page when you try to edit things. So when you click to try and type stuff in you're (unknowingly) clicking and typing in the iframe.
    Somebodies gone and posting bollocks and messed things up I think. Not cool.
  15. #22980
    Quote Originally Posted by Mental Trousers View Post
    Problem fixed.
There are currently 88 users browsing this thread. (0 members and 88 guests)
