wax ive put numerous cylinders in engmod and in every instance the intake and reeds seem to be undersized. i would dare guess your intake and reed block wont be to big
Last edited by husaberg; 9th July 2016 at 22:18. Reason: pretty sure it was the NSR500
Hello
I am looking for advice on scavenge for a cylinder 3 transfers port
You don't want to guide the inlet flow away from the B-ports, Bjorn. You want it to go into the B-ports; you just do not want it to go only into the B-ports; the A-ports should get their share of the flow as well. I think those Boyesen ports look pretty good as they are right now; I would not add any ramps.
Here are some new boyesen ports. Please comment and any suggestions will be greatly appreciated. Thank you jfn2
http://www.kiwibiker.co.nz/forums/al...p?albumid=5034
I know that the tabs hanging down into the reed area need to be trimmed. One pic shows a before view. These go into the B-ports first.
Come on TZ I know you want one of these
http://www.trademe.co.nz/motors/moto...1117556154.htm
Thanks for your reply.
The cylinder from a French moped, Peugeot 103
not expensive category requires only removing material for the engine.
Expansion Pipe and carburetor 15 mm authorized
for the corners of A-port I thought he had a hook on the rear side is Good idea ?
hi frits would the mods on a 3 port engine work on a reed or rotary kart 100cc engine. if not would a much wider a port work better with a divider for direction. thanks frits.
You're not exactly overwhelming me with information, Rod. I would need a little more than the number of ports and the cylinder capacity.
But in general all available real estate in the cylinder circumference should be used for ports. So if there is room to widen the ports, use it.
3 port engines as used in direct drive karts are very sensitive to even tiny changes to the scavenging regime.
Mess up this and all the bottom end needed will disappear.
They usually have plenty of transfer area with just the 3 ports as drawn, due to the restricted Blowdown capability.
And again, if you go cranking in a heap of transfer STA, and get it mismatched with the Blowdown, you will immediately loose stream velocity
and thus directional control at low rpm.
How many zillion dyno tests do you think the top engine guys have done to get the things to where they are now, and it appears that 3 port
transfers are plenty for a wide power band starting at 8000 and going past 22,000.
guys I had some scrap bits sitting around that I been trying different boyesen ideas. their pointed down but with this style of cylinder I see no other way to do it without grinding them higher which lifts the rear wall of B. which effectively shortens the B tunell as well I suspect ? maybe I could make a small radius on the roof corner of the rear B wall/ boyesen without lifting the wall to high but small radius may not be as effective as bjorns cylinder
There are currently 42 users browsing this thread. (2 members and 40 guests)
