Page 1546 of 2776 FirstFirst ... 54610461446149615361544154515461547154815561596164620462546 ... LastLast
Results 23,176 to 23,190 of 41630
  1. #23176
    The Cheetah cylinders from CPI have the Boyesen tunnel roof about 20mm down the B port rear wall.
    But as Frits said, the dividing septum between the transfers is also dropped down to the same level, such that flow can equally access
    both duct entries.
  2. #23177
    both duct entries.
    ive seen those cylinders but doesn't that also shorten the transfer tunnels length and reduce the mixture enertia and kinetic energy ? I vaguely remember frits talking about this stuff in the pisa tower
  3. #23178
    Page 1000 is your friend. It has links by Husaburg to Frits post about the leaning tower and lots of other great stuff.
    http://www.kiwibiker.co.nz/forums/sh...tuner/page1000
    And the post itself:- http://www.kiwibiker.co.nz/forums/sh...post1130452963
  4. #23179
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    get the same result with only 3 Port scavenging is more difficult
  5. #23180
    anybody relocate the ring pegs and weld the hole on top with success ? been practicing on old pistons and may give it a go. alittle more practice and I should have full confidence
  6. #23181
    Yes the Cheetah cylinder has the port dividers well down from the duct/bore edge.
    This was done years ago on TZ piston port cylinders, but only on the A port by dropping the bore wall down 15mm in relation
    to the B port length that was left stock - it gave a good power increase.
    But with the reeds and Boyesen ports in the back I think the flow around the entry to the ducts is more important than the effect of the
    duct length.
    Something that would be easily tested back to back, but not easy to reverse.
  7. #23182
    20th June 2012 - 00:17
    yamaha
    duct length.
    This is something I plan on trying on my pjs cylinder for the vintage class jet ski.
  8. #23183
    yamaha
    On another point I have a cool old school vintage class Jetski pipe and cylinder I would like to ask wobbly and Frits some questions on. I can do it in pm but I thought since we are all talking two stroke it may be interesting in here. Would anyone be upset if I posted some pics up in this thread
  9. #23184
    if you have a local dyno test facility you could find any performance difference by using epoxy. different angles and sizes or close the hole completely could all be tried
  10. #23185
    2nd April 2012 - 00:54
    Interesting ? Frits, Jan, Wobbly your thoughts ?
    http://citsengine.com.au/
  11. #23186
    Its all good. Not everyone races Buckets. Love seeing what others are up to with their own projects. Sharing ideas and questions about your own work that all of us to learn from is great.
  12. #23187
    Not us, my efforts ended in failure but plenty of people report they have managed it successfully, its worth a go.
  13. #23188
    Safer to grind the old peg away. Mini cutoff wheel on a dremel and surgical care will nail it.
  14. #23189
    yamaha
    This is a 550 vintage engine for a Jetski.
    I have the rare twin dry pipes for the ski. These were the most powerful pipes they made god this engine, back in the day they had no ignition curve and simply ran a straight line. I have that fixed and am now running a zeeltronic ignition. They used to have a problem with seizing Pistons after a few laps if you even got that far. The engine should be pushing about 100-110 hp accordingly the data I have on them.
    My question is the stinger on the pipe is only 22mm which seems to be not much for what's basically two 275cc cylinders producing between 50-55 hp. Assuming that's what it makes. What's your thoughts please. Is it possible to put larger stingers on the pipes with out effecting the rest of the pipe to much.
    Thanks for your help.
ID:	323057   Click image for larger version.
ID:	323058   Click image for larger version.
ID:	323059   Click image for larger version.
  15. #23190
    Interesting ? Frits, Jan, Wobbly your thoughts ? http://citsengine.com.au/
    I had a pleasant exchange of thoughts with CITS-inventor Basil van Rooyen (picture) last year. I think I did comment on the CITS engine before, didn't I?
Name:	Basil van Rooyen + Twister.jpg
    The stinger on the pipe is only 22mm which seems to be not much for what's basically two 275cc cylinders producing between 50-55 hp...
    It's not only possible; it's essential if you want to keep the engine alive. You may loose some overrev but you'll save some pistons and cylinders.
    Here is that simple exhaust concept of mine once more (slightly revised). Amongst other things it will give you a guideline for the stinger diameter (D5 in the picture).
Name:	FOS exhaust concept.gif
    I just discovered https://www.hondarandd.jp
    Registration is required and you must agree to not spreading the available information, but it may be worth while.
There are currently 59 users browsing this thread. (0 members and 59 guests)
