Page 1549 of 2776 FirstFirst ... 54910491449149915391547154815491550155115591599164920492549 ... LastLast
Results 23,221 to 23,235 of 41626
  1. #23221
    19th December 2015 - 14:31
    2015 250XC KTM
    Hoppers Crossing
    Superkart gas gas
    The superkart gas gas engine was done by Manfred Wittenborn wiwa a gas gas racing Germany cylinder is 2 exhaust port . AKA rs125
  2. #23222
    26th April 2013 - 21:55
    BMW R1200R 2009
    Quote Originally Posted by Wizzer10 View Post
    The cases of the gasgas 250 came with a balancer till 1999. The enduro was equiped with a balancer, the MX was not. Those cases were the basis of the 300 that was used in the quad.
    For unknown reasons, from 1999 they abandoned the balander, made new cases where a retrofit of the balancer was no longer possible.
    When i was enquiring about the possibility of buying the old cases, the belgian importer of gasgas told me that the company no longer has any in stock. I was not very convinced by his explication so i contacted the french importer. He told me that gasgas made an exclusive deal with manfred wittenborn (www.wiwa-racing.de) that only he gets those cases so he can produce and sell the famous wiwa kart engine with balancer. It's a business deal... Is that a bad thing ? No, of course not. But 1 little detail one should take into account : the price for his 250 engine without carburator and without a pipe is 4.700 euro. The engine has another unique feature : it is the only mx based 250 engine that is truely square : 68 x 68
  3. #23223
    Unknown reasons, well I'll guess. I've owned 200 & 300 & ridden a couple of 250s and latest 300s. Certainly never noticed enough vibration to register whilst dirt riding. And I hate vibration. More weight, expense and parts to go wrong.
    Of course dirt riding is very different.
  4. #23224
    on the new ktm engine i 'think' the links frits posted said the crank and possibly the flywheel is lighter so the counterbalancer doesnt increase the overall engine weight. i havent seen if the balancer shaft rides directly on needle bearings or common ballbearings
  5. #23225
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    KX 500 Reeds
    Wobbly, my KX 500 Rebuild is almost finished and I am thinking about fitting VForce 2 Reeds. As i read what you said about Size and Flow Velocity, do you think it is better to fit a Reedcage made for a 250 or even 125 to make more Power? Or is it best to use the Cage made for the 500? Thanks
  6. #23226
    frits dont you think a dirtbike would be better off with zeroshift type of transmission? maybe faster laps and less gear wear
    Sure, and better still with a CVT. And not just dirtbikes but any vehicle.
    Peewee did you know that the seamless transmission used in Motogp cost over 500,000 Euros (each) and the primary shaft alone, has over 200 parts.
    That's likely more parts than some entire two stroke engines have.
    With the Hondas there is only one mechanic outside the factory that is even allowed to touch it.
  7. #23227
    Martin ,I cant give you any guidance on the reed suitability unless I can put all the data into EngMod along with the engine
    power capability to be able to do a valid comparison.
    The stock cage may be fine for flow, depends upon the power.
    But in general a VeeForce will make better power simply due to having way less tip lift for an equal curtain area.
  8. #23228
    Thuringia Germany
    Thanks Wob!
  9. #23229
    I didn't know the cost but at 500,000 I wonder how much the automotive version would be
  10. #23230
    mine must update automaticly somehow. now you can select teacup passages and bullnose at the sleeve/ inner wall. didn't notice this last time I used it
  11. #23231
    Hopefully a bit less.........
    I don't know once it gets to full production a lot less, but its a very complicated bit of kit compared to a CVT even a computer controlled one like a lot of cars have now (ie Mitsubish)
  12. #23232
    20th June 2012 - 00:17
    yamaha
    Where do you buy the best possible big end bearings, the engine I'm using is known for being hard on bearings I want to make sure I have the best I can get.
  13. #23233
    25th February 2014 - 01:31
    mostly GG 280 trials
    right HERE
    I usually use Samarin but INA/FAG seem to be very good as well. IKO has a online catalog but don΄t know where to buy
  14. #23234
    The manufacturers are all very good, you just need a modern " flat " cage and be sure that you have a set of selected rollers
    that are less than a micron different in diameter.
  15. #23235
    heres a list of the prox lower rod bearings with part# which are made by ntn and probly a few other manufacturers.
    16 x 22 x 13 13 pcs Copper / M-Cage 22.162213
    18 x 24 x 14 13 pcs Silver / M-Cage 22.182414
    18 x 24 x 15 15 pcs Silver / Flat Cage 22.182415F
    20 x 26 x 14 16 pcs Silver / Flat Cage 22.202614F
    20 x 26 x 15 14 pcs Silver / M-Cage 22.202615
    20 x 26 x 15 16 pcs Silver / Flat Cage 22.202615F
    20 x 27 x 14 12 pcs Silver / M-Cage 22.202714
    20 x 27 x 14 14 pcs Silver / Flat Cage 22.202714F
    22 x 28 x 16 14 pcs Silver / M-Cage 22.222816
    22 x 28 x 16 18 pcs Silver / Flat Cage 22.222816F
    22 x 29 x 14 16 pcs Silver / Flat Cage 22.222914F
    22 x 29 x 16 14 pcs Silver / M-Cage 22.222916
    22 x 29 x 16 15 pcs Silver / Flat Cage 22.222916F
    22 x 29 x 17 14 pcs Silver / M-Cage 22.222917
    22 x 29 x 17 16 pcs Silver / Flat Cage 22.222917F
    24 x 30 x 17 17 pcs Silver / M-Cage 22.243017
    24 x 30 x 17 19 pcs Silver / Flat Cage 22.243017F
    24 x 30 x 20 19 pcs Silver / Flat Cage 22.243020F
    24 x 31 x 16 - Silver / Flat Cage 22.243116F
    24 x 31 x 17 15 pcs Silver / M-Cage 22.243117
    24 x 31 x 17 16 pcs Silver / Flat Cage 22.243117F
    24 x 32 x 20 12 pcs Silver / M-Cage 22.243220
    24 x 32 x 20 16 pcs Silver / Flat Cage 22.243220F
    25 x 31 x 20 15 pcs Silver / M-Cage 22.253120
    25 x 32 x 16 17 pcs Silver / M-Cage 22.253216
    25 x 32 x 16 17 pcs Silver / Flat Cage 22.253216F
    25 x 32 x 16.5 17 pcs Silver / Flat Cage 22.253216.5F
    25 x 32 x 20 16 pcs Silver / M-Cage 22.253220
    26 x 33 x 18 16 pcs Silver / M-Cage 22.263318
    26 x 34 x 20 14 pcs Silver / M-Cage 22.263420
    26 x 35 x 20 14 pcs Silver / Flat Cage 22.263520F
    27 x 34 x 21 16 pcs Silver / M-Cage 22.273421
    28 x 35 x 18 17 pcs Silver / M-Cage 22.283518
    28 x 36 x 20 15 pcs Silver / M-Cage 22.283620
    30 x 38 x 16 17 pcs Silver / M-Cage 22.303816
    30 x 38 x 18 17 pcs Copper / M-Cage 22.303818C
    30 x 38 x 18 19 pcs Silver / Flat 22.303818F
    30 x 38 x 18 19 pcs Silver / Flat 22.303818F-1
    30 x 38 x 18 17 pcs Silver / M-Cage 22.303818S
    30 x 38 x 19 20 pcs Silver / Flat 22.303819F
    32 x 40 x 18 20 pcs Silver / Flat 22.324018F
    32 x 40 x 20 18 pcs Silver / M-Cage 22.324020
    32 x 40 x 20 20 pcs Silver / Flat Cage 22.324020F
    33 x 41 x 20 20 pcs Silver / Flat Cage 22.334120F
    34 x 42 x 20 21 pcs Silver / Flat Cage 22.344220F
    34 x 42 x 21 21 pcs Silver / Flat Cage 22.344221F
    34 x 43 x 20 16 pcs Silver / M-Cage 22.344320
    35 x 42 x 20 21 pcs Silver / Flat Cage 22.354220F
    35 x 43 x 22 19 pcs Silver / Flat-Cage 22.354322F
    36 x 45 x 23 20 pcs Silver / Flat-Cage 22.364523F
    37 x 45 x 22 22 pcs Copper / Flat-Cage 22.374522F
    38 x 50 x 23 17 pcs Silver / Flat Cage 22.385023F
    40 x 50 x 23 19 pcs Silver / Flat Cage 22.405023F
There are currently 12 users browsing this thread. (1 members and 11 guests)
  1. Mike Fisher
