Page 1550 .......
Limited rpms with HCCI. Now that adds a lot to this site's credibility, doesn't it Flettner?THE NAUTILUS CYCLE (HCI/HCCI)
Our unique patent pending design solves the inherent challenges of pre-ignition, poor cold starting, unbalanced combustion, uneven temperatures, limited RPMs...![]()
With all the people they employ, if only 4 of them had 1/4 of Flettner's ability and enthusiasm, they would have a whole range of working demonstrate-able engines for the world to see.
Sad, all that cad and no real engine to see..
Neil L
In some respects, the idea of the Nautilus piston entrant pre-chamber might be good for the HCCI process.
However, I do what wonder what clearance might be necessary between the piston projection and the hole in the head. This is a practical type question as there are so many design factors that would have to be considered in establishing this clearance: piston rocking, the thermal expansion of the projection, the max running temp of the piston projection and possible thermal deformation, the positional tolerance (ie its true concentricity wrt piston skirt) of the projection on the piston and the positional tolerance of the hole in the head (ie its true concentricity to the bore axis).
Frits, you’re good on this sort of stuff, what sort of clearance do you think necessary? Given it must achieve a claimed 2 to 3:1 pressure ratio above the major compression ratio. I know it is an open question as the rpm, engine capacity and probably the major compression ratio should be known.
Frits have you been on the Luxembourg Race event last weekend?
There was a 50ccm machine racing class.
While I was changing my jets there was a man greeting me, but I was concentrated on my work.
After finishing the Job I thought was it Frits? But could not find the person to clarify.
Regards Siggi
Has anyone experiences overhauling the Aprilia RS250 / Suzuki RGV crank? Mine needs a rebuild because of too much play at the right conrod.
I want to fit 110mm long TZ250 rods instead of the 105mm series.
1. Is it a good idea to convert the Crank to Washers at the low end? Is it even possible without milling of the crank web on the inside?
2. does anyone have a .dxf file of the base gasket?
Thanks for the flowers Ken, but I'm not that good. My instinctive reaction: the piston rocking won't allow the necessary clearance. Calculating the piston projection dimensions and volumes is easy enough, assuming there is no leakage. But there will be leakage and I haven't got a clue about its magnitude.
Anyone have piston dimensions for a nsr250r mc21?
Looking for wrist pin to timing edge of piston crown please. Thanks!
From model glow plug engine experience, a clearance of 0.02mm prevents them from running. They will run with 0.01mm clearance but lack any power.This is for ringless engines. Unless they are looking at the leaking gases from the small area getting super heated then starts combustion. But due to not seeing a working engine , after the Ryger affair, I'm now sceptical.
Neil
There are currently 99 users browsing this thread. (0 members and 99 guests)
