Page 1556 of 2775 FirstFirst ... 55610561456150615461554155515561557155815661606165620562556 ... LastLast
Results 23,326 to 23,340 of 41611
  1. #23326
    29th December 2011 - 04:14
    rd 350 ypvs 1985
    netherlands
    Glitches aside, if using 1.3 gives 'normal' outcome and 1.6 gives better outcome but real world says 1.3 should be better something is a miss right?
    Not that I know how and what, just saying, also not claiming that's an engmod issue!
    Engmod seems glitchy here and there, hope the next update adresses those instead of new features. Ccv I calcuated by measuring the total volume including transfers, then measure the volume of transfers and see if these where the same as calculated in engmod.
    Hope that helps somewhat, it's bin a while
  2. #23327
    All the 250s I have actually measured are mid to high 1.3 ratio.
    When you are watching the Ex pressure trace ( measured at the port face ) you will see the pressure ratio varying in value where it crosses
    the cursor at EPO.
    You will have superposition when the crossing point is above 0.
    The higher this value the higher the scavenging ratio at the port goes - a really good diffuser with the added superposition will go off the scale.
    Here is an example of good superposition and a really good diffuser acting together.
Name:	RGV100 Traces.JPG
  3. #23328
    I have absolutely no idea how one can measure the case volume without the transfers - please educate me.
    Engmod calculates the transfer volume from the port area, the inlet/exit ratio and the duct length, so this volume is
    entirely dependent on the input accuracy, especially the correct length ( as this is also a large part of the case, if you read the help files ).
    Running the code with a CCV of 1.6 is an insane input, so the result will be equally insane output - its not a sim issue at all.
  4. #23329
    See if someone knows the answer to this here.
    The MC21 is 45HP restricted by CDI timing curve. There is a well known wire splice mod, but it also has a gear position sensor.
    From my understanding, 1st gear is most agressive timing curve, 2nd slightly less agressive, and 3rd gear a decent curve for pump gas street use.
    My question, if you don't perform the wire splice mod, leave everything stock... are these bikes 60HP in 1st, 2nd, and 3rd gear.... but restricted to 45HP in 4th, 5th, and 6th?
  5. #23330
    I had major problems with the wire splice method when I first got the NSR300 going. We messed around for ages and could only ever get 60hp. Plug in HRC bypass loom and 72 straight away. I run an ignitech now. We never did an all gears run so could not tell you about 1st to 3rd sorry.
  6. #23331
    rd 350 ypvs 1985
    netherlands
    Oke, that will be true but then... I start at 1.3 and increase it and it keeps making more power. How do I know where the input starts being insane or, probably a better question, what am I not adjusting as well so the power doesn't go up anymore since that wouldn't be the case in real world?
    ps; more of a hypothetical question btw although I to have encountered this 'issue' in the past, never went to 1.6 though. Would have to dive in again to see how my model fares now, maybe a none issue but perhaps for broather understanding of things/ engmod.
  7. #23332
    6th February 2016 - 06:52
    ducati
    Thanks Wobbly again for the example above regarding the exhaust.
    My question was, why does engmod default the crankcase volume to exclude transfer port volume from the ratio, when we are using the transfer volume to do the calculation?
    I've just opened some of the other projects to verify. The radio button of, 'transfer volume excluded from ratio' is always selected. Should we be running the sim with, 'transfer volume included in ratio' instead?
  8. #23333
    Richban, are you talking about installing the complete HRC wiring loom that eliminates the lights?
    Or a type of inline small wiring setup that HRC made?
  9. #23334
    The code will always have the transfer duct volume available to it, as I pointed out you have to input the areas and length.
    But Neels must have been reading this thread and has just sent me an update to make the inputs clearer to everyone.
    I will install this tonight and report to him and you.
    Edit - OK Neels has changed the help file to make clear what is happening.
    In most cases you will simply be using the default ie a volume measured a TDC thru a hole in the piston and this of course includes the transfer ducts.
    He has made it clear now why we need other options, including the fact that if you change the transfers, this will then be updated automatically in the code as CCR ie Calculated Compression Ratio
    Regarding useful values of case vol.
    The Aprilia RV engine has it down at 1.24 or so ie a huge volume as would befit it huge power output.
    I have found that 1.3 is about the optimum top limit for a full house reed engines ie KZ kart 125, as with a bigger case you have to keep on installing thinner reed petals and eventually they hit the stops and go spastic
    or simply lift too far then flutter with no control.
    This I have absolutely dynoed to death on the TM KZ10B kart engine, as a small change in case vol under 1.3 looses mid power, and a small change above 1.3 with a reed spacer looses
    all the overev power - no matter what reed stiffness is used in each case..
    Engines with crap transfer ducts need the ratio up closer to 1.4, and I have never seen anything go at all well with a case smaller than 1.4 ( by smaller I mean volume ie say 1.45 ).
    But as always remember that the code can only recognize crap ducts in a limited fashion ie the input you have control over in specifying the shape.
    Re MC21 and its ignition control.
    There are two parts to the Honda ignition control.
    First is the blanket retard function that is easily disabled with the wire splice method.
    But secondly there is a function that limits the road speed to 180Km/Hr max in 4th,5th,6th.
    This can be disabled by fooling the ECU into thinking it never goes past 3rd gear.
    As to the curve in 1st gear being the most aggressive, this is a possibility, but I have never seen any evidence that the PGM software has the ability to store
    more than 2 curves.
    So it makes sense that 1, 2, 3 are the same and 4.5.6 are the same.
    Reworking the gear detector so it never tells the ECU 4th is selected would keep the more aggressive curve active.
    I only say more aggressive in that as the rpm rate of change is so much faster in the 3 lower gears, Honda would be logically happy to wind in alot more advance without
    fear of meltdown on shit fuel and or long periods of WOT.
  10. #23335
    the cursor at EPO.
    Hey Wob, the minor pressure fluctuations (of around 40 to 45 deg) in the transfer port after TPC, are they real as a result of resonance within the passage or some reed tip frazzle OR some EngMod calculation perturbation? The pipe is doing a good job, well to me anyway.
  11. #23336
    Hey Ken, I have always thought that the sine wave fluctuations in the transfer ducts after TPC were a result of them being converted from an open pipe ( ie the duct open at both ends )
    into a stopped organ resonator ie one end only open.
    The pipe in the example I gave was well past its designed peak, as the max pipe/port depression is well past BDC, but the superposition of the scavenging effect is so strong it easily overcomes this
    natural movement of the peak depression moving rightward ( too late ) with rpm.
  12. #23337
    Hey fellas,
    http://www.grampianmotors.co.uk/
    This is a neat site in that if you, say, go to MITAKA, click on road bike rod kits, then your bike & model and up comes the rod crs, widths, diameters etc. Ditto with pistons. Good if you're chasing bits to swap around between motors.
  13. #23338
    Hey fellas,
    http://www.kiwibiker.co.nz/forums/sh...post1130987881
    You can keep Russell Crowe but we want Far Lap back.
  14. #23339
    ducati
    Wobbly, thanks for the update, and thanks for the detailed results and explanations.
    And Neels, thanks for the update as well, and sorry for not going directly to you before stirring the pot here on the forum. It all makes sense now.
  15. #23340
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Please feel free to ask anything you like on this forum - there are enough experts to help you and it shows me where to improve!
