Page 1558 of 2774 FirstFirst ... 55810581458150815481556155715581559156015681608165820582558 ... LastLast
Results 23,356 to 23,370 of 41610
  1. #23356
    About HCCI ignition(i think)
    I have built a new engine(not fully complete yet)
    Test started it this weekend.
    It´s an Kawasaki KX250 downstroked to 211.9cc(due to regulations in swedish dragracing)
    However, i was so eager to hear the engine spin even though the pipe isn´t ready yet.
    So i started it anyway.
    And note, the exhaustvalves wasn´t in place, the guillotine therefor left a big hole downwards in exhaustport(no lid on either)
    Engine started nicely but started to rev out of control almost directly.
    Tried to stop it, pulled the cord to the stop button, nothing happened.
    Placed hand onto the carburetor, nothing happened.
    With hand still on carb and full throttle engine lowered the speed.
    Had to shut off fuel to get it to stop.
    Later, put back all exhaustports and started engine with no other adjustment.
    It ran nicely on idle.
    Quite interesting experiance
    I figure the exhaustpulses drew fresh air into cylinder through guillotineport.
    And even though i had hand on carb it still drew fuel enough to get a burnable mixture.
    But, interesting is that what i think it almost directly triggered HCCI.
    Rgds.
    No doubt true, as I had a similar problem with my HCCI mudbug (100cc yamaha), hand over the inlet didn't stop it. It was getting air in again each cycle via the exhaust port. I also had no exhaust system attached, interesting isn't it.
    In my case I didn't even have an electrical ignition to try to turn off. It certainly gets the heart rate up! See what happens when you dick around doing dumb stuff, you learn dumb shit:
    All you need is a bit of HCCI control
    https://youtu.be/9zhFsS_ocuQ
    https://youtu.be/VBVMGywXVr8
    https://youtu.be/OCBngYfWiTE
    I guess this is a free piston engine, that last one certainly has some grunt.
  2. #23357
    Decompression valve should sort it out. Probably a bit abrupt but. . .
  3. #23358
    27th January 2011 - 11:30
    asdasd
    AKL
    Piston crown and combustion chamber deposits
    What should the deposits look like on the piston and head for a well functioning race 2 stroke?
    Just changed the ring on the Derbi 50 and repacked the muffler so I shot a few photos:
ID:	323800Click image for larger version.
  4. #23359
    You might want to check the squish gap fore and aft.
  5. #23360
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    With the earth strap not quite burned half way and the fair amount of wash around the edges of the piston I would say a touch rich but not bad at all.
    . . . That shit's Nasty.
  6. #23361
    asdasd
    AKL
    Was thinking that but wasn't sure if it was impacted by being the exhaust side. Will do.
  7. #23362
    13th September 2012 - 07:48
    1991 NSR300
    In a house
    I had major problems with the wire splice method when I first got the NSR300 going. We messed around for ages and could only ever get 60hp. Plug in HRC bypass loom and 72 straight away. I run an ignitech now. We never did an all gears run so could not tell you about 1st to 3rd sorry.
    That's the way I understand it too
  8. #23363
    1991 NSR300
    In a house
    Richban, are you talking about installing the complete HRC wiring loom that eliminates the lights?
    Or a type of inline small wiring setup that HRC made?
    You could buy a hrc wire splice in a adaptor loom and just plug it in to get full power , the gear position splice is a different mod
  9. #23364
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    The head needs to be dowel located to the bore. That is why the squish won't be even. Dave and I machined that head profile just before heading to Tokoroa and ran out of time to dowel her up.
  10. #23365
    Two outer bolts Ithink bored for dowels. We did squish test with solder front and rear at same time held with plasticine or grease. Should be 0.5.
  11. #23366
    Does anyone know if the stock MC21 chambers have internal stingers?
  12. #23367
    Using a " normal " earth strap to read the chamber conditions is not accurate at all due to its very high thermal mass .
    Fine wire electrodes give a very good indication of the combination of advance and jetting leannes.
    Having the burn mark change about 2/3 of the way toward the body is spot on.
    At 1/2 distance you can look at winding in some more advance if the egt is at optimum power.
    Usually the rear of the pistons squish ( over the boost port ) will mark up more due to heat as when the piston rocks over TDC
    this side closes the squish gap up, increasing the MSV and the retained heat in the end gases..
    Here is a KZ10 that has a straight line ignition, tuned right to the edge after a 25 lap final, any more advance and the piston would be starting to deto.
    The other is a 66mm piston in a RZ400 that has done 480Km racing miles, one piston is jetted slightly richer,but the squish gap is perfect.
Name:	480Km Pistons.JPG
ID:	323819   Click image for larger version.
Name:	Piston Crown.jpg
  13. #23368
    asdasd
    AKL
    Thanks Wob. From reading on here and a few other places that's how I've understood it too. Good to have confirmation.
    The main thing for me and this bike at the moment is reliability, suspension and gearing. I won't be doing any engine development until I have some of my own baselines so it's good to know it's probably on the safer/lower power side. It shouldn't be giving me any issues whilst I sort out the meat sack on the thing. It's getting a rev counter, temp gauge and maybe an EGT, at the moment it has none of them. Whilst it might not mean an decrease in times, it'll teach me loads about set up that I can take to my 125.
  14. #23369
    PS, if the jetting and ignition are perfect with a correctly set squish and you keep on getting a hot spot in front of the exhaust, then most likely
    the stinger is too small and or there is insufficient cooling of the Exhaust duct.
    I cured this in the KZ10 engines by allowing water thru slots right up to, and into the back of the bolt on flange spigot.
Name:	KZ10 Cooling.JPG
  15. #23370
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Venturi flow meter for exhaust port. correction calculation blowdown sta
    => http://www.torqsoft.net/exhaust-time-flowarea.html
