Page 157 of 2773 FirstFirst ... 571071471551561571581591672072576571157 ... LastLast
Results 2,341 to 2,355 of 41593
  1. #2341
    Checking out the ground clearance on Chambers FZR-GP100. With the springs removed and the suspension completely compressed the tip of the foot pegs just touched at 40 degrees, would have liked it to be 45, but every thing else like chamber and gear/brake levers have much further to go, so no clearance problems there.
ID:	208850   Click image for larger version.
Name:	40 Degrees.jpg
  2. #2342
    So cut the footpegs down, they are touring models currently.
    Just use the std RG barrel but weld a plate to it & make a curve, that's what mine is.
  3. #2343
    Thanks, good idea's........
  4. #2344
  5. #2345
    We need to make ourselves a dyno..........
  6. #2346
    OK TeeZee enough with the plenum chamber........plenty of turbos lying around the workshop.........a Jet Bucket is the way to go.
  7. #2347
    16th November 2005 - 07:48
    I just lost count
    The District of Waipa
    This has been discussed several times. At the rate ESE develop stuff we should see it in about 2015.
    Pumba is a wise man.
  8. #2348
    This has been discussed several times. At the rate ESE develop stuff we should see it in about 2035.
    fixed
    by the way thats when the grandkids will be getting into it with gusto
  9. #2349
    Finished by 2035, why whats the rush?????...........
  10. #2350
    Grandkids remember
  11. #2351
    I just lost count
    Grandkids remember
    What yours Karl
  12. #2352
    In building a Dyno, we found one of the harder design problems to overcome is the task of reading the RPM from the ignition spark plug lead and this held us up for a while.
    The problem is that the ignition output varies with engine load and its amplitude is basically all over the place, with a lot of ringing and electrical noise. So there needs to be a way to get a clean signal with a consistent amplitude and shape that can be read by a computer easily.
    SportsDevices show how this can be done with a 555 timer:-
    http://www.sportdevices.com/rpm_readings/index.htm
    JayCar sell a (Neon Tube Sound Display) kit, KC5221 with a LM555 timer that can be modified fairly easily. Unfortunately the kit can only be brought online from their “Kit Back Catalog”:- http://www.jaycar.co.nz/productResul...=21&SUBMIT.y=5
    The spark rate at 12,000 RPM for a single cylinder one spark per rev., 2-Stroke is equivalent to 200Hz, or 200 sparks per second. So the on and off time or width of the output pulse from the LM555 at 12,000 RPM should probably be a 50% duty cycle, 1/400 or 0.0025 mSec so as to get a nice consistent square wave that can be easily recognized by the computers software.
    Go here, or check out Pic-04 for calculating the resistor and capacitor needed for “on” time or width of the output pulse.
    LM555 Monostable Oscillator Circuit Diagram and Timing Calculator http://home.cogeco.ca/~rpaisley4/LM555.html#3
    Pic-01 JayCars KC5221 Kit.
    Pic-02 SportsDevices circuit.
    Pic-03 a LM555 monostable oscillator circuit.
    Pic-04 LM555 timing values.
Name:	KC-5332 Neon Tube Display Kit.jpg
ID:	209338   Click image for larger version.
Name:	inductive sensing.gif
ID:	209337   Click image for larger version.
ID:	209339   Click image for larger version.
  13. #2353
    31st July 2005 - 11:15
    a shed full of crazy shit
    why not one of these http://www.trademe.co.nz/Browse/List...x?id=293504620
    or put a break out lead on your timing light cables (it would produce a voltage spike every spark; which could be easily turned into a frequency; then connected into your computer parallel port.
    one would need to make sure you don't put more than 5v up the port (easy fix with a few resisters)...
    http://www.epanorama.net/circuits/pa...put.html#input
    provides some insight (and code snips), but some quality time spent googling will un-earth what you require to fully build up the required code.
    or look for a USB interface option http://www.usbee.com/freqc.html
    most simple data loggers would sort out this for you (including the maths) and you could log other parameters like temp etc....
  14. #2354
    29th September 2003 - 20:48
    2008 DRZ400E & 1983 CB152T
    Alexandra
    If you are using an ignitech you can just hook up to the tacho output i would have thought?
  15. #2355
    Hi Bert, lots of interesting reading there, thanks, we want to build a dyno that any small bike can use, so the rpm pickup has to be universal.
    k14, I had forgotten about using the tacho output, but that is a good idea. Earlier last year I had downloaded some software that read a tape recording of the ignition and produced a dyno graph, it worked on the inertia principal much like an inertia dyno does. The problem was getting a good recording, but with the taco output it should be much easier if I need to go there again.
