Pipe temp should be 325 at the bottom of the powerband and 425 at peak power.
What are the STA values for the rotary valve using the figures you entered.
142 and 82 are very early timings for anything making good power.
Using 95 or 98 pump gas the pipe temp is close to Avgas.
But 91 makes more power with a richer mixture and more advance - and hates compression.
Back at 142 it will be a bitch to carb properly, i would start at 135 and close it where you need to to get the top end you are after.
Of course it depends on how much mid you can afford to loose - but 90* is very late and suitable for very high end applications.
Breakfast of Champions
Av ... https://www.facebook.com/avalonbiddleracing
The sim blowdown shows 18.5 crank,so this means around 15.5 rear wheel on a Dynojet - if everything is done real well.
Add in another 10% loss for the belt drive and now you have 14 Hp.
You're right about that! I want to establish a baseline before I start grinding further - be able to quantify how bad I screw up...
Maybe I'm not that far off then.
I'll see if I can touch 14 on the roller, then add some blowdown and a better pipe!
Hi wob and everyone!
I have a general question on the exhaust temperatures. Are they a depending on the cc of the engine?
I worked on a 50cc engine with engmod and the estimated peak of the simulation was at least 2000 RPM higher than in real life. In fact, i needed to make the temperature on the exhaust unphysically low (150°C) to get the rpm range to suit the reality.
I would suggest the temperature to be a formula of the cubic capacity, bmep and blowdown (more blowdown meaning less backflow to the transfers, thus the first gas scavenged and lost through the exhaust will be way cooler than with less blowdown)
cheers from germany
Christoph
Maybe mixture on its way out of the crankcase was colliding with mixture on its way in, and this caused higher than atmospheric pressure in the carb, blowing fuel ut of the bowl.
No fuel spilling below 11-12k.
You might also recall that I had a hell of a time getting it to start at all before I found the carb "sweet spot".
Interesting.
In my experience the only thing that really affects the pipe av temp is specifically what egt in the header creates max power.
This is tied directly to the bsfc number and this is affected by the fuels octane,and thus indirectly the burn speed,along with the fuels energy content.
Fuel such as 91 pump or some race fuels ( such as the unleaded that replaced that used in the 2T GP classes ) makes best power when running well under stochiometric.
Thus when run rich with a ton of ignition timing, and reduced compression, the egt in the header is typically in the high 500*C/low 600*C range.
Whereas Avgas and real leaded racegas such as 110 octane loves compression, and responds well to lean mixtures and lots of retard to increase pipe heat.
These engines run in the high 600*C range in the header.
95/98 pump gas is similar to Avgas but cannot tolerate as much com, so the egt rises, close to that Avgas would show with higher com.
Thus most sims work well with the 325/425 wall temp range, but this needs modification where an out of range combination of fueling/com/timing is used.
Rotary valves create havoc in the carb bore over the emulsion tube exit , even with " normal " timings.
Have completely weird arse numbers,even going back to 142* makes everything so unpredicatable its impossible to sim it properly let alone tune the carb effectively.
That would be extreme indeed, Adegnes. The disc does not run without friction; it has to be taken along by the crankshaft. And if there is any play, it will lag behind, opening 30° later instead of 30° earlier, but also closing 30° later than the 83° aTDC that you mentioned on the previous page. Now that will really upset the carburation.
There are currently 40 users browsing this thread. (1 members and 39 guests)
