Page 1580 of 2776 FirstFirst ... 58010801480153015701578157915801581158215901630168020802580 ... LastLast
Results 23,686 to 23,700 of 41631
  1. #23686
    Page 1580 links list to go here ......
Name:	Bore-Transfer Radius.jpg
    One small detail everyone seems to forget.
    Quote Originally Posted by fpayart View Post
    Hello,
    You will find hereafter some informations about THE Rotax 256.
    The valve diameter is 124 mm
    There is two kind of valve: Cutaway opening 162 ° or 170 °
    Road Racer inlet opens 136 BTDC / closes 85 ATDC and Kart inlet opens 136 BTDC / closes 80 ATDC
Name:	Valve ROTAX.pdf
Name:	Carter admission.pdf
    Regards.
    Francis.
    Could and/or would someone please tell me how the wall temps are used in the EngMod2T simulator?
    http://www.kiwibiker.co.nz/forums/album.php?albumid=5056
    The wall temp is an average over the pipe length, and sets what wave speed is used by the sim for each calculation step. It also sets the energy loss from the gas to ambient air.
    For tuned engines 125 to 350 cylinder size with fat pipes I have found 325 at the bottom of the power band and 425 at peak is very accurate.
    This was found empirically,by experiment, and checked along several pipe lengths on a Dynojet with varying air speed over the bike front using a laser gun.
    I don't know about smaller engines that would have a proportionally larger pipe wall area/displacement coefficient.
    The real deal, a performance 2T Two Stroke successfully running an electronic fuel injection system.
    E85 at work
    Kawasaki F86M BigHorn 350cc Air Cooled, E85 and Fuel Injected .......
    Attachment 325137
    Here is the EFI at work.
    Attachment 325138
    F86M dyno graph.
  2. #23687
    With a pumper if you have over run richness, then the pop-off is too low and or the lever height is too high.
  3. #23688
    Quote Originally Posted by DaisyB View Post
    Could you explain how to do this on the pumper carbs? Having a fun time trying to dial out the over-run richness - at least it's on a combo, so when it does clear and spin the rear wheel we don't fall off!
    (Later)Edit here it is it is on the Net. I peiced it together, the stuff with the overrun.
    Wob might have some other solutions.
    This one only deals with overun continued pumping on McCollouch carbs
    Click on it 3 times
Name:	Pumper carb mods Jennings Son of a secret weapon.jpg
    Actually the whole series is worth a read.
    Jennings
    Basically, the problem there was that every time I closed the throttle the crankcases filled with gasoline, and there was a long pause after reopening the throttle before anything happened. And then the engine would catch and make a mighty lunge—which always seemed bent on carrying the motorcycle right off the track.
    I cured the carburettor flooding by following John Brooks’ suggestions and drilling a.037-inch hole to connect the metering pressure feed from the crankcase to the carburettor throat behind the throttle butterfly. This uses the vacuum behind the throttle to damp out crankcase pulses that would otherwise maintain pressure under the metering diaphragm and keeps fuel dribbling out of the main nozzle at idle. I also plugged the idle mixture hold behind the butterfly—which meant that the engine wouldn’t idle—but that isn’t of any great importance in racing. The similar mixture hole just in front of the butterfly I left open, as it is needed to feed the engine at low throttle openings.
    A tuning session at our local drag strip showed that the revised carburettors were an improvement, having much better throttle response and no tendency to flood when the throttles were closed. We also found that the mixture curve was wrong and was going a bit lean above 9000 rpm. To counter it with the McCulloch carburettor, you enlarge the main vent that bleeds under the metering diaphragm. Once done, you must also open the adjustable main jet a tad, but it does lift the top end of the mixture curve. I can’t tell you how much larger you should drill the vent. I overdid it on the first try, and then had to open the pressure feed hole into the chamber to compensate-which I also overdid—and was forced to drill the vent even larger. Anyone else going through the same process should first obtain all available small-numbered and lettered drills and proceed with great caution. The difference in mixture, with a very small change in air-orifice diameter, is surprisingly large. By the time I had learned this lesson, all of the drillings in my carburettors were too large, and although they were working fairly well, a less drastic series of passes with a drill would have been better, I am sure. Sometimes there is more learned in failure than in success. With my Bridgestone 350GTR racer project (a racing failure if ever there was one) I learned several things: that a conventional battery/coil ignition system is inadequate to the needs of a racing two-stroke engine—Which should be fed oil in a proportion of about 1:12 with its gas; and that the McCulloch carburettor does offer significant advantages in this kind of application, but that it is necessary to do a great deal of work with its fuel delivery system, and even more work with the metering system’s air bleeds. These carburettors work exceedingly Well in the low and mid-speed ranges, but have an inherent tendency to go lean at maximum rev’s and this must be compensated. I have not yet succeeded in this; the modifications made have improved things, but the mixture is still slightly over-rich at 6000 rpm (and downright sooty below that speed) while a shade lean up at 9000 and above.
    http://www.bridgestonemotorcycle.com...cretWeapon.pdf
    Part 2 to be added later
    http://www.eurospares.com/graphics/B...eaponPart3.pdf
    Plus another period one for giggles
    http://www.eurospares.com/graphics/B...ne350Racer.pdf
    Special Thanks to Michael Moore
  4. #23689
    You cant show a piston with a pin plug and not have me ask what, where, who, how much.
    This^ !!!!!!!
    The picture shows a 2011 APF piston, main transfer mold and piston pin. The pin is closed, although there is still a little room for bypass flow. Seems like this kind of pin was found to be "good enough" at some stage. The pin should be available from service aprilia, I do not know the price.
    But for sure it would be nice doing a head to head comparison with a hollow pin on a kart engine.
    Edit: spinotto is italian for piston pin
  5. #23690
    18th March 2013 - 08:20
    Suzuki GT500 1976
    United Kingdom
    Thanks Wob, will try that, back on the dyno in a couple of weeks.
    Thanks Husaberg, will read it all!
  6. #23691
    19th June 2011 - 00:29
  7. #23692
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    exhaust wall temps
    Could and/or would someone please tell me how the wall temps are used in the simulator? I was asked this when I tried to order a pipe wall surface sensor for the data collector I'm using. I could not answer him.
    http://www.kiwibiker.co.nz/forums/al...p?albumid=5056
  8. #23693
    is very accurate.
    using a laser gun.
    I dont know about smaller engines that would have a proportionally larger pipe wall area/displacement coefficient.
  9. #23694
    what material do you guys use for the gasket between cylinder and exh manifold ? i need to make that gasket . thought of buying a automobile header gasket then cut it to suit but maybe theres something easier
  10. #23695
    My RG400 cylinder had a deep recess with a wide flat for the header to sit on. Right or wrong I used high temp silicone to seal it. Being a race bike that joint was always being pulled apart and I never noticed the silicon failing.
Name:	TZR100 ud forks0004.jpg
ID:	324894   Click image for larger version.
  11. #23696
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    Question about Rotax 256 twin or 128 single, does anyone know what was the rotary valve diameter and the "width" in degrees of the window in case? Thanks.
  12. #23697
    is very accurate.
    using a laser gun.
    I plan to run my 50 on the roller again tomorrow, hopefully with the carburetion sorted. I'll take some pipe wall temp measurements and post them.
  13. #23698
    I can answer tonight finding a pristine inlet port is a bit difficult these days Recommended Rotax timing is 138/88
    As yet I don't know why anyone would spend double the price of a TM KZ10C on a Ryger engine for half the performance
  14. #23699
    I have a feeling its in the bell book or maybe it was the 124? one of the ones were anyway.
    You should be able to get pretty close by looking at the parts Fiche for the oring size.
  15. #23700
    13th March 2015 - 07:20
    1987 SUZUKI 500RG
    France
    Hello,
    There is two kind of valve: Opening 162 ° or 170 °
    Regards.
    Francis.
