Francis Thank You very much, 2nd picture is exactly what I was looking for.
Merci Francis I must have some untouched cases 34 high x 40 wide.
Can you tell us what happened with the Aprilia RS 125/FPE project?
https://www.youtube.com/watch?v=feFhdLe7oNI
Hi Frits, Jan, Wobbly and everyone :-)
I got a question regarding discharge values:
Has anyone determined the cd values of exhaust ports? Similar like it was done to the QUB SAE-Paper
2003-32-0029.
Nevermind if CFD simulated or measured (and re calculated) on a flow bench.
If I remember correcty: Frits, you made the exhaust port of the F2 with an automatic cd-value controled CFD tool?!
@Jan, was CFD used to design the exhaust port of the RSA? I remember that I have read it was done with a flowbench?
Cheers and thanks
Chris
What is an F2?
You remembered it right; I did not remember it at all because it was 14 years ago but it has come back now. It was the Profi F2A. And I did not design that engine; I only did some ducting and piping for it, using a home-brewn CFD program. The F3D was the engine I did some more work on.
Re your question about the Cd values of exhaust ports: that would not be just a number, but a whole list per port with a CD-value for each crank degree.
I never tought my program to put out such a list; what I needed was mass flow behaviour and a points cloud describing the duct geometry.
Below you see the points cloud, the corresponding 3D-solid and the copper electrodes used to spark-erode the exhaust duct in the prototype F3D engine.
Jan did flow tests stepping through the piston positions, using the contraption shown below.
wobbly;
Thank you very much for the info on wall temps. Where on the pipe would be the best place to mount a single sensor or do you have to monitor different places and where would they be and how many? My data collector only has 4 temperature outputs. I am using one for egt, one for water temp, and one for cht leaving one more.
adegnes:
I'm looking forward to seeing your temp readings. Thanks
I'm afraid you'll have to wait a bit longer for my numbers.
On the dyno the translucent float bowl revealed massive fuel foaming throughout the powerband, nothing but foam in the bowl.
Is vibration the only probable cause for this? I mean it's not that bad, I've experienced far worse without this foaming issue.
I also tried the added weight, the brace, and holding it with my hand again, now with the clear bowl, made no difference.
Running 98pump with 5% a747
What you are after is the average temp of the pipe wall material.
You would need to measure the hottest ( at the header ) then the coldest ( in the mid ) - then it gets hotter again as you travel down the rear cone.
Problem is that there is far more area of cold surface in the middle, so sadly some fudge factor guesstimating is needed.
Re the foaming fuel bowl, as I said before the crank balance is wrong for this to even begin to happen at all.
Fuel tank anti surge foam would help in the bowl, but you need to fix the actual issue.
It sounds like some part of the out of balance force is combining with the 2x crank speed secondary vibration modes.
Again thank you wobbly for the temp information. I suppose I could do with out the water temp sensor and run two surface temp sensors. I'll try it.
Thank you! But...
I did measure the balance factor earlier(following TZ's instructions), and raised it from below 25% to 38% - the highest I can get it without mallory slugs.
What I need to learn more about is the vibration modes, are we talking about torsional vibration here?
You dont need to read anything, read my lips "if the cylinder is near vertical then you need a balance factor closer to 60% ".
What im saying is that your engine is currently so far wrong, of course it will froth the bowl, buzz your balls,and make your eyes drop out.
Any vertical single balanced to 40% is a complete waste of your time running it at all.
Low inertia of the crank/variator and no flywheel makes the situation WORSE, due to lack of mass damping.
Just buy the Mallory and get on with it - believe the people that have been there, done it, collected the $100 and didnt go to jail.
I recently tested a single kart engine on my dyno that was balanced at exactly 40%, it was impossible for me to hold the dyno throttle lever as it
hurt so much,it broke off the CHT/EGT leads, wreaked the dyno's digital speed pickup, and funnily enough - fuel spewed constantly from the overflows.
That engine wasn't considered seriously at all to be a replacement for our junior kart classes.
There are currently 198 users browsing this thread. (0 members and 198 guests)
