Page 159 of 2773 FirstFirst ... 591091491571581591601611692092596591159 ... LastLast
Results 2,371 to 2,385 of 41592
  1. #2371
    10th December 2008 - 07:39
    07 fz6n. 07cbarrrr600
    STRAYA
    My own 50 is coming along, I have got all the cables, chain and ignition sorted now.
    The side cover is cut away over the ignition stator so the timing can be easily adjusted on the dyno, the cover will be replaced when the engine is dialled in.
    Next job is to cut the new squish and CC the head, aiming for 3cc or 8.5:1 corrected compression ratio.
    Why on earth have you got that fixture so far out of the chuck ?
  2. #2372
    Chambers runs his 22.5 rwhp GP100 at 8:1, I was skeptical but it seems to have worked out OK for him.
    Looks like CV of 3.25cc for a compression ratio of 8:1 and 16:1 uncorrected...........
    The changes in volume are so small the clearance inside the plug and variations in the squish volume will have a significant effect.........I will have to take my time getting this right.
  3. #2373
    Yep its not a good look, the fixture was made for air cooled GP cylinder heads and a bigger lathe, the shank is to large to fit inside the smaller chuck on our lathe. There is a smaller fixture but I couldn't find it today.
  4. #2374
    STRAYA
    Yep its not a good look, the fixture was made for air cooled GP cylinder heads and a bigger lathe, the shank is to large to fit inside the smaller head stock of our lathe. There is a smaller fixture but I couldn't find it today.
    You can't just cut that one in half or turn the shank down ?
  5. #2375
    Turn the shank down, that's possible, cut in half, no, its been made with a draw bolt through it and has other uses, I will search out the correct one tomorrow when the team is back at work.
  6. #2376
    or use a Dremal
  7. #2377
    Yeah you will need to measure comm 3 times to make sure you have your procedure down pat & can believe the results, it changes super quick the smaller you go. RG heads also tend to 'cone' a little so I used to lap the head with a flat oilstone every so often. When I remeasured it a few years later it had shot up 2 points in com!
  8. #2378
    A bit of real bucket racing...........................
    And more from the Hill.
    If I had a personal list of top ten riders, Fish would be right up there..........
  9. #2379
    16th November 2005 - 07:48
    I just lost count
    The District of Waipa
    WTF who the hell put this thread in PD. FFS I thought the bucket forum escaped al the BS the rest of the site was subject to. Looks like I was wrong
    Pumba is a wise man.
  10. #2380
    23rd January 2004 - 12:00
    ninja 250
    I dont know who moved it mate, but Ive moved it back again. Its one of the best threads on KB
  11. #2381
    Thanks Gav.
    I think the boys had been getting a little silly on another thread and someone gave them all time out in the naughty room.
  12. #2382
    ninja 250
    Thanks Gav.
    Yep, thats seems to be what has happened , just try and clean it a bit clean and we should be fine, hehehe
  13. #2383
    Spy photo from secret engine development centre
    Just leaked Joe2
    aiming for 28rwhp
ID:	210381   Click image for larger version.
  14. #2384
    Oh my God....suddenly we are feeling very behind the times with our air cooled engines...........good looking effort, like Jasonu's, much impressed.
  15. #2385
    tnat's the only engine combination that is as good or better than an MB100 with 6 speed. The box on the 125 is near perfect. The clutch needs a bit of work and the stock rods need to be changed but otherwise very very nice. 28hp is going to be a test of the clutch
