Page 1592 of 2774 FirstFirst ... 59210921492154215821590159115921593159416021642169220922592 ... LastLast
Results 23,866 to 23,880 of 41610
  1. #23866
    SEAL FRICTION TEST RESULTS ARE NOW IN !!!!!!!!!!
    At atmospheric pressure, the twin seal set up required 138 gm on Ø40.6 = 0.0275 Nm. The power required to overcome this friction at 14k rpm = 0.0403 kW. Remember this is for 2 seals. Note slightly less friction than before, mainly I think due to the better finished shaft surface.
    A couple of points:
    1. This is a quasi-static result and maybe things might change with running at actual speed. This could be tested with running the shaft between two bearings and two seal packs on the shaft. One would be used to measure the torque and the other used to apply pressure to the test piece, a passage interconnecting the two cavities inside the seal packs. See sketch below.
    2. As Frits correctly pointed out, there is a radial force imposed on the seals, equal to the measured force. However, I feel that this force is relatively small in relation to the seeming stiffness of the seal moulding. Notwithstanding, this could be overcome using the method shown in the sketch.
    3. Larry W suggested the effects of lower than atmosphere and we could do this, but content with the results.
    Now, I’m sure that most won’t believe the results, but we did it quite a few times. I expected differently as well. So, if you are still sceptical, feel free to drop in this Friday arvo and have a play yourself. We’ll provide the beer, single malt whatever, E85 or even Marsala ice cream.
    Oh, the results you might ask. The friction at 8 psi was exactly the same as at atmospheric. No change. Bugger, we had a really neat labyrinth set up designed for KZs.
    Back to the Slider engine.
  2. #23867
    A couple of points:
    Ken hook engine crankshaft crankcase assembly to lathe,run at speed measure current draw.
    Repeat with telfon seals
    Then totally remove seals and repeat test (i think you will be surprised)
    The Old style spring gater seals used in pommy shitters were HP killers, modern ones i would expect would be far better.
  3. #23868
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    I won, I won, well I was closest, I claim the prize of 'nothing' from Australia
    Ken, is there any leakage at 8 psi?
  4. #23869
    So the friction created by the backup radial spring on the seal lip far outweighs that of the case pressure - man that
    is so counter intuitive, just like most things in a 2T.
    Re Harolds work on the Yamaha.
    He was the team boss for them in 125 with Ui, and he had ( sorry, he told me he had ) done a huge amount of work on a Jante developing a cylinder
    that bolted straight onto the TZ125 that already had over 50 Hp.
    This made me super depressed at the time ,as the cylinder we had done for the BSL500, made 55Hp ( 166cc ) at 12,000 so I thought I was well off the pace bmep wise.
    Yamaha wouldnt let him use it on the team bike ( that was very slow ) but looking at the nicely made cylinder it appeared just like a RS125, except it had
    the oval to round transition header off the 250 factory bikes.
    As it later transpired the thing had nowhere near 50 Hp when it was tested on the Derby dyno, so his boasting to me ( and Derby obviously ) was largely bullshit.
    This became obvious to me when we sent a 3D printed plastic cylinder to him to test/modify on the Jante - and we never saw a result, let alone any more power.
    Much of his cylinder " design " work then went to KTM 250, as did the so called A Kit Honda pipe design.
    That engine was in my opinion very well conceived as a symetric parallel twin ,firing at 90* with a balance shaft, but as with Derby, the cylinder and pipe were the Achilles heel
    in that Jan at the same time had made huge steps forward, initially with Harolds Derby reed, and then with the Aprilia.
  5. #23870
    Thumbs up for performing the tests!
    200% from me, go high or go home!
    Crap, I knew I should have gone home...
    Nothing in it for a crowd of seasoned bucketeers I guess, but you could watch it for a laugh!
  6. #23871
    So 2 standard crankshaft seals rob .054hp
  7. #23872
    On your advice Adegnes, Im into a Friday night rum session.Only 1/2 way so far but feeling pretty good at this point.
  8. #23873
  9. #23874
    con rod shape
    so , between the small end of a 2t conrod and the big end , conrods have a familiar shape.. would anybody in the know tell me why its shaped like this? is there any reason why this is?
  10. #23875
    The norm is a non symmetric H section and this deals with the max stress concentrations of compression/elongation on the outer edges.
    The only variation I have seen was earlier Rotax rods that were elliptical in shape ( for aero efficiency i assume ) , and a few 100cc kart engines that were slightly H
    in section with the center hollowed out.
    I always assumed this was to help the disrupted flow from the side RV, the reason Jan looked into putting the RV on the back.
    Edit - Makr has given the correct term of I beam - not my idiot idea of a non symmetric H, sorry.
  11. #23876
    For different shapes look at an ariel Arrow or a Alpha conrod as used in 1960 villiers conversions like the Greeves silverstone.
ID:	325341Click image for larger version.
ID:	325342Click image for larger version.
    The reasons i believe for the shapes were increased primary compression, which was of course all the rage back then. as the two strokes had cavernous crankcases and half cycle cranks.
    In Irvings tuning for speed, they cover modifying two stroke rods for improved steamlining
    The streamlined arrow rods were made and used in the IOM bike Herman Meier construsted were actually cheaper to make so it went into mass production.
    Sorry i can't find a decent picture of any.
  12. #23877
    13th October 2016 - 17:41
    Yours eh, ka pai.
    Tangata te Maori
    Ariel Arrow engine strip.
  13. #23878
Name:	Arrow Crank 2.JPG
ID:	325334Click image for larger version.
Name:	Arrow Crank.gif
    Arrow Crank and Rods
  14. #23879
    Yours eh, ka pai.
    Tangata te Maori
    Kawasaki 500/3 Crankshaft Rebuild.
    http://www.kawtriple.com/mraxl/files/crankrebuild.pdf
    Note the collar/spacer the seals bear upon, was this the type included - in your seal friction test - Ken?
  15. #23880
    pic two is the origional style pic one is a nice pic, good find
There are currently 100 users browsing this thread. (0 members and 100 guests)
