Page 1594 of 2776 FirstFirst ... 59410941494154415841592159315941595159616041644169420942594 ... LastLast
Results 23,896 to 23,910 of 41626
  1. #23896
    yes they will link but because the aux is tear shape it will keep linking to a minimum. unfortunatly there was no other piston choice as far as i know
  2. #23897
    13th October 2016 - 17:41
    Yours eh, ka pai.
    Tangata te Maori
    Wiseco?
    yes they will link but because the aux is tear shape it will keep linking to a minimum. unfortunately there was no other piston choice as far as i know
    What piston are you using?
    Wiseco list 'em up to 91mm as OS for the 2T Sea Doo 950,
    if its a goer, dimensions compatibility-wise - they might do a custom unit from one for you.
  3. #23898
    its 90.5mm cr500 piston. far as i know prox, oem, wiseco, wossner all have the piston sides sliced off. maybe other engines also use 90.5 but what is the wristpin height and pin diam ? this piston has long side skirting which keeps the aux from linking to the crankcase at tdc. other than the large side cutouts, i think this piston will be fine.
  4. #23899
    Yours eh, ka pai.
    Tangata te Maori
    Ask 'em?
    Wiseco will likely respond to an info/custom request ( they have a template for this - on their site) & give the dimensions.
    Or, ask one of the 'Bucket foundry' blokes here to fill your inconvenient piston cavities with a metal-foam matrix?
    www.azom.com/article.aspx?ArticleID=5940
  5. #23900
    wiseco gladly does special requests but they have a minimum order. ive talked with them about special stuff before. ill just use what I have for now and if I find a better alternative later I can swap out the piston easy enough
  6. #23901
    Yours eh, ka pai.
    Tangata te Maori
    Sure P-W, try what you have, but asking Wiseco to see the 91mm piston's vital stats shouldn't cost you..
    ( & what you have is impressive, so thanks - for sharing)
    Likely a PWC forum/local rebuild shop could show you one too.
  7. #23902
    As there are somany experianced tuners writing in this thread i must apologize for asking.
    But is there any good quality 66.4mm bore piston with piston ring dowelpin at 6 o clock?
    Ofcourse single pistonring.
    Rgds
    Patrick
  8. #23903
    21st March 2014 - 22:00
    Hanau, Germany
    Peewee: Woessner makes pistons to your desired design, it only cost a bit more ...
  9. #23904
    Yours eh, ka pai.
    Tangata te Maori
    Woessner do 6 o' clock ring pin pistons..
    Rgds
    Patrick
    If that piston you seek is for a Yamaha, you could be in luck..
  10. #23905
    Most all the 66.4 engines can be had in a single ring design, and yes Wossner make plenty of them in flat top and domed
    for everything from KTM to CR250
  11. #23906
    I too would be more inclined to use a Woessner, with a comparison on the pistons I use, the Woessner is by far the better piston over the Wiseco and slightly more cost effective too. Next order will be a batch of 10, with this number Woessner will make the changes I want.
  12. #23907
    hey guys im near completetion on this engine and hope I can get some input for the head, im using methanol fuel by the way. cylinder is bolted to the crankcase and ive got a rough cut done on the head, ill check all measurements and do another final cut. because im using Honda piston with longer stroke crank I cut almost 2mm higher into the head and cut the squishband 17* to match the piston. where im needing help is on the comp ratio, width of band and piston to head clearance. heres what I was thinking for a approximate starting place. 16:1, 1.27mm piston head clearance, 50% of area band, dimensions are 90.5mm x 82mm, expected top rpm around 8,000 or so. does these head figures sound about right ? included is photos of piston at bdc and tpc. while im thinking of it I cant remember if I showed my newest bike yet either
    Will rev to more like 6000-6500 unless you like rebuilding big ends and your teeth haven't all fallen out from the vibrations
  13. #23908
    Yours eh, ka pai.
    Tangata te Maori
    Peewee's machine is like this one - on steroids..
    http://motocrossactionmag.com/bike-t...e-project-bike
    As the reviewers say, if KTM built a current factory version, it'd sell..
    500's aren't really too annoyingly vibey to ride, & for sure - they won enough long desert races - in the day.
  14. #23909
    it will turn up more than 6500, i know this for sure. hard to say how long big ends will last but its using the prox cr500 conrod assembly. with the old topend that used 92.25 piston, most the vibration seemed to be in the middle rpm range. above and below wasnt all that bad
  15. #23910
Name:	Team ESE Porting Apprentice.jpg
    Team ESE has taken on a cylinder porting apprentice.
