Page 1595 of 2775 FirstFirst ... 59510951495154515851593159415951596159716051645169520952595 ... LastLast
Results 23,911 to 23,925 of 41617
  1. #23911
    3rd April 2011 - 18:54
    What day of the week?
    Levin
    Attachment 325383
    Team ESE has taken on a cylinder porting apprentice.
    Must be a dentist or tattoo artist
  2. #23912
    Attachment 325383
    Tell the apprentice she will get fired/disowned/Introduced to Donald Trump, if she doesn't put on her Safety glasses.
  3. #23913
    hemi im glad you like what ive done but most these guys have accomplished way more impressive things. besides, i only copied old hat that i found around this site. none of it was my own ideas
  4. #23914
    13th October 2016 - 17:41
    Yours eh, ka pai.
    Tangata te Maori
    Yeah, maybe - but at least you're getting stuck in..
    Peewee, what you have kindly shared is interesting, esp' doing it with a big cylinder,
    & showing the port/time/area issues of getting it to breathe well, rather than just 'tractor' about..
    Maybe you could ask Flettner to do a bolt-on P-V for it?
  5. #23915
    Listen you perverts, instead of doing that buy her one of these.
    http://www.ccspecialtytoolstore.com/...ivel-p/bv1.htm
    Makes porting a doodle even for dirty old men bucket racers.
  6. #23916
    Listen you perverts, instead of doing that buy her one of these. http://www.ccspecialtytoolstore.com/...ivel-p/bv1.htm
    Yeah, that will do her eyes a lot of good. That head-swivel is a fine tool, but it won't be much use to a blind tuner.
    Come to think of it: judging by the pictures there must be more than one blind tuner around. Ouch-01.zip Ouch-02.zip
  7. #23917
    Would love to know the story behind that wooden piston in there!
  8. #23918
    The FPE disaster pics reminds me of running in the very first recieved Rotax twin on the Zipkarts new dyno.
    Rotax QC was non existent back then, and the very first time I did a full power test, it threw a rod and cut the front of the case
    completely in 1/2.
    We had to buy 100 big end bearings, and I sat for hours with a 4 digit micrometer and put together sets of needle rollers
    within 1 uM of each other - then it was reliable.
  9. #23919
    Quote Originally Posted by Hemi Makutu View Post
    If that piston you seek is for a Yamaha, you could be in luck..
    It´s actually for an Kawasaki, but it has 18mm pin and pistonheight isn´t very important as i already has a spacer to move the cylinder upwards to fit the long rod i use.
    I can just make an another spacer or shim of the one i have.
    The imprtant thing is the locking pin for the ring.
    I want it at six o clock so i can port out the B-transfers a lot more.
    As i can see with wiseco´s 'racers choice' piston for KX250 the single ring is ~7 o clock, not good.
  10. #23920
  11. #23921
    A port map is fine for recording the number of ports, but that's about it. As you say, radii and chamfers will distort the map, so you can't take reliable port height measurements from it. But you cannot take reliable port corner radii measurements from it either, so why bother making a port map at all?
    Having gotten that off my chest, I want to say that I enjoy your vlogs more and more. A lot of familiar tips are passed on in a relaxed, understandable way.
    Keep up the good work Adegnes .
  12. #23922
    Thanks! Means alot!
    Anyone with ideas for better ways of measuring the port corner radii?
  13. #23923
    Thanks! Means alot!
    The pictures show Jan Thiel's 'coins-on-a-stick' that were mainly used for feeling the passage width of ports but that can also be used to check radius diameters.
ID:	325429 Click image for larger version.
  14. #23924
    Thanks! I'll fabricate a set!
  15. #23925
    You can make those coins-on-a-stick like Jan had, but for radius checking it could be even more useful to have a set of balls-on-a-stick.
    If I need to measure a radius in a port corner, I usually check with a drill shaft. After all I've got those lined up with 0,1 mm diameter increments.
