Page 1608 of 2776 FirstFirst ... 60811081508155815981606160716081609161016181658170821082608 ... LastLast
Results 24,106 to 24,120 of 41626
  1. #24106
    Had a few problems, cracked piston... This is the third Wiseco piston that has done this to me.
Name:	strong index finger.jpg
    "We cannot advise strongly enough against unbridled spinach consumption prior to handling our delicate products".
    popeye@wiseco.com
  2. #24107
    My old RG400 pistons in my TS100 used to come out looking like that after 2 meetings. It never broke but only because I replaced them regularly, every 2 meetings. I used to prep them by radiusing the edge of the bottom of the piston and polishing it as well. didn't seem to help but made me feel better.
  3. #24108
    26th April 2013 - 21:55
    BMW R1200R 2009
    I was pondering about a polite way to express my opinion but you made it a lot easier for me Neil. All I need to add is '+ 1'.
    Used to be, Hemi, used to be. Now it's 24/7 all the time .
    Is your experiment with Roland Holzner-Modena that conclusive ? I know we are speaking on an abstract level since the actual race rules exclude alle 2 stroke development, but if it were permited, would you choose a 24/7 over a rear rotary valve like on the RSA if you were asked by a constructor to make them a winning 125cc mono at world championship level ?
  4. #24109
    16th November 2016 - 20:47
    73 kawasaki h1
    U.K.
    Cutting grooves across a squish band just seems wrong to me. Wouldn't that undermine the reason and benefits behind the squish band and just promote chronic hot spots? Or am I missing something here?
  5. #24110
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    If cutting grooves in the squish helped,why didnt the TopGun tuners use it?I'm sure Mr. Jan Thiel tried it or disqualified it do to 2T physics..
  6. #24111
    Attachment 326253Attachment 326256
    Had a few problems, cracked piston, now that is not supposed to happen with forged pistons and a rotated ring that got court in the exhaust port. This is the third Wiseco piston that has done this to me. The ring peg gets pushed or works back in its hole and then the ring rotates.
    Here is a solution to that problem.https://s3.amazonaws.com/WEBPOSTS/KI...ston+trial.pdf
    Don't need to worry about cross heads and linear piston movement.
    Just make your own Ringless, Chrome plated, Steel pistons. Keep the revs over 5000.
    Cheers, Daryl.
    "First they tell you you're wrong, and they can prove it.
    Then they tell you you're right, but it's not important.
    Then they tell you it is important, but they knew it all along."
    Charles Kettering.
  7. #24112
    Lightbulb Why 5000 rpm?
    This is from the patent shown earlier:
    From 6000 up, with a 0.001" gap, the ringless engine BHP exceeds the ringed one. Fig4 (apparently)
    Independent dyno testing for verification is required.
    Cheers, Daryl.
    Charles Kettering.
  8. #24113
    New answer to the Meaning of Life, the Universe & Everything?
    So that's 24/7 X 24/7 = 11.755
  9. #24114
Name:	hot exhaust air sucker.jpg
    TeeZee, What fan are you using for extraction? We need to get one for our dyno. Cheers Dave
    Cant see it in the picture but the exhaust fan has been put inside a piece of air duct that used to go around a pot belly stove chimney. The fan itself is a 200mm 400V 3 phase unit a friend rescued from the skip for me so I don't really know where you could buy one. Behind Cully is another 200mm fan that draws fresh air from outside and blows it over the dyno operators.
    For an exhaust extractor fan, the gutted propane heater looks a very good idea.
    I'm using a gutted propane heater, works ok(for 50cc atleast).
  10. #24115
    13th October 2016 - 17:41
    Yours eh, ka pai.
    Tangata te Maori
    Aha, the dreaded harmonic frequency pulse, tamed by 2T tech, splendid..
    An academic paper researching 'knock sensor' applications to small 2T mills ( Husqvarna chainsaw) - if of interest.
    http://liu.diva-portal.org/smash/get...FULLTEXT01.pdf
  11. #24116
    Here is a solution. https://s3.amazonaws.com/WEBPOSTS/KI...ston+trial.pdf
    Don't need to worry about cross heads and linear piston movement. Just make your own Ringless, Chrome plated, Steel pistons. Keep the revs over 5000. Cheers, Daryl.
    My engine idles at 3,500 rpm and makes power from 7,500 up and max's out at 12,500.
    Thanks Daryl. it's very interesting, I see the experiment was done by the USAAC ... US Aviation Army Command using a water cooled Suzuki RM250 engine, so done by a reputable institution on a practical real world engine.
    Now to read it all carefully to see how it went and what gems there are if any.
  12. #24117
    Yours eh, ka pai.
    Tangata te Maori
    Here's another Pentagon paid for 2T patent..
    www.google.ca/patents/US8127544
    HCCI opposed piston..
  13. #24118
    Yours eh, ka pai.
    Tangata te Maori
    Combustion chamber swirl patterns.
    Those 'Singh grooves' seem a tad basic..
    Now if some talented machinist was game to try cutting a Fibonacci...
    ...or Schauberger, dynamic flow pattern..
  14. #24119
    Thanks Daryl. it's very interesting, I see the experiment was done by the USAAC ... US Aviation Army Command in part using a water cooled Suzuki RM250 engine, so done by a reputable institution on a practical real world engine.
    Ok, I read the whole thing. They had more seizures than I could live with. It was mostly about comparing the performance of a alloy and a steel ringless piston and neither made more or anywhere near as much power as the RM's conventional ringed alloy piston.
    The possibilities of getting extra power buy using a ringless piston.
Name:	Busted Busted.jpg
  15. #24120
    Lunch is not Free And we have to make it ourselves.
    Ok, read the whole thing. They had more seizures than I could live with. ("This is the third Wiseco piston that has done this to me")
    It was mostly about comparing the performance of a alloy and a steel ringless piston and neither made more or anywhere near as much power a conventional ringed alloy piston.
    True, but it worked and their process was Very Very Basic.
    The alloy piston was a standard one without the rings fitted;
    The steel one was a sheet metal, fabricated flat top;
    They didn't get results for the ringless engine over 6000 rpm.
    Changes to mixtures & jetting were random, if done at all.
    Tuning to maintain a constant exhaust gas temp might have created a datum.
    Seizures of the chrome steel piston produced no damage to piston or bore and were sanded/polished out.
    (Except when the soldered support fell out)
    More work was needed to establish gudgeon axis clearance and internal support & thermal control.
    Using different materials for piston & liner with greater expansion of liner (Ti & Steel or Steel & Al) could limit seizure with increased temps. Lots to explore here.
    Importantly the Patent was registered by the same bloke who did that testing.
    Perhaps he saw more in it than the test results that were presented to the army.
    Cheers, Daryl.
    Charles Kettering.
