Page 1612 of 2776 FirstFirst ... 61211121512156216021610161116121613161416221662171221122612 ... LastLast
Results 24,166 to 24,180 of 41630
  1. #24166
    If the top ring friction force is nearly 50N at TDC how can the ring power loss at TDC be zero?
    Power =work done / time
    = force X distance / time
    = force X velocity
    = 50 X 0
    =0
    The friction power loss is greatest when the piston is moving fastest. Zero when it's stationary.
    Cheers, Daryl
  2. #24167
    13th October 2016 - 17:41
    Yours eh, ka pai.
    Tangata te Maori
    True, F1 is tightly prescribed, tech-wise..& 2T s are banned..
    F1 changed from super-expensive, fragile/wasteful ultra-high rpm N/A V10/V8 mills to a design concept
    that would appear to be more durable/efficient, the lower rpm hybrid turbo-compound...
    Cost however, of making such engines hack high heat/pressure - instead of rpm, remains real high.
    Fact is, 4Ts 'Have one power stroke, then three to wear the engine out' - to paraphrase R-R engineer Stanley Hooker.
    To get 4Ts to do some decent work, you have to rev their tits off, or supercharge them, (chemically &/or by pumps),
    which always ends up being a complex/costly exericise..
  3. #24168
    Quote Originally Posted by Hemi Makutu View Post
    If I had my way they could still be using old 4cyl BMW road car engines if they wanted and whatever aerodynamics & tyres they think work best.
    Formula Libre is #1 for me
    Wise man, and clearly seen in the Ricardo graphs.
    Cheers, Daryl.
  4. #24169
    Yours eh, ka pai.
    Tangata te Maori
    Now for something completely different..
    A compact expansion chamber using "large angle diffuser" ( LAD) multiple internal cone flow vectoring, perhaps?
    Anyone game to try it?
    www.chengfluid.com/flow_conditioner/
  5. #24170
    Lightbulb Not more rings, More Balls.
    Quick easy dyno experiment: 1X used piston, cut a ring groove around the skirt, shouldn't need a full skirt because it's below the ports & not holding any pressure, just the skirt off the bore. Fit a worn in/out ring, check that it doesn't drop out the bottom of the liner, check ring gap through stroke & pin it to prevent rotation.
    Easier than most things you have tried.
    PS, don't expect it to last too long and don't use your good barrel.
    Quick easy experiment #2. If you're uncomfortable with adding a ring to the bottom of a piston, you could do a quick and dirty run with these.
    Hole in skirt (front & rear) to let ball protrude. Countersunk brass screws & nuts to adjust. (Could also add some springs or rubber, for a tiny bit of pre-load). Should roll in and out (over/through?) inlet/transfer ports, if required. Or use 2 one on either side of port or piston cut-out.
    Similar PS applies: don't expect it to last for more than a couple of minutes and don't use your good engine.
    A couple of back to backs (without & with) should disclose if any significant benefit is available.
    (15 KW in the Ricardo tests, assume that's per piston so +66% for the 125, worth a look?)
    Remember though, it was only 15KW peak at max piston speed so any improvements will be averaged.
    PPS, keeping the piston square in the bore might help those Wisecos survive better too.
    PM me if it works. Don't sue me if it doesn't.
    Cheers, Daryl
  6. #24171
    Yours eh, ka pai.
    Tangata te Maori
    Why not a few doz ballpoint pen nibs?
    Hole in skirt (front & rear) to let ball protrude. Countersunk brass screws & nuts to adjust. (Could also add some springs or rubber, for a tiny bit of pre-load). Should roll in and out of inlet/transfer ports, if required.
    Cheers, Daryl
    Fit the brass ball/roller nibs in the thrust face & pre-load with lube, instead of ink?
  7. #24172
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    Neither did I, but I'm sure someone did.
    cheers, Daryl.
    How do you lubricate the piston/sleeve?
  8. #24173
    Now your just taking the piss.
  9. #24174
    Quote Originally Posted by bjorn.clauw.1 View Post
    +1 on your crank truing vid. I made a jig that holds the crank webs in allignment when I press. I normally put some green loctite in the holes in the crankwebs (a little, so there is no exces that comes out and glues your big end solid,... don't ask). They always come out true. Until last, when the pressure gage of my hydraulic press broke and I decided to eyeball it. pushed too hard and had misallignment. Frits his method with the bolt worked nicely. The axial missaligment was an other story. Gently tapping was no longer enough to adjust it. Got it true in the end though.
    Wondering if it's a good idea now to put some loctite in the holes on the crankweb (or if it even helps at all)? Comes from a rotax manual I believe.
    jig looks like this
    Attachment 326376
    this looks interesting. Never tried it though. (maybe beef it up a little)
    Attachment 326377
    Thanks!
    Two strokes & rum!
  10. #24175
    Piston & liner will be exposed to air/fuel/oil through the inlet & transfer ports.
    Fuel vaporises and leaves some oil behind.
    Doesn't need much cos there's bugger all contact between the piston & liner.
    Remember this is just an idea for a quick dyno test. Squirt some oil on it during assembly.
    Cheers Daryl.
  11. #24176
    Trying to think back into the box.
    The screwed on ball bearings might be a bit rough, even for me.
    How about Brass brake shoe rivets? Brass Thumb tacks?
    How about Teflon buttons, shaped like thumbtacks, countersunk into the skirt?
    Quick & easy to do, should give enough life for a few runs before it all turns to poo.
    Works for Harleys on Nitro.
    Credit for the pics to this site: https://www.rbracing-rsr.com/bulbenefit2011.html
    Cheers, Daryl
  12. #24177
    3rd December 2011 - 23:33
    2005 aprilia rs50
    UK
    Attachment 326268
    Cant see it in the picture but the exhaust fan has been put inside a piece of air duct that used to go around a pot belly stove chimney. The fan itself is a 200mm 400V 3 phase unit a friend rescued from the skip for me so I don't really know where you could buy one. Behind Cully is another 200mm fan that draws fresh air from outside and blows it over the dyno operators.
    For an exhaust extractor fan, the gutted propane heater looks a very good idea.
    I'm using a gutted propane heater, works ok(for 50cc atleast).
    I've actually got a proper exhaust extraction fan, but that's used for cooling. When I think about it my bike always seems to be "overcooled" on the dyno, might switch them around.
    Thanks for the info guys.
    A few pics of our dyno:
Name:	Dyno constuction.jpg
ID:	326406Click image for larger version.
Name:	dyno construction 2.jpg
ID:	326405Click image for larger version.
    Dave
  13. #24178
    Dave
    That's a nice clean looking dyno, especially found of the front wheel mount!
    How about some "slow tv" to round off the evening.
    https://youtu.be/hlsogG-zcC0
    Two strokes & rum!
  14. #24179
    Tell me what you used for inertia wheel on your dyno
  15. #24180
    2005 aprilia rs50
    UK
    Talking
    Cheers adegnes
There are currently 70 users browsing this thread. (0 members and 70 guests)
