Page 1615 of 2773 FirstFirst ... 61511151515156516051613161416151616161716251665171521152615 ... LastLast
Results 24,211 to 24,225 of 41593
  1. #24211
    16th November 2016 - 20:47
    73 kawasaki h1
    U.K.
    I've looked again and I'm still not sure. This just shows a lack of consideration on the part of the photographer. Or a willful desire to keep me guessing. Or my eyesight is worse than I thought.
    Anyhow, elsewhere, there was also discussion of adding a sump to gearboxes. These two things led me to wonder about the merits, if any, of actively cooling the transmission oil.
  2. #24212
    Quote Originally Posted by EssexNick View Post
    The origional Kawasaki tandem sure benefited from the reduced spash effect when it lowered the oil level resulting in less hot oil that previously heated its crankcases from it wet gearbox.
    I would say that pressure feed gearbox oiling and water cooled cases have made it a bit irelevent. When compared to the benefits offered by these other alternative solutions.
    Most of the heat comes from the clutch, which ideally should be dry and air cooled anyway.
    Honda deemed the pressure feed gearbox to be worth while on road bikes (nsr250) it was hardly something that most would have noticed as being race derived and a selling point, unlike the fashionable single sided swingarm , gull arm tri arms and dry clutchs etc.
  3. #24213
    73 kawasaki h1
    U.K.
    Thanks for the reply. Most of what I know about two strokes is at least 25 years out of date, but I still wonder about these things.
  4. #24214
    Mate remember most 2T buckets are also at least 25 years old...
  5. #24215
    That head cutting how to kinda turned into a joke... I swear it has worked great for me before....
    In fact, here's a pic of a head I reshaped with this method a few years back:
    Not too bad I think, for what it is.
    Two strokes & rum!
  6. #24216
    Alex, I very much like your down-to-earth videos that show all the little problems one can encounter.
    BUT
    Be extremely careful. Not because you can damage yourself but because you can easily damage the cylinder.
    Yes, it would be a pity if you damage that part. But you can always get another one. And the same goes for your sweater that will be grabbed sooner or later.
    And the skin on your arms and hands will self-repair too, given time. But where do you plan to get a new set of eyes? For gods sake man, were some eye protection.
  7. #24217
    BUTYes, it would be a pity if you damage that part. But you can always get another one. And the same goes for your sweater that will be grabbed sooner or later.
    Thanks!
    You are absolutely right! I usually do wear protection glasses, guess I got a bit carried away...
    I should know better, I've actually had an aluminum chip pulled out of my eye with tweezers by the doctor once.
    Two strokes & rum!
  8. #24218
    73 kawasaki h1
    U.K.
    Exactly why I'm here. If I'm to drag the old H1 anywhere near the 21st century then this is the place to be.
  9. #24219
    Mission 1 annoy the purists.
    I see a radiator and some bucket style water jackets.
  10. #24220
    [QUOTE=adegnes;1131015369]
    Not too bad I think, for what it is.[
    thanks for the video... when you have very limited equipment," a mans got to do what a mans got to do".. i recently watched a video of a man cold chiselling a keyway in a large crank shaft and thats how they used to do it for real!! no milling machines then.
  11. #24221
    The new 400 Superlight for Dennis will be closer to 100Kg than 130.
    It has a carbon tank and bodywork, every bolt/axle is Titanium, and small diameter front Brembo discs off Aoyama's 250GP title winning bike.
    With Marchesinis all round and alot of unneeded alloy ground off the chassis it should be a rocket.
    I got a Mupo suspension kit for it, to replace the internals of the 2006 HRC RS250 forks, with an all adjustable rear shock for the Aprilia chassis
    but Mr Taylors dyno says they are " shocking " so they will need a lot of revalving to stop Charlett whining endlessly about the handling.
  12. #24222
    EDIT: this should do it: Attachment 326435
    Please let me know if there are any more problems. That HEAD-program should behave now.
    Yes that's better. It doesn't run on an HP 200LX running MS-DOS 6 BTW.
    A question though about the box containing the legend "Radius 6.84" in the attached pic: Is this the radius of the curve from point 2 to point 3?
    I set it at 6.5 in the parameters, but I'm guessing the program has corrected it to match the required CR?
  13. #24223
    https://www.youtube.com/watch?v=U2OBHpQhixE
    https://www.youtube.com/watch?v=pA91yGMUIG0
    Chatter was one of the words you were searching for. Much like the chatter of teeth. hakke tenner
    The other was method metod
  14. #24224
    Thanks!
    Two strokes & rum!
  15. #24225
    Thanks!
    Thanks for the videos and also thanks for the Norweigan girls.
