Page 1622 of 2774 FirstFirst ... 62211221522157216121620162116221623162416321672172221222622 ... LastLast
Results 24,316 to 24,330 of 41606
  1. #24316
    I'm actually using that black flex shaft you posted.
    Hmm, maybe that bulky 90° dremel attachment could be modified to fit in small cylinders, think I'll order one.
    What I was thinking about was something small enough to be fed through the exhaus or up a transfer and then connected to a "burr on a stick". Maybe some RC flex drive stuff can be used.
    Two strokes & rum!
  2. #24317
    Look at the pictures in the eBaylink compared to human hands. They would be just fine for a 500 but a bit compromised in a 250.
  3. #24318
    I've got a Dremel right angle attachment and you cannot get into a MB100 cylinder with it. Nice bit of gear though, just of no use.
  4. #24319
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    ... here's a wank shot of the NSR300 doing it's thing onto the front straight of Taupo, by far the best i've ever had it running!
    Attachment 326637
    I have always dreamed of being able to do that with my Bucket, great shot.
  6. #24321
    Nice mod! Love it!
    Two strokes & rum!
  7. #24322
    Cheers Rob. I was put off racing for a day or so. .... I will work on getting the 50 sorted first.
    Yeah don't make decisions in haste. There's always the 50. You can't possibly hurt yerself on that.
    When I rode bigger bikes I never thought I could be frightened by a 50 but now they actually seem a challenge and even a little frightening ...... . I very much want a 50 of my own.
  8. #24323
    Certainly taught me about what to order from the hospital menu and what to avoid.
  9. #24324
    See...Bucket racing can teach you useful skills. That knowledge will be very handy as you age disgracefully.
  10. #24325
    19th October 2014 - 17:49
    San Francisco
    In re alternate charging systems:
ID:	326662   Click image for larger version.
ID:	326663   Click image for larger version.
ID:	326664   Click image for larger version.
  11. #24326
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Another nice Maico prototype, first time I've seen the internals of this one. Thanks Michael, BTW this could also be posted in the "oddball engines .." topic.
  12. #24327
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Another nice Maico prototype, Thanks Michael, BTW this could also be posted in the "oddball engines .." topic
    I see you did get it moved to the 'Oddball thread' TJBW.
    Strokers Galore!
  13. #24328
    1988 cagiva freccia
    france
    I want to convert the hrc needle reference to reference keihin
    There exists a table or means of conversion ?
    Needle HRC 16203-NX4-780 marking 1268/3466/2351
  14. #24329
    I would say to have to measure them out. The Kehin numbering system is based an angles and widths and certain points along its width.
ID:	326688Click image for larger version.
    The problem is though these carbs are ketting older and as the Jet Needle wears the needles need to be made thicker to acomidate this wear.
  15. #24330
    24th January 2010 - 03:21
    TZ 350
    UK
    the problem is the local machinist does mostly automotive stuff and says he cant do a radius in the head band. either he doesn't know how or his machine isn't capable. so for now I wont have a radius in the head band until I can send the head off to someone else. heres what I have since the last bit of cutting.
    I may have posted this before - can't remember - whether it's necessary to follow piston radius or not for squish - it's what I wanted to do with our TZ350 - don't have easy access to cnc - so found a way to get it done with what i did have available...
