Page 1628 of 2776 FirstFirst ... 62811281528157816181626162716281629163016381678172821282628 ... LastLast
Results 24,406 to 24,420 of 41631
  1. #24406
    They look similar to what I've been calling phenolic resin cage bearings. I started using them when I had main bearing cages come apart in my Suzuki TS100 bucket. I've used them more recently in MB100 engines as main bearings. I've never had a problem with them. They weren't a whole lot more expensive if I recall.
  2. #24407
    any you guys tried these cages ? seems like they would need to be special ordered and maybe that adds a lot to the cost http://www.skf.com/binary/tcm:12-322...m_12-32271.pdf
    Aprilia RSA crankshaft bearings. Look familiar?
Name:	BC1-1442 BA 1.jpg
ID:	327149 Click image for larger version.
Name:	BC1-1442 BA 2.jpg
  3. #24408
    ive seen them frits but wasnt sure of the material. pa66 is common so i assumed thats what it might of been
  4. #24409
  5. #24410
    Made in 6203/04 also you think? Having trouble finding them in the SKF bearing finder.
    From the same site
    http://www.superkart.it/engine-spare...-kz-flat-model
    Not exactly cheap...
    Two strokes & rum!
  6. #24411
    H model had 2 seperate cranks with a coupling in the middle , on the outside of the coupling was the output gear that drove the jackshaft. So the crank was but a distant relative to the early TZs
    Hey Husa , found a good picture describing the above
Name:	tz250h_j crank.jpg
  7. #24412
    It is a very nice picture, i think i will harvest it.
    https://www.kiwibiker.co.nz/forums/a...p?albumid=4882
    From the same site
    Euros aye eeeek.....
    Try KTM85 they have a plastic cadged roller bearing not sure re the size though
    But its in the Pro X cattledog though (which i can't find at the moment either lol)
    NJ206 ECP
    Inside Diameter: 30mm
    Outside Diameter: 62mm
    Width: 16mm
  8. #24413
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Those bearings were especially made for Aprilia.
    We had lots of problems because the 'shoulder' used to break off.
    So they removed it, and instead supplied a loose ring.
    They were used on all Aprilia engines, not just the RSA
  9. #24414
    Hello Jan, Have a happy Christmas, best wishes to you and your family, keep looking after the animals
  10. #24415
    23rd March 2015 - 21:24
    Conti RX356 V3
    I use SKF NJ 204 ECP C3 or FAG NJ 204 E TVP2 C3 (equivalent to the 6204 bearings) in my 50cc Derbi engine. 0,2...0,3 axial play and I never had a failure with up to 50h runtime, thats about the time the better crankshafts last
  11. #24416
    Thanks!
    Two strokes & rum!
  12. #24417
    euro...
    https://www.acu.org.uk/news/track-racing/.... british motorsport could end.....
  13. #24418
    Not just British motorsport: ALL European motorsport could end. Funniest and scariest is that this would also apply to lawnmowers and mobility scooters.
  14. #24419
    Jus as well the IOM is not part of Britain, neither is Ireland.
    Last edited by husaberg; 27th December 2016 at 10:48. Reason: that should read not part of UK
  15. #24420
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    The IOM and Northern Ireland are British. - Southern Ireland is a republic, they officially separated from Britain in 1949 (I think).
    It's funny that when Eugene Laverty wins he prefers to have the Irish national anthem played and under the Irish Tri colour flag, whereas his brother Michael uses the Union Jack and has the British national anthem playing,
    They come from Northern Ireland but at least now they can voice their preferences without controversy. (progress I guess!).
    Both motorcycle racing and Rugby don't seem to recognize borders in Ireland and that's good!
    Strokers Galore!
There are currently 104 users browsing this thread. (0 members and 104 guests)
