Page 1637 of 2774 FirstFirst ... 63711371537158716271635163616371638163916471687173721372637 ... LastLast
Results 24,541 to 24,555 of 41606
  1. #24541
    Quote Originally Posted by jseb89 View Post
    The engine is from a 1999 Honda CRM250 AR - the production version of their EXP-2 400 rally bike.
    nice project you have going. is your assignment only to model the cylinder or do you have to prepare it for more power as well ? excuse me for not knowing but whats a crm250 ? I presume it was some kind of road going bike but is it medium or high performance ?
  2. #24542
    20th July 2013 - 08:55
    Honda
    uk
    Now all you need is an SLM (Selective Laser Melting) unit. Then you will have your cylinder directly in metal, no casting required any more
    (minor problem: you will need a watercooled credit card).
    Attachment 327730
    Metal printing is very expensive and I think the material selection is limited, digital sand printing for casting is another option that is potentially cheaper and lets you have greater control of the material specification / composition - air cooled credit cards need not apply for either option unfortunately
  3. #24543
    Honda
    uk
    I'm not quite sure exactly what direction to go in yet but a good first step is to inspect, measure and model all of the components.
    The basic composition is:
    Bore & stroke: 66.4x72
    Con rod length: 132.5mm (most modern 250's are 125mm)
    Piston compression height: 33mm (most modern 250 engines are 38mm)
    It's a road going trail bike, medium performance
  4. #24544
Name:	CRM250 EXP 2.jpg
ID:	327738Click image for larger version.
    sorry the first ones fuzzy.
    exp
    https://www.kiwibiker.co.nz/forums/s...post1130353595
  5. #24545
    must be a european model as ive never seen or heard of it in the usa. looks interesting
  6. #24546
    More likely to see one in Japan, some were imported second hand all over the world though.
  7. #24547
    Coming along!
    Two strokes & rum!
  8. #24548
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Many people complain about ignitech.
    The power would be less than the original ignition on 250 rgv or rs honda.
    It is necessary to couple the 2 outputs on a single coil for a cylinder, and to power the cdi with 16 V to arrive to equalize the original cdi.
    Amazing that wobbly made with. What do we not understand?
  9. #24549
    So how is this criticism manifested or quantified? Are you somehow measuring spark energy in a running system, or looking at a spark at turnover?
  10. #24550
    The issue with the Ignitech in the case of the RGV ( Aprilia ) and the RS125 is that what no one realizes is the interaction between the output circuit
    of a DC - DC converter and the ignition coils inductive reactance.
    Both of those ignitions are DC-DC,like the Ignitech, but have been optimized to provide sufficient coil energy by fine tuning of the converter to drive the coils
    primary resistance and overall inductance.
    For the Ignitech, any coil can, and often is connected that is nowhere near correct to generate sufficient spark gap power.
    The RS125 coil is very wrong, and doubling up the output circuits of a P2 ignition will then give better performance than the stock setup.
    The RGV,Aprilia coils have worked perfectly well on dozens of race engine projects I have done.
    But the Ignitech is also capable of driving huge power into a very high inductance ( with low resistance as well ) coil such as the big Crane CDI
    versions.
    This setup is ideal for high com methanol burning race engines,where big spark gap power is needed to fire off the rich mixtures reliably.
    I now routinely use a P4 ignition on twins with circuits 1,3 and 2,4 paralleled into 2 RGV coils with very good results.
    Edit - by that I mean way more spark energy than is actually needed.
  11. #24551
    Just reading the Mike Sinclair book. Its not a literary masterpiece, but it is interesting and gives an interesting insight into some of the advances and some of the disadvantages of being beholden to a major manufacturer. Even with KRs considerable infulence as Team head and Marlboro money. Some of the advances made have been mentioned here, exh port bottom, carb solenoid, Czech university flow simulation tool etc.
    Not sure if it will be available outside NZ.
    I got loaned mine but I'll probably buy one for the sake of it.
    http://www.batemanpublishing.co.nz/P...ProductId=1594
  12. #24552
    Jan Thiel just told me that he is considering selling a helmet that was given to him by Valentino Rossi in 1997,
    the year that Rossi became a world champion for the first time. The helmet is signed by Rossi. Any takers?
  13. #24553
    16th November 2016 - 20:47
    73 kawasaki h1
    U.K.
    Any idea how much he might be asking for it, or is it up for auction?
    Two things I have to add, 1: Thank you for thinking of us. And 2: Unfortunately it won't be for me, but someone I know is a mega fan.
  14. #24554
    Anyone got a Rotax 257 cylinder for sale.
    I have an old engine that needs rebuilding and the cylinder is cracked on the spigot as many did.
    A damaged one is fine as long as its serviceable.
  15. #24555
    Quote Originally Posted by FritsOvermars
    Quote Originally Posted by EssexNick View Post
    I was only the messenger. You now know as much as I do and I am in no way involved, nor do I wish to be. Posting my message was just a kindness among friends.
