Page 1662 of 2776 FirstFirst ... 66211621562161216521660166116621663166416721712176221622662 ... LastLast
Results 24,916 to 24,930 of 41633
  1. #24916
    A 125 cylinder with 310cc of " case " volume at tdc would have a primary com of 310/310-125 = 1.67.
    That ratio would indicate huge pumping losses.
    But the engine with 310 at tdc and 238 at BDC is only 1.3 - perfectly normal for a race 125.
    So what am I missing in the Ryger " concept " of using big primary com to force transfer the charge into the cylinder, instead of an efficient pipe
    pulling it thru around BDC.
    I think it comes down to the higher speed at which the smaller "crankcase" volume attains its peak efficiency.
    With the conventional style engines reducing the primary comp to anywhere near the same level had required the crankcase airflow and transfer flow to become so hugely stifled it became irrelevant, I believe it was because it created huge boundary friction in the areas around the crank wheels. plus other flow airflow restrictions.Thus I muse separating the crankcase might be the difference.
    Also it would seem the ryger benefits from modern transfer control and durations. As devloped over the last 40 years.
    There is an engine speed at which maximum air delivery to the cylinder occurs, and that this engine speed is inversely proportional to crankcase volume, but that the maximum value changes only slightly with changes in crankcase volume. To put it another way, the crankcase-pump's volumetric efficiency is nearly constant, but the engine speed at which it attains maximum efficiency rises as crankcase clearance volume is reduced. pumping losses (horsepower absorbed in doing this work) rise as to the third power of compression ratio. Researcher Fujio Nagao, of Kyoto University
    or it might just be overhyped horse poo.
  2. #24917
    are you able to factor in a cooler intake charge and reduced crankcase turbulance, as the fuel air is no longer being churned around and heated up prior to entering the transfer ports. if the high primary comp forces a fast movement of charge into the cylinder, wouldnt that pressure drop cause the reeds to open allowing a secondary wave of intake flow? like a pumping action.
  3. #24918
    How much masking effect does the dirty great post down the center have ?
    Still got to get the mixture in and distribute it to the transfers....
  4. #24919
    couple questions from a dummy trying to figure it out. true it wouldn't be churned up but wouldn't it be compressed more, between the piston and plate ? this would add heat also, in the same way high comp ratios in the cylinder , between piston and head , or am I thinking wrong ? how much combustion heat would travel into the big plate ? and if the primary ratio is through the roof , 1.67 or what ever, wouldn't that meen a much lower average pressure delivered to the cylinder ?
  5. #24920
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Ryger
    Ryger Question:
    The displacement in the chamber below the piston is roughly half the cylinder displacement - thus the pumped volume is about 70cc in a 125cc engine. So relying on pumping only at theoretical best we can only get a delivery ratio of 50% (Aprillia RSA125 ~ 140%) so where does the rest of the charge come from?
    You would need some super pipe to create this sort of suction to make up the difference and that is just to match the RSA125, but the Ryger is supposed to be relatively insensitive to pipe design so not this?
    The inertia of the gas flowing through the ports can help a small amount but nowhere near this difference.
  6. #24921
    Ryger Question:
    My initial guess is directly through the very short piston skirt on the inlet, ie it does not shut until well after the transfers opens.
    but i have never tried to map it out, but i am picking you may have though
  7. #24922
    Ryger Question:
    Fairy dust.
  8. #24923
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Ryger Question:
    So there is NO reason why it should give more than about 30HP I can think of.....
    It MIGHT be overhyped horse poo....
  9. #24924
    Yamaha XJ750 1982
    South Africa
    I updated my software to simulate stepped pistons, both ways, the traditional bigger bottom step and the Ryger smaller step, and I have tried many ways without ever exceeding 30hp on the Ryger. Maybe I am missing something....
  10. #24925
    ok.. thanks for that info.. i thought you would be able to give me that information because i can see you have gone into this engine set up in a good technical way...lets hope for good weather for you to test under load... thanks
    now, I think its not weather, just time needed to assemble the bike....
    Jack Findlay n1 in photo
  11. #24926
    Maybe we all are, or Maybe not.
    I am looking forward to hearing Katinas impressions when he gets to ride his bike.
  12. #24927
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    1st 110cc water cooled bucket
    Farmer Ken had his new engine on track today, a few nice home made goodies in this baby, NSR250 pot on TF bottom end, stroked crank, power valve, quick shifter, it's fully loaded
    Getting a bit pissed off with my correct way up photo's getting rotated by this forum
ID:	328496   Click image for larger version.
ID:	328497   Click image for larger version.
ID:	328495   Click image for larger version.
ID:	328498   Click image for larger version.
ID:	328499   Click image for larger version.
  13. #24928
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    thanks for the pictures , was told when driving home he had made this engine up , was guted i had not seen it .
    i'm over buckets
  14. #24929
    1996 Buell S1
    Orewa
    I mentioned to Reagan that his green meany may be a weapon water cooled and stroked to 110cc
  15. #24930
Name:	NSR-TF 110cc Engine.jpg
    Great to see the first race ready 110cc H2O special out on the track, big up's to FarmerKen .....
There are currently 42 users browsing this thread. (1 members and 41 guests)
  1. Mat2.0
