Page 1668 of 2776 FirstFirst ... 66811681568161816581666166716681669167016781718176821682668 ... LastLast
Results 25,006 to 25,020 of 41630
  1. #25006
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Unlikely i could explain but a picture might help?
    Okay its clearly not to scale and a pretty lazy ass attempt at a picture.
    Attachment 328650Attachment 328651
    It would clearly only work with an engine that had no ancillaries on the disc side of the crankshaft.
    Thus the clutch and the ignition would have to be on the other side.
    Throw in Flettners variable inlet port timing as well.
    It would cause a lot of friction....
  2. #25007
    likely i am sure it would but in my defense so do bevel gears.
    Is there a rule of thumb for disc friction?
    I considered some of those narrow thrust bearings like these.
    As it sealed on the outer oring housing i thought it might get away with a little leak arround the disc as it can't go anywhere or is this a big issue as well?
    Anyway making it work is the R&D departments issue, i work in the silly ideas department
  3. #25008
    24th December 2012 - 21:49
    Quiet plodder
    South Akl
    Never finished.... is actually my middle name
    Come on, pull the other one.
    you can do it.
    choose something and tackle it until you finish.
    dont be like me.
    READ AND UDESTAND
  4. #25009
    26th April 2013 - 21:55
    BMW R1200R 2009
    Thx for the explanation. Very interesting. And I hope Flettner is hearing your hint. By the way, I think his idea for a variable inlet disc is a marvel.
  5. #25010
    Instead of driving a disk valve off the end of the crank or the cross shafts like the RSA, would it be possible to put the disk on the end of an AC 3 phase servo, and run it off an encoder on the crank, you could locate it anywhere, front back top bottom side etc 15000 rpm might be a bit out of the reach of the servo but 3 or 4,000 is doable just put a 1:4 gear train on it. How much power does the disk take to run. Needs a good high voltage winding to power the drive, an added bonus would be variable timing
    To give you more of an idea what Im talking about there is a demo video on this page https://www.teknic.com/products/clea...-servo-motors/ watch from about the 4 minute mark will give you an idea of the accuracy and speeds etc.
    All this is everyday stuff in the CNC world
  6. #25011
    I guess my variable housing has a servo anyway. just not a high speed one.
  7. #25012
    At highspeed it doesn't even have to rotate at all. As long as it stops in the open position. Its only needed at lower speeds isn't it?
  8. #25013
    Very very good point !
  9. #25014
    Rotate? Why not just open and close guillotine?
  10. #25015
    Health and Safety prevent us from doing that
  11. #25016
    with 8000 odd posts i had to have one once, eventually.
    Thats a step away from Diesel talk and poppet valves
  12. #25017
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    people were making up straight cut primaries for the rd and rz using stock yamaha parts
    I am at the moment working on my Aprilia RS250 (= Suzuki RGV engine). I allready came to the clue that Suzuki uses the same design for clutch parts on RGV 250, GT250, GT380, DR400... So I modified the original clutch to one frictionplate more using a few GT250 steel plates.
    Also the inner hub of the clutch has the same dimensions in these bikes - except for the height. Here the RGV is highest.
    I wonder if anyone has done the same thing and may tell me if there is an other Suzuki which straight cut primary gears suit the RGV?!
    Cheers to everyone
    Tim
  13. #25018
    Cheers to everyone
    Tim
    No idea re the clutch and primaries for the RGV
    But i have seen a SP or F3 RGV parts list posted on the net, have you tried to cross reference the parts numbers?
ID:	328657Click image for larger version.
ID:	328658Click image for larger version.
ID:	328659Click image for larger version.
ID:	328660Click image for larger version.
    Murphys law the one you want to see iis the blurry one.
    Vincent Crabtree did a nice piece on using a RG250 crank in one for a 54mm stroke with some Snowmobile cylnders that are a bolt on.
    They shared the same primary gear. or the spline from memory (RG250)
    Lozza (2Tinstitute)brought a crank to do the conversion but i never heard anymore.
    The best way to find what clutch parts fit others is to cross reference EBC cataloges and such like.
    Honda and Suzuki seem to use the same plate parterns and baskets ove ran over again
    For instance pretty much all the up to 250 hondas share 2 types of plates.
  14. #25019
    13th September 2012 - 07:48
    1991 NSR300
    In a house
    Cheers to everyone
    Tim
    The tunning works do trick clutch and primary gear parts
  15. #25020
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    Aprilia RSA Big End Pin and Crank Web Diameter
    Jan and/or Frits,
    can you please tell me the Big End Pin and Crank Web Diameter of the RSA 125?
    Thank You!
There are currently 48 users browsing this thread. (0 members and 48 guests)
