Page 1670......
Yes, very interested. Thanks Nathan, for the great idea of using a MAP sensor to measure the pressure changes in the exhaust system so as to see the changes in bulk air flow through the engine, I wish I had thought of that ages ago.
Page 1670......
ya i dont like the square aux either. with the teardrops you lose alittle area in the lower rear corner but gain some area in the upper rear, where its needed most. so the pressure drop can be faster through the first few initial degrees of opening, atleast that's what I think happens
Hi Guys.
I did a quick thread search and could not find anything discussed on smartcarb. Anyone running one? I have had a little experience with Lectron and they seam really good. Is smartcarb as good?
One other small point about the square Aux, is that this exposes a huge area enabling interconnection to the A port via the small end piston hole.
With a teardrop the port exposes less than 1/2 the area where the linking can occur, and separates them height wise.
https://www.kiwibiker.co.nz/forums/s...post1130842057
https://www.kiwibiker.co.nz/forums/s...post1130255542
https://www.kiwibiker.co.nz/forums/s...post1130812466
https://www.kiwibiker.co.nz/forums/s...post1130437168
there is more but KB search is not working properly maybe due to the thread being split a few times. poll etc
google search just for this thread:
https://cse.google.com/cse/publicurl...90:5pd9xdluxce
only downside is that the google indexing robot passes by every 5 days, so the last 5 to 10 pages are not included.
I've only ridden one bike with a smartcarb. About 2 weeks back. Ran nice. But I know a lot of people on gg forum that were ccustom sanding the needles. Seemed supercritical, not as they set out one needle fits all. I question how they would wear.
Heavy to hold.
Thank's for the feedback Wob and PeeWee. As the rear of the aux port is already at the bore centerline I need to give up a bit of the (theoretical) blow down. Re the short circuiting I will use a piston plug, but that will not really solve the problem, right? So I will follow the tear drop shape...
Re the stagger: the Yam cylinder has indeed a different transfer entry as Jan's RSA cylinders. I thought with the 3 ex port design the reverse stagger would be the way to go. Also the Yam engineers had the idea to let the A port going flat into the cylinder were the B port has a 15° upward angle. Need to think about to fill up the A port top with JBweld...
We used piston plug AND teardrop shape!
And with a triple port the A-port must be lower to reduce short circuiting with the aux-ports.
The Yam engineer's ideas seem VERY outdated.
Later they copied Honda 100%, and even published an SAE paper about that......were proud of it.....
They even didn't do the copying themselves, Yamaha-France's famous head mechanic Guy Coulon did it for them.
Our A-port was at least 25° inclined upwards, maybe a bit more.....
When I reduced the B-duct entry the reverse stagger was already there.
True, an overly rich mixture will yield a low exhaust gas temperature. But even with a correct mixture strength such an engine will loose revs because a high compression ratio doubles as a high expansion ratio, dropping the EGT even before the exhaust port opens.
And let's not forget Harald Bartol. Our beloved friend Cees van Dongen showed the way by putting a Honda RS125 cylinder on his son's Yamaha TZ125, and Bartol first copied Van Dongen's idea and subsequently developed 'special' cylinders, financed by Yamaha. I hear that Yamaha were not amused when it became clear that their money had been used to carbon-copy Honda cylinders.
41j you seem to have room to bring the aux exhaust ports closer to main exhaust, instead of just making them wider outwards.
The bridged exhausts like Honda 125's, open up to wristpin. Has Honda ever used closed wristpins? Any time I've tried widening a bridged exhaust on a dirt bike into wristpin area it ruined the power. Couldn't get it to work.
Forgot to mention I've had really good luck widening bridged exhaust port next to transfers. This goes against the RSA results... but has always worked for me on bridged ports
Very late reply!Husa asked in Nov 15,2011(page 360) if anyone tested the ignition curve from a KTM 50SX iggy,well I did today,,planning to use it on a one off Minarelli scooter engine,so I built a test rig.Sorry to say its a "flat liner",no curve at all!Back to the drawing board...![]()
There are currently 69 users browsing this thread. (1 members and 68 guests)
