Page 1671 of 2776 FirstFirst ... 67111711571162116611669167016711672167316811721177121712671 ... LastLast
Results 25,051 to 25,065 of 41630
  1. #25051
    Very late reply!Husa asked in Nov 15,2011(page 360) if anyone tested the ignition curve from a KTM 50SX iggy,well I did today,,planning to use it on a one off Minarelli scooter engine,so I built a test rig.Sorry to say its a "flat liner",no curve at all!Back to the drawing board...
    Chairs, the latest ones i see are are digital now though, so they will have a curve i hope.
    They are still a neat little set up, and cheap as chips.
ID:	328749Click image for larger version.
    Price:$299.00 + $4.49 shipping
    https://www.amazon.com/DIGITAL-IGNIT.../dp/B00CFL5QLU
    http://www.ktm-parts.com/mm5/graphic...XS12050039.pdf
    For an idea just how big they are for those unfamilar with the little KTM's
  2. #25052
    As you have gone 1/2 way and put in the bore/duct radius you may as well go all the way and epoxy fill the B port front wall
    as Jan did as a successful test on the Aprilia.
Name:	TZR - 2.jpg
  3. #25053
    21st March 2014 - 22:00
    Hanau, Germany
    Thank you guys for the feedback.
    Currently I have 3,0 mm distance from the main to the aux ex port, can I go narrower, let's say to 2,0 mm (I remember the 5KE TZ cylinders had a problem there with cracking walls)?
    Ok Wob as you say, now I'm already not too far from a good setup I will do that too. The front of the B port has already the right direction at the outlet to the cylinder, but to minimize the lost of energy I will correct also the complete wall.
    BTW: when cutting so much on a cylinder is a re-plate a must? As that is my first attempt my idea was to test that setup let's say for about 2-3000 km on the road and then put in all the new stuff (like piston, crank, etc.).
  4. #25054
    I muse maybe for a twin sided disc valve to make a lot more power than a single it would require an intake track with a very large updraft that way some of the airflow would go directly up the transfers on the same side rather than colliding and thus losing velocity in the middle an into the conrod?
    I note the kreidler 50 with 2 discs had the intakes facing steeply towards the crankwheels rather than being straight a well. packaging?
    Was thinking about this and wondered that, instead of having the two disc valve passages being coaxial or on a plane, have them enter the under cylinder volume semi tangentially.
    One could enter under the A passage entry point on one side and the other, on the opposite side, enter under the B passage. This would eliminate any direct collision of the streams, but dunno about the connecting rod impeding the flow over the cycle.
    Also, the possible resultant swirl motion above the crank might create some asymmetry to the flow entry into the transfer passages.
  5. #25055
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    A very good idea, I was thinking about that too..
  6. #25056
    The problem with grinding a cylinder is that the main exhaust will then not have the plating going around the corner from the bore into the port.
    As the ring bulges outward,and the top/bottom port radi with a chamfer help to guide it back into the groove,eventually the plating will be worn thru to alloy - or chipped away.
    You can smooth the edge with a cotton mop to help the situation,but for sure it will last long enough to test the porting results.
    The transfers dont give any problems, as they dont need a chamfer at all.
  7. #25057
    6th February 2016 - 06:52
    ducati
    was having some fun with my computer these past few days. Still trying to figure out the Ryger and how this design software works
    Trying to figure out how to animate the damn thing!
  8. #25058
    19th October 2014 - 17:49
    San Francisco
    Could you post a photo on your test rig? I need to run a 2015 KTM 250SX ignition as I can't find anyone who has any idea of what the map in it looks like and I don't know if it will be suitable for RR use instead of MX.
    thanks,
    Michael
  9. #25059
    was able to finally start it today so thnx to everyone on this site who offered assistance along the way . wasn't tuned real well since I had to steal the carb from my Honda but never the less it runs and there were no immediate mechanical failures. ill put the methanol carb back on and run it again after the mud dries up in a few weeks. probly do alittle more work to the head like install a mechanical compression relief so the crankcase doesn't break at the kickstart area and may lower the com ratio a bit
ID:	328762   Click image for larger version.
  10. #25060
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    Here is my backyard(bucket) method,machined a shaft(read bolt) to match the crank profile,install it into cases,add iggy,TrailTech tach,spark plug and timing light,degree wheel or protractor on stator to read curve at different RPMs(not used in my case)Spin it with a DoAll dental drill motor attached to the shaft Click image for larger version.
Name:	iggy chk 3.JPG
ID:	328769Click image for larger version.
Name:	iggy chk 2.JPG
ID:	328768Click image for larger version.
Name:	Iggy chk 1.JPG
    Wobbly has a vid of his rig somewhere in this thread that uses a vacuum cleaner motor,waay more hi-tech than my rig!
    https://www.youtube.com/watch?v=pA6k...w&feature=plcp
  11. #25061
    23rd September 2015 - 05:11
    does Playstation count?
    USA
    Even if it's not needed to guide the rings back into place, isn't there still some benefit to airflow? I had always thought sharp edges were the enemy of good aerodynamics.
  12. #25062
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    You gotta love those paddle tires! Sounds pretty good.
  13. #25063
    San Francisco
    thanks, that's pretty much what I had in mind though making a dedicated housing rather than using the crankcase.
    cheers,
    Michael
  14. #25064
    Hanau, Germany
    Quote Originally Posted by d2t View Post
    But you want the flow in the desired direction, that would be (a least a little) influenced by the grinding....
    One other point came back into my mind: Wob I think you mentioned some when before that the aux ex ports shall be some °CA lower as the main ex port, otherwise one would loose some significant power in the lower power band. Is that valid also for aux ex ports which are connected to the PV (as the Yamaha drum type is)? If not I can get some more blow down there...
  15. #25065
    Transfer ducts with whats called "exit " flow benefit far more from the sharp edges at the bore as the gas that forms the scavenging regime
    maintains a much better coherent stream.
    With bore chamfers the column edges break up, and eddies or tiny turbulent swirls are formed that compromise the directional contol.
    Jan tested this at Aprilia, and i have done a direct back to back on a KZ10B, dynoing at 47.8 Hp with no chamfers, then immediately loosing
    near on 1 Hp everywhere after chamfering all the transfer ports - creating a ruined cylinder in about 10 minutes .
There are currently 76 users browsing this thread. (0 members and 76 guests)
