If memory serves that was on a AC, no WC![]()
Keen to see the data!
This might work well enough, first up set the area over say 5000rpm, and less than 50% TPS to be Speed Density. You'll want to set the TPS a fair bit higher than required to initiate the pipe wave, so when you whack the throttle on fast, the motor has a chance to fire (and pick the airflow up) before it crosses into the alpha-n table and goes to full fuel. If it doesn't fire in between, it will flood with all fuel and no airflow. Set the RPM bins like 4000, 4999, 5000, 6000 so you get a sharp cutover as you go over 5000rpm, and the system doesn't try to interpolate between the two zones (Megasquirt does this, not sure about the ecotrons). I'd probably do the same with the throttle position to be safe.
I'm not sure how the load prediction weighting works, if it's a form of blending between the alpha-N and speed density map, you might be able to have the fuelling incorporate TPS input when in the speed density mode, this will give some resolution to the fuelling between 0-50% TPS. Set it to maybe 0.5 to use half and half? Otherwise it will just be a set fuel value (with the exhaust around atmospheric pressure), until the airflow and fuel line up, motor fires and the pressure jumps up. If the load prediction does work like that, you might be able to use speed density/alpha-n half and half right up to full throttle, and should work similar to my system, alpha-n with 'speed density' correction.
On the speed density table you should make the pressure bins a sharp cutover at some threshold, so you get a 1.8x or so jump in fuelling when the motor fires. You could also have the higher pressure areas of the map give a little more fuel as the exhaust pressure wave develops with successive firings, like this:
100kPa - 55%
105kPa - 55%
105.1kPa - 100%
150kPa - 100%
200kPa - 110%
Also, you don't want any smoothing or averaging on the MAP input.
If you can use the exhaust pressure relative to barometric pressure for the speed density table it would be nicer, that way the exhaust firing threshold will adjust with altitude, luckily megasquirt gives this as an option called '%baro'. Or use a 1bar differential pressure sensor between exhaust and atmosphere as the speed density input.
You could have ecotrons give you a true multiplied table option, surely wouldn't be that hard to code.
Good luck!
TZ
Just wondering if you have tried using a vacuum signal from the 24 mm venturi. This signal would be very sensitive to whether the engine is on pipe or indeed firing. If the delivery ratio is doubled then the vacuum signal would increase by 4 times. Flow is proportional to the square root of the signal.
This signal could maybe be intensified by running a second choke - with the exit centred in the 24 mm venturi - like an old weber carb. You would then take your signal from the second choke.
You might find a couple of people in the World who believe you.
TZ350, KTMs will now come standard with efi on certain models of their 2 stroke enduro models for 2018
Normal to doubt
We do not know whether this power and.
No one has seen it
So what are you showing us? This could be any engine, with any driver doing any lap time. The only thing I picked up from the video is that the up shifts are terribly slow.
Why don't you stop trying to baffle everyone with bullshit and share some real technical data for a change, for that is what this thread is about.
luc seriously? which power you mean - the 70hp, the 65hp or any new values available meanwhile? you've had like 2 years to show a proper proof and all you got are fishy posts, a fishy homologation, a fishy web shop and calling people who scrutinize those (which should be in every technicians nature...) names.
I can post a vid of me lapping RS125s/650cc supermotos on a kart track with my 50cc bike. must also produce massive amounts of power![]()
There are currently 186 users browsing this thread. (0 members and 186 guests)
