Page 1694 of 2776 FirstFirst ... 69411941594164416841692169316941695169617041744179421942694 ... LastLast
Results 25,396 to 25,410 of 41630
  1. #25396
    I'd have thought there's a good chance of a crankcase explosion too with Nitro.
    Back when we could use it in roadrace engines here a local sidecar outfit used 11%...I asked why 11% ? The answer was because that's all this engine will take...I noticed the crankcase breather (sorry, it was a 4T) had it's end up by the steering head so asked why....The answer was that if the pilot saw a blue flame at the hose end, he was to switch off, take it out of gear and brake - then reach over, tap the passenger on the shoulder and they'd both roll off the bike...Then walk to the nearest marshals point for a broom to sweep up the bits from the crankcase explosion.
    They went through a few motors before arriving at this happy place - it was fast though....
    Hmm wonder what afr works for acetone? It has about the same energy content as ethanol.
    Thanks, I'll see if I can find his posts!
    Not only that but from what i have read if it comes into contact with unpickled Al it can also explode
    Soak the homemade crankcases in diluted vinegar Adegnes.
    it covers it in the bell book along with recomendations for jetting on nitro and methanol
  2. #25397
    I'm looking through the book now!
    Nitro just made my hobby alot more exciting!
    Two strokes & rum!
  3. #25398
    plenty on jetting and comps for meth and nitro etc
    pg120 for the nitro looks like its only the tanks that need pickling
  4. #25399
    On moderate nitro levels, gasoline CR is the way to go, great news, I'm at 14.5:1 now and can just leave it as is.
    Two strokes & rum!
  5. #25400
    Don't worry when if you overdo it the piston crown will vaporise lowering the comp ratio a few points.
  6. #25401
    Exactly, self regulating!
    Two strokes & rum!
  7. #25402
    9th August 2013 - 20:06
    kreidler rs 1976
    Netherlands
    Ryger
    OK, so I have deleted all the " nasty " posts except for the " good " bit where I suggested that Luc
    maybe wasnt an incompetent idiot.
    This now means I have a life, and I ( we ) would also be really,really friendly if the " hard proof " was posted here - a World Exclusive,
    as the media would say.
    Your turn Luc.
    Thats what she said - I honestly hope he doesn't. contrary to your behavior the world doesn't owe you a dime luc...
    And only to be continued, when people like koenich keeps his big mouth too !
  8. #25403
    23rd March 2015 - 21:24
    Conti RX356 V3
    i'm eager to listen for sth real.
  9. #25404
    *lol*
    So you are entering this forum with great secrets as a bait.
    But will only tell if you are licked where the sun don΄t shine?
    Made me laugh.
    Keep on!
    Remember: Third party dyno!
  10. #25405
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    At model boat heat races nearly everyone runs around 60% nitro. The smaller engines (3.5 cc) often run more while the larger engines (15 cc) may run 40 to 50%. Record runs often are made with 80% nitro. These engines all have aluminum crankcases, pistons, rods, and often chromed aluminum liners. The only problem with high nitro fuels is ball bearing corrosion with water. After run oils are essential to prevent bearing failure. Nitromethane/methanol fuels are much less explosive than gasoline. I've put out fires in gasoline fueled boats but never in a nitro fueled one.
    Lohring Miller, NAMBA Safety Director
  11. #25406
    Try this search:- hydroplane site:www.kiwibiker.co.nz/forums/showthread.php/86554-ESE-s-works-engine-tuner/
    Then click on his name and select forum posts. His early posts talk about hydroplane racing.
  12. #25407
    Thanks! I was able to find stuff with the forum searh before, but lately it's become totally useless...
    I remember his posts from reading through this thread when I first found it some years back(well I've actually read through it twice), maybe it's time to go at it again. It's like a good book!
    Two strokes & rum!
  13. #25408
    Had the carb apart again to drill out anything I couldn't fit my thumb through.
    I drenched everything in brunox(wd40 equivalent) after running it, but forgot to do the float chamber.
    No residue or anything, but that smell! I can best describe it as week old dead rodent.
    Two strokes & rum!
  14. #25409
    Ahh your turn of phrase is brilliant
  15. #25410
    Start the engine on normal fuel and run it till it is completely warmed up. Then switch to the nitromethane mixture.
    Beware: You can't kill your engine by stopping the ignition anymore, the nitromethane mixture is self-combustible under pressure. So make sure you can cut the fuel off at any time! or completely stop your air flow!
    plus ten carrots
    here is a selection of stuff i pilfered from Bells 4T book.
Name:	nitromethane bell 4t book.pdf
    I just watched your Video
    https://www.youtube.com/watch?v=ihmxMnAZmvM
There are currently 66 users browsing this thread. (0 members and 66 guests)
