Page 1714 of 2773 FirstFirst ... 71412141614166417041712171317141715171617241764181422142714 ... LastLast
Results 25,696 to 25,710 of 41593
  1. #25696
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Pistons:
    We had cast and forged pistons.
    Cast pistons gave slightly more HP, but sometimes cracked.
    0,8mm piston rings gave more HP than 1mm rings.
    As the auxiliaries and transfers overlapped each other a certain power los was caused by this.
    So closing the pin hole in the piston was tried.
    There were many solutions that were tested, but they all caused some trouble.
    In the end the best, and most reliable, solution was welding then closed.
    This was very well done by PANKL in Austria, and never caused any trouble!
    thanks for your imfo
    i'm over buckets
  2. #25697
    10th December 2016 - 13:02
    Yamaha
    Eskdale
    Do you mind me asking why do you think cast pistons made more hp than forged?
  3. #25698
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Because forged pistons had a tendency to 'bend' their dome inwards.
  4. #25699
    Yamaha
    Eskdale
    Wow thanks for that.
  5. #25700
    2008 Yamaha fino
    Bangkok
    When modifying a cylinder measuring duct sizes is not easy, especially in the curves!
    You can see our solution to this problem on the photo....
    Round 'sensors' fitted to a piece of welding rod!
    We had them from 7-7,25- 7,5 and so on until 28mm.
    Behind the cylinder, in the wooden block.
  6. #25701
    Vannik or anyone that knows stuff, I don't have your software so don't know this, if combustion does not happen, what happens to the air velocity in the combustion chamber at / after TDC? Does the rapid turbulence in the combustion chamber stop and reverse at some stage, as the squish starts to open up again? Or does it keep going but just slow down a bit?
    Jan, thank you, this is gold.
  7. #25702
    28th November 2013 - 21:58
    Dawes Jaguar
    UK
    I think you are referring to the JBB 250 cc.
    http://www.50c.nl/Archief%20Ton%20Ko...JBB/index.html
    No, I'm not. I'm familiar with the JBB 250. When it was discussed, earlier, it was me that pointed out it uses the same sealing system as many outboards.
    Frits posted a picture of a labyrinth seal made up of various diameter washers.
  8. #25703
    He did indeed
    You can easily build you own labyrinth with a stack of shims. Jan Thiel used this system in the Garelli 250cc V-twin. The whole shim package was only 5 mm thick.
    Attachment 322755Attachment 322756
  9. #25704
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    I do not understand .If the dome bends inward compression ratio go down and that is less power?
  10. #25705
    2008 Yamaha fino
    Bangkok
    Detonation.
    This started te be a problem when 50cc engines started giving more than 17HP, around 1975.
    At the time I thought this was a limit on engine power.
    Nikasil plated cylinders were very prone to detonation.
    Because of the rounded off edge at the top.
    At Minarelli/Garelli I solved this problem by sticking the cylinder head insert 3mm into the cylinder.
    A good solution, used for many years.
    But at Aprilia we found an even better solution: plate the first 5 mm around the bore at
    the top of the cylinder.
    Later this was machined to a very sharp corner, and this eliminated completely the unnecessary
    'dead room' at the top of the cylinder, it also gave 0,3HP more.....
    A little bit of still remaining detonation was eliminated by modifying the inner wall of the
    transfer ducts, cooling the piston.
    But part-throttle detonation remained a problem.....
    Which we never had on the dyno!
    On the photo you see a piston after a 54HP run...
    As long as you keep the throttle wide open a 2 stroke doesn't brake down!
  11. #25706
    2008 Yamaha fino
    Bangkok
    Yes...I think so.
  12. #25707
    2008 Yamaha fino
    Bangkok
    He did indeed
    The shim package of the 250 Garelli was about 1mm.
  13. #25708
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    The turbulence is caused by the breakdown of the main flow. Because of the viscosity (in effect the internal friction of the fluid) the main flow progressively break down into ever smaller eddies and if left long enough all the main flow and all the eddies will stop. The main flow is from the transfer port loop and a stronger better directed flow with more kinetic energy can generate a lot of turbulence before it stops. If you have weak flow by the time combustion happens you need the extra flow from the squish to generate extra turbulence to get good combustion. On the other side if you have strong flow and thus good turbulence the extra turbulence can speed up the combustion too much and you loose power but mostly overrev. This explains why engines do not always behave the same to squish changes. Good engines use squish to minimize end gas to stop detonation while poor engines use squish to add turbulence.
    So to answer the question: Turbulence cannot reverse, it is a one way street after creation. The bulk flow with the squish opening will loop slower and slower, both because of the increase in volume and because it keeps generating turbulence until it completely stops.
  14. #25709
    Thanks for the insight, Jan!
    do you remember the difference between both of the A-port variations from the picture? Which was better, version A or version B?
Name:	y type kanaal is A of B vraagteken10.jpg
    And did you ever have the pin come loose on the pistons? I guess not, buit it does look brave to me.
Name:	A-piston 4 (1).jpg
  15. #25710
    Dawes Jaguar
    UK
    Very impressive! Thank you (both of you). You can tell we're all interested, Husaberg hasn't posted any boob pictures for ages...)
