Page 1715 of 2773 FirstFirst ... 71512151615166517051713171417151716171717251765181522152715 ... LastLast
Results 25,711 to 25,725 of 41592
  1. #25711
    28th November 2013 - 21:58
    Dawes Jaguar
    UK
    Some pictures of the 250 engine.
Name:	Page 1 - 1.jpg
ID:	330116Click image for larger version.
Name:	Page 2 - 1.jpg
ID:	330117Click image for larger version.
Name:	Page 3 - 1.jpg
ID:	330118Click image for larger version.
Name:	Page 4 - 1.jpg
ID:	330119Click image for larger version.
Name:	Page 5 - 1.jpg
    Think Rotax built a V twin as a one off for Cotton before the tandems came along.
    Presumably the engines had more and more Aprilia built parts as time went on.
    I saw an article in an Italian magazine about the development of the 250 and (I think!) it said that power slowly increased over the years but the biggest jump was the introduction of crankcase cooling.
    Was that similar to the 125?
  2. #25712
    Dawes Jaguar
    UK
    Found this
ID:	330121   Click image for larger version.
  3. #25713
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    The shim package of the 250 Garelli was about 1mm.
    Jan, did you ever thought about using bearings with steel cover discs instead of a labyrinth seal?
    (6204-z-c3 would be an example)
    so you may use two bearings right next to each other without the need of any extra parts.
    the question is where to place the covered side.
    1. covers at the crank webs with an oil feeding hole between them
    pro: crankcase volume does not differ
    con: might get full of oil
    2. covers facing each other, feeding hole in the middle
    con: probably not enough oil supply
    3. using only one closed bearing with feeding hole in the middle
    pro: more vented bearings than 1.
    con: crankcase volume of one gets higher than the other
  4. #25714
    20th September 2015 - 03:19
    1981 Vespa p200
    San Diego, CA
    Can one find reasonably powerfull(up to date) 50 ccm cylinders,pistons and exhausts without silly money and where?
    Malossi, Polini and Roost make very good cylinders for the 50cc piaggio engines.
  5. #25715
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Thanks for the insight, Jan!
    do you remember the difference between both of the A-port variations from the picture? Which was better, version A or version B?
    Attachment 330106
    And did you ever have the pin come loose on the pistons? I guess not, buit it does look brave to me.
    Attachment 330105
    Version A was the best.
    The pin never came loose.
  6. #25716
    Jan,
    In all your time at Aprilia and others, when you wanted to try a different port or passage shape, did you actually reshape the sand cores yourself (eg by rubbing, filing or even building up with more sand) or was the new design formally designed/drawn up and new coreboxes made?
    Otherwise this is a great unfolding of the history, even though you’re not writing a book, I’m sure the likes of Husa will compile something.
  7. #25717
    2008 Yamaha fino
    Bangkok
    I often modified sand cores by filing
    We also used to 'cast' ducts in some resin, and modified these.
    After that we made new core boxes, using the modified resin cores.
    Our core boxes were really very nice, I shame I never made some pictures of them!
    We mostly did those things by ourselves, without involving the technical office.
    When we had arrived at the best transfer ducts the whole sand core was put on design.
    So a one-piece cylinder core could be printed.
    Also a study was made to improve cooling, especially the hot spots, as were the bridges in the exhaust duct.
    A cooling channel through the inside wall of the transfer ducts brought an additional 0,5HP
    The result of this was the APF cylinder.
Name:	RSA cylinder top view.jpg
ID:	330130   Click image for larger version.
Name:	RSA zandkern laatste versie.jpg
ID:	330129   Click image for larger version.
Name:	APF 2010 ports+cooling 2.jpg
ID:	330128   Click image for larger version.
ID:	330131   Click image for larger version.
Name:	RSA cylinder bottom view.JPG
ID:	330132   Click image for larger version.
  8. #25718
    2008 Yamaha fino
    Bangkok
    I don't know when water cooled crankcases were introduced at Aprilia.
    When I started working there in 1995 all engines already had water cooled crankcases.
    I made my first 50cc with water cooled crankcase in 1972.
  9. #25719
    2008 Yamaha fino
    Bangkok
    The cooling channels at the inside wall of the transfers.
  10. #25720
    I do not understand .If the dome bends inward compression ratio go down and that is less power?
    Yes...I think so.
    And maybe because the depressed dome pushed the crown outwards a smidgen causing more friction?
  11. #25721
    Jan, which area of the cylinder would you say water cooling has the greatest effect on improving power? does the cooling have to bring the temps down really low to have the best effect? would having that area benefit from having its own dedicated cooling circuit and radiator rather than being part of the a general cooling circuit?
    regards, nigel.
  12. #25722
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Hello Jan
    It strange that You could see 0.5 horsepower differences on dyno and be able to decide if it was a good or bad change.
    How much running in was nessecary to get reliable data?How often did You compensate for air pressure,humidity and temperature?
  13. #25723
    Whoa, this Bs look bigger than any other picture I've seen of them before. A lot bigger.
  14. #25724
    2008 Yamaha fino
    Bangkok
    regards, nigel.
    The lower the water temperature was the more power there was!
    40° was the lowest we tried, each 5° more giving a power loss of about 0,4-0,5HP.
    On the dyno we normally used 50°
    The exhaust duct had to be cooled really well, especially the bridges in it.
    In the beginning we had some trouble with holed pistons, caused by auto-ignition.
    But bringing the water closer to the spark plug cured this completely!
    We also found out that the quicker the water circulated the better.
    An electric water pump was insufficient!!
  15. #25725
    2008 Yamaha fino
    Bangkok
    Hello Jan
    Our computerized testing program was fully automatic and very precise.
    There was, of course, automatic compensation for temperature, humidity and air pressure.
    You could choose the cooling water temperature you wanted, and it was kept constant.
    Also the dyno room was air conditioned, with constant temperature and humidity.
    You could be sure that if you saw a 0,1HP gain that it was 100% true!!
    And I repeated every modification at least 3 times....
    A test went as follows: The engine was started and put at 10.000 rpm to warm up, full throttle.
    When the desired temperature was reached you had to push a button.
    Then the test was executed fully automatically, say from 9000 until 14500rpm
    When maximum revs was reached you had to stop the engine.
    Tests were 99,9 % repeatable
There are currently 59 users browsing this thread. (0 members and 59 guests)
