Page 1717 of 2774 FirstFirst ... 71712171617166717071715171617171718171917271767181722172717 ... LastLast
Results 25,741 to 25,755 of 41608
  1. #25741
    This was the 250.
    Quite different looking in cylinder detail from the Biagi 250
    whoops wrong pic thats the 500.
    So the pic on the right is the Biagi cylinders made elsewhere?
    These is the cylinders i normally associate with an early Aprilia
    I have an DEA almost copy of it
  2. #25742
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    Attachment 330177Attachment 330178
    My pictures show the ultimate two stroke configuration.
    Ligth,even pull ,simple and nobody can claim that it will not work yet.
    Does it have a common crankcase for both cylinders?
  3. #25743
    Seen this today neat
    https://grabcad.com/library/aprilia-...nder-incompl-1
    seeing one in 3d is pretty neat
    Needs a little work on the AUX exhaust
  4. #25744
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Yes,thats the big plan and only one common inlet for crankcase.
    If the underside of the lagging piston controls this inlet we get the phase skewing as a disc valve without the complication.
    I have some parts but lack motivation for the time being
    http://i.imgur.com/n36caso.jpg
    Hi Martin You are from Trabant country.
    Find an used engine and let us make the Trabant engine like this
    Should hae been done really many years ago.
  5. #25745
    Thuringia Germany
    yes, indeed. i was born in the GDR. but i am not proud of the trabant and it is engine. it is crap in my opinion. but the reason for that are for sure not stupid engineers but stupid assholish politicans... 26bhp? i don`t agree!
  6. #25746
    Jan you settled on a dome piston. Which other types were tried and what were the results?
  7. #25747
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    We tried various flat, and radiused pistons, but the original ROTAX dome always gave the best results.
    With flat pistons the flow detaches which gives less piston cooling.
  8. #25748
    10th December 2016 - 13:02
    Yamaha
    Eskdale
    KZ2 EGT question
    Hi Guys new here
    Trying to learn a bit about EGT .I would have thought the temp would have kept climbing to max rpm .Is the lag just the time it takes for the sensor to heat up ? or is there another reason
    Any help would be appreciated
  9. #25749
    That looks like the unloved APD cylinder.
    My take on the twin crank is the single crank engines the head angle has to be steeper to over come the gyro effect of the crank. Early Kobas frames used at 27* head angle which is mx territory. The Kobas could run that rake but still change directions a fast as the TZ/RS's. Contra rotating cranks seem to have less tyre chatter as well. Less vibrations make them far easier to ride faster.
  10. #25750
    You may need new glasses its also in Austrian
    It was all there was on the Net sorry.
    http://www.artmotorsport.com.au/new/...nual%20Pt1.pdf
    There are plenty of pics here of the crankcases
    including a scaled down wood pattern someone made for 50cc cylinders.
    https://www.kiwibiker.co.nz/forums/a...p?albumid=4839
    https://www.kiwibiker.co.nz/forums/a...5&d=1413591174
    https://www.kiwibiker.co.nz/forums/a...6&d=1413591175
    https://www.kiwibiker.co.nz/forums/a...9&d=1413021975
    They are 3D printed cases from a 18yr old fellow in Italy (shits me someone so young can have all that talent ) for 125cc he is getting help fram Garbriel Gnani (his cylinders)
    http://www.2t-special.it/forum/viewt...hp?f=14&t=5065
  11. #25751
    Did you try the hybrid Yamaha style? Flat top with chamfered edge?
  12. #25752
    2008 Yamaha fino
    Bangkok
    Yes, of course....not better!
  13. #25753
    2008 Yamaha fino
    Bangkok
    Biaggi's cylinders were named APB, originally designed by AVL in Austria
    As designed they were useless, but they were developed very well by my colleagues at Aprilia.
    Only Biaggi used them, their development was stopped in the beginning of 1998, when the APC became better.
    The APD was a 7-port cylinder which proved useless.
    It had been developed using a Jante-type flow bench, made in Brno, Czechia.
  14. #25754
    2008 Yamaha fino
    Bangkok
    These are APC cylinders, copied by many kart engine manufacturers.....
  15. #25755
    2008 Yamaha fino
    Bangkok
    No, would not have made any sense.....
    See the picture.
    On the right the 250 with APB cylinders.
    A longer stroke was tried without success.
    And during one test the piston pin came out of the carburetor....
ID:	330191   Click image for larger version.
