Page 1734 of 2773 FirstFirst ... 73412341634168417241732173317341735173617441784183422342734 ... LastLast
Results 25,996 to 26,010 of 41589
  1. #25996
    Great project, I love it. ...
  2. #25997
    Was kinda wondering if you'd find a dyno to fit that.
  3. #25998
Name:	NSR Cylinder Adaptor Plate.jpg
    Posted because someone asked to get a better look at my Honda NSR cylinder to GP100 crankcase adaptor plate.
Name:	NSR GP Cases.jpg
ID:	330989 Click image for larger version.
Name:	NSR Cyl Plate.jpg
    All the original crankcase stud holes are plugged with alloy rod glued and screwed into place. Three of the new studs for the NSR cylinder are fitted into the GP100 crankcase, the fourth is in the adaptor plate.
    I have no idea how big the crankcase volume is, but it is huge, must measure it some day. Long rod, RD400 115mm original is 100mm CC, crank wheels slimmed down and with the gear box spacer plate the flywheels are 12mm further apart than standard.
Name:	NSR big Ex port.jpg
ID:	330986 Click image for larger version.
Name:	Std Ex Port.jpg
    Comparison of blowdown area of ported NSR cylinder on the left and standard one on the right.
  4. #25999
    29th December 2011 - 04:14
    rd 350 ypvs 1985
    netherlands
    Hi all,
    am I right in thinking that an even tubmax would make for easy jetting or is that bs?
  5. #26000
    Cracked head stud boss in pic 4.
  6. #26001
    Good spotting, thanks. .....
  7. #26002
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Does it sell?
  8. #26003
    The case com ratio is a very important element, guessing or not measuring it correctly isnt an option.
    PS - you have a worn out piston available, drill a hole in it.
    that's what I did driiled a hole in a old piston. seems like a also packed modeling clay on the inside of the reed block and then bolted it to the cylinder. might of even packed alittle clay in the exh ports at the bore face so oil cant excape out exh between piston and bore. watch for any air pockets as it will throw off your results
  9. #26004
    My buttugly racer has met some development in the looks
    A couple of heatcyckles more and i´ll se what it produces on the dyno.
    Everythings new in the engine.
    Bearings,crank,cylinder,piston.
    I have ported the cylinder som more also.
    Switch to methanol has been done.
    It has been started since the pic was taken
    nice job there. will you be using standard Kawasaki ign box ? if so can you report back if the best results require the timing plate under the flywheel to be advanced or not ?
  10. #26005
    Quote Originally Posted by casal-fan View Post
    Hi Juergen.
    Jeah... I also like it a lot, turned out great. Martin sculptured it for me after we agreed on the design, ccs, etc.
    Have you noticed it protrudes into th cyl. just like Jan spoke about a few pages ago?
    And about the short circuiting caused by strangely designed piston that also came up a few pages ago.
    Also encountered this problem with the Gasgas piston.
    Decision was made not to open aux. exhaust pass the holed piston sides.
    Engmod showed enough TA with 193* exh. duration. 72X72 are relatively big numbers, around 9500 rpm at max power with good overrev was the goal.
    im thinking the wiseco ktm300 would be your best bet as far as I know but double check to be sure it will fit your engine. if you notice the front bottom corner in the red circle. the gasgas version might possibly allow a connection from crankcase to exh at tdc so watch for that. this is why I think the ktm version would be more suited. 858M07200 I think is the part #
ID:	330997   Click image for larger version.
  11. #26006
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    How is the Lithuanian 'Rygerised' Honda doing?
  12. #26007
    Clicked over 4 million hits on the Team ESE thread today, this thread is like some super dinner party with really great friends.
Name:	Lots of Friends.jpg
    And just like the Queen's great Birthday bash, a big thank you and thumbs up to all the great people who contribute to and read this thread, they all make it a fun and an interesting way to learn something new about 2T's.
  13. #26008
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    I was thinking about that too.
    Paging katinas paging katinas
  14. #26009
    Honda NS 250 -28mm.
    Honda NS 400- 26mm.
    But these carbs works best with original airbox with foam filter. Anyway so much modification is needed and not just like change main jet, but with emulsion tube, needle, power jet, etc., because no acceleration.
  15. #26010
    Let's switch to four-strokes, they said.
    Oil on the track? Nah, won't happen....
    https://www.facebook.com/frits.overm...type=2&theater
There are currently 73 users browsing this thread. (1 members and 72 guests)
  1. Wos
