Page 1739 of 2776 FirstFirst ... 73912391639168917291737173817391740174117491789183922392739 ... LastLast
Results 26,071 to 26,085 of 41626
  1. #26071
    Both Honda and Yamaha were keen to keep Cagiva in the game for the sake of diversity. Cagiva had Wayne Rainey's championship-winning Yamaha YZR500 V-four on loan for a full month. I've still got the drawings of the Cagiva-cylinders somewhere; they were completely identical with the Yamaha-jugs. And Honda supplied Cagiva with not-for-sale Keihin carbs from their NSR500.
    I cetainly wouldn't mind seeing those drawings.
    Alas, once again me and my archives are not in the same country. But you don't miss much, Husa. Yamaha's biggest step in the latter days of their two-stroke activities was to copy Honda cylinders .
    For the 500/4 Honda had an instruction book for mechanics. It was made in such a way that it could not be foto copied...
    ....But somehow a copy of that instruction book found its way to my archive anyway. And that is a very instructive document. But as I'm not supposed to have it,
    I hesitate to put it on an open forum. And no, I won't respond to PM-requests in this case. It's a big pile of paper anyway and I don't have a scanner.
    do we have a graph showing exhaust valve position to run along side this attachment... or did it not change at all until a certain level of rpm was achieved?( im sure this has been spoken about before but im struggling to find...). also how much exhaust duration was there prior to it being activated?
    We don't, Breezy; not a graph. I should be able to draw one because I must have a table of rpm/valve positions somewhere, but not within reach.
    The closed-valve exhaust timing was 172°.
  2. #26072
    Got a new computer and thanks to Neels help I managed to easily install the latest version of EngMod2T on it. Great help from Neels.
    Used EngMod2T to develop a PoweValve curve for my new NSR/GP110 cylinder.
    I thought that a PV curve would be a straight line steadily increasing as the revs go up, but it looks like that is not necessarily so.
    I have a list of the break points for the PV curve developed from the EngMod simulations. And now I need to find the corresponding mV feedback breakpoints for the servo motor that drives the PV.
Name:	Degree Wheel.jpg
    Using a degree wheel and the list of breakpoints for the PV.
Name:	PV Setup.jpg
    I developed the PV mV control curve by adjusting the servo feedback required to match the PV blade to the degrees ATDC to Exhaust/Power Valve opening position at each point on the curve.
Name:	Final Curve.jpg
    Half an hour later and I have a new PV curve setup in the Ignitec ignition module.
    Basically there are three steps, 8-10k, 10-11k, and 11-12.5k. the hump at the end is just to move the PV completely out of the way in the extreme over rev region.
    The next stop, the dyno.
  3. #26073
    Nice injector position TeeZee .
Name:	TZ350 cylinder.jpg
    Oops. I stored the above picture as 'TZ350 cylinder'. But now I must forever remember that it is not a Yamaha TZ350-cylinder .
  4. #26074
    You really need to set up a portable expansion drive or start backing up to Cloud.
    Funny enough the Suzuki that KR JR rode to victory had exhausts that were copies of a Yamaha YZR they never gave any more power on the dyno but they lapped a second or two faster with them on.
    Willings spilled that one. pretty sure the rest was out of the Yamaha play book as well. So that might have been also a Honda by default.
    I noticed that the later 90's RGV500 had a spool PV as well as a blade anyone got pics of that?
    PS you tease you know i am a NSR anorak , i also have a have a scanner and contary to popular opinion i are actually very discrete, you really should see the stuff i don't post on the web.
    MY japanese contact was meant to take some decent photos of the line drawing for the YZR's but i think he has forgotten.
    I do have a scale line drawing for the chassis of the later ones.
  5. #26075
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
  6. #26076
    Wasn't it two or three blades for the exhaust powervalve and a spool valve for the exhaust resonance chamber?
    Can you teach me how to put tons of paper in this cloud? It's not like I have a spare year available for scanning the lot before uploading it, even if I had a scanner.
    Anyway:
  7. #26077
    This was never done I think....
    And I don't remember the answer to your second question, might have been around 170°.
    ok thanks for reply.
  8. #26078
    ok, thanks for reply.
  9. #26079
    Anyway:
    You might be right re the RGV
    As for your paper documents, I would be glad to teach you how
    All you need to do is mail them to husaberg scanning and uploading services Wild Wild West NZ
  10. #26080
    30th November 2014 - 11:08
    69 kawasaki avenger
    brisbane
    Reverse cylinder
    Hi I have a reverse cylinder tz250 in pieces. It has spare y1 and y2 cylinders. Can these cylinders be bored out to fit Tz 350 Pistons to put onto a kart for hill climbing. Are the Tz cylinders Able to be fitted to a spare Rgv bottom end. Would these cylinders be much better than bored out rgv barrels.
  11. #26081
    Husaberg, your the search engine of choice, can you find the KTM patent on this new TPI system? Keep digging until you get traction.
    Mostly interested in the date it was filed.
  12. #26082
    Opposing it on "prior art" grounds ?
    Best case outcome would be a payoff from KTM - which wouldn't be bad surely ?
  13. #26083
    Far more important; bragging rights.
  14. #26084
    Yes, a lot of us have copied Flettners original idea he posted ages ago, even KTM have done it.........
  15. #26085
    ... a reliable water cooled F4 Bucket engine with really good performance.
    So simple, and no real tuning knowledge needed .....
    https://www.kiwibiker.co.nz/forums/showthread.php/86554-ESE-s-works-engine-tuner?p=1131032879#post1131032879
    In "Bucket terms" it is pretty simple to bolt a NSR cylinder onto a Suzuki GP100 bottom end.
There are currently 23 users browsing this thread. (2 members and 21 guests)
  1. gamma500,
  2. lohring
