Page 1740 of 2773 FirstFirst ... 74012401640169017301738173917401741174217501790184022402740 ... LastLast
Results 26,086 to 26,100 of 41594
  1. #26086
    Page 1740 ........
    Links to a whole bunch of EFI projects.
    EFI Kawasaki Bighorn on the dyno https://youtu.be/ifSEql1X4R0
    EFI Kawasaki Bighorn Trail ride 1 https://youtu.be/eleqBGvOM4M
    EFI Kawasaki Bighorn Trail Ride 2 https://youtu.be/CnIemdISKrM
    EFI Kawasaki Bighorn VMX https://youtu.be/v8i6ps0PdVI
    Maramarua classic forest trail ride https://youtu.be/ZqzOgOJuJ1E
    EFI YZ dyno run https://youtu.be/UEQli7nuak4
    EFI YZ250 look around and first start up https://youtu.be/hOGZ5llowoU
    EFI YZ250 trail ride 1 https://youtu.be/1YG9ko8-Nwk
    Nath88?
    EFI first start up https://youtu.be/wIRF3VJUqBk
    EFI ride around the block https://youtu.be/4Zsz26QmfAU
    CVT EFI NOS and everything else https://youtu.be/A9d-atuQO7Y
    EFI and Turbo Snow Cat https://youtu.be/U1uz7gdS-cA
    SeeDoo Etec https://youtu.be/LhNHcy9si5o
    1975 Suzuki GT250 road bike fuel injected start up https://youtu.be/A7fONUsJQD4
    1975 Suzuki GT250 road bike fuel injected road test https://youtu.be/BePHcg5dNjw
    Fuel injected 1971 Yamaha R5 https://youtu.be/qzVHgHJ9PWI
    Athena Direct Injection https://youtu.be/h-F_IndOm5I
    BRC 250 EFI kart engine https://youtu.be/dNat9ZwWbq8
    BRC 250 EFI kart engine https://youtu.be/Kfx61bUOznc
    Racing EFI Vespa https://youtu.be/_sjx2i4xFlY
    EFI Banshee first start https://youtu.be/e1WHVVT6d9c
    EFI Banshee run https://youtu.be/eznxX_ndpII
    Direct injection https://youtu.be/IpjWi-0qTJg
    Will direct injection DI save two strokes https://youtu.be/ql2-wW0LuWY
    Orbital direct injection https://youtu.be/fIoB0zTeUAY
    EFI Dragbike Thailand https://youtu.be/VB6Q_fQQ_PY
    Mega Squirt YZ125 https://youtu.be/Di8FuHApLKA
    Aprilia RSi 125 EFI Part 1 https://youtu.be/S1xvr_VXzx4
    Aprilia RSi 125 EFI Part 2 https://youtu.be/j5FOUn7V3nc
    Aprilia RSi 125 EFI Part 3 https://youtu.be/WBaiMJb6ntY
    Aprilia RSi 125 EFI Part 4 https://youtu.be/pZl5KPwvm0s
    EFI 125 kart engine https://youtu.be/4D8WRjDxan0
    EFI 125 kart engine https://youtu.be/b1YbPdw00Ww
    EFI 125 kart engine https://youtu.be/r5ljaDdaH_o
    EFI 125 kart engine https://youtu.be/uexMJbtyZdU
    EFI 125 kart engine https://youtu.be/uzbSsYh8Z9w
    EFI 125 kart engine https://youtu.be/XIcX9-GsMGQ
    Fuel injected Kart https://youtu.be/R5_KlcefQ8k
    2017 KTM dyno https://youtu.be/8g0uSIisMtI
    2017 KTM demo ride https://youtu.be/nf1tfdUtjJI
    EFI CR250 https://youtu.be/VlHyRcmlLgU http://www.supermototecnica.com/2015/09/10/sviluppi-del-sistema-iniezione-diretta-indiretta-due-tempi/
    EFI YZR500 https://youtu.be/tNAtmKzqo9A
    EFI CR500 https://youtu.be/BskSxMoQrwA
    2T Nitro Engine visible combustion https://youtu.be/aO5Qkzlo2Kw
    2T visible combustion https://youtu.be/G7PSec7RjRw
    More 2T Visible combustion https://youtu.be/BrWpF6YiSDs
    Fuel Burn in a side valve 4T https://youtu.be/jdW1t8r8qYc
    4T Visible fuel burn https://youtu.be/31mtOdHGbB4
  2. #26087
    Far more important; bragging rights.
    and some fat $stacks$ too.....
  3. #26088
    A little more progress.
    1st race in ~3 weeks.
    Are tuning the engine as we speak.
    And 211.2cc on methanol sounds angry at 13000rpm
    Will post a video later on when i got it fully tuned.
  4. #26089
    Opposing it on "prior art" grounds ?
    Best case outcome would be a payoff from KTM - which wouldn't be bad surely ?
    Nah, not interested in a payout (it would never happen anyway) I just think it would be a bit rich if KTM have patented my idea and legally leaned on me when I start production of my own injected engines.
    The idea behind showing it off on the internet was so the technology is available for anyone to use if they so wanted. Couldn't be patented , prior knowledge according to my patent attorney.
    He said they are probably bluffing.
    Yes Dave, I could live with bragging rights
  5. #26090
    That's exactly the problem I'm having now... I've been experimenting with measuring the crankcase pressure instead of exhaust, just after transfers open. Under 25% throttle once on the pipe (7000 up) the pressure is lower than at 0% throttle... then over 25% the pressure starts going up. Which makes sense, the scavenge effect of the pipe drawing against the mostly closed throttle. But as you said, no good for a normal 4 stroke style ECU, it expects a linear input. I should put up some graphs of the data collected. Perhaps if you sampled the pressure before and after the transfers open then take the difference. The ability to write the code specifically for the engine is where KTM has a massive advantage.
    At the moment I'm working on modifying the ECU code to capture the highest peak of the exhaust pulse as the port opens. I think this will be a good indicator of how much wave energy has gone into the pipe. So far the best results have been with the exhaust pressure at the powervalve vent. The PV housing was acting as a damper, smoothing the pressure pulse so the ECU could catch the peak easily, signal was a bit too smooth so I'm trying other methods, trying to nail an analog carb feel on throttle transitions. If the code mods don't work out (I'm no programmer), back up plan is to use a 'precision peak hold' circuit on the map sensor, then using the ignition output to reset the circuit at the start of each cycle. You could implement this on your ECU easily enough.
    I often use pipe pressure as a measuringtool when tuning twostrokes.
    I weld a bung on the middle of the 'Belly' on the pipe.
    Then connect the pipe through the bung to a simple turbopressure gauge.
    To even out the pulses a bit i use a simple fuelfilter in-line on the hose.
    I also use a restrictor before the filter, between pipe and filter just to get the pulses less intense.
    Maybe it works the same way, but instead of a pressuregauge, you can put a mapsensor, 0-5v.
    (And as we speak i use an adjustable 'restrictor' as the bung has two functions now.
    When not measuring pressure i use the bung to pressurise the fueltank, with this restrictor i can adjust fuelpressure.)
  6. #26091
    29th December 2011 - 04:14
    rd 350 ypvs 1985
    netherlands
    This guy claims it's not a KTM patent at all (?)
    https://www.youtube.com/watch?v=f1TVszsAXc8
  7. #26092
    Quote Originally Posted by 1948rod View Post
    Hi I have a reverse cylinder tz250 in pieces. It has spare y1 and y2 cylinders. Can these cylinders be bored out to fit Tz 350 Pistons to put onto a kart for hill climbing.
    No idea but unlikely, Hans Hummel made a 350 cylinder conversion kit for the V twin though.
    Are the Tz cylinders Able to be fitted to a spare Rgv bottom end.
    Anythings possible given enough time and money
    Would these cylinders be much better than bored out rgv barrels.
    No need to bore out RGV cylinders use either Arctic Cat ZRT600 2001 cylinders or RG200 they both bolt on to RGV's
    As do RG150 wolf.
    There was a guy who made up a close to 400cc 1kt TZR using DT200 cylinders and a stroked crank, But WR200 cylinders would have been better.
  8. #26093
    Husaberg, your the search engine of choice, can you find the KTM patent on this new TPI system? Keep digging until you get traction.
    Mostly interested in the date it was filed.
    I couldn't find it the other day they don't list patent numbers which suggests to me they either don't have international pattents yet or they are pending.
    Either that or they are not in their own name.
    I find it hard to believe Boyseen never pattented it, they pattented just about everything else.
  9. #26094
    Let me know if going after KTM works Flettner. That would give me motivation to go after Suzuki with their VVT on the GSXR 1000.
  10. #26095
    Apparently there will be no tuning software available from KTM for the new FI 2 stroke offroad models.
    That's going to complicate things.....
  11. #26096
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Even for offical KTM Dealers this has been standard (on foulstroke): You may choose between standard mappings for different countrys and Akrapovic mapping with / wo catalysator.
    Nothing more .
  12. #26097
    Nothing more .
    KTM used to offer a tuning kit for sale for the 4 strokes. Available to the public. They don't offer that anymore. Harley Davidson was fined by the EPA for selling/allowing customers to modify EPA regulated settings. KTM has decided they didn't want to be liable. So no software will be able from now on.
    Hopefully hackers will step in
  13. #26098
    11th November 2011 - 12:15
    93 kx500
    Aus
    Here's an old Rotax patent from 2004 with twin conventional injectors in transfer ports but aiming into cylinder area: CLICK HERE
    Latest one from rotax 2016 combining DFI with indirect FI (IFI?) and it's control system: CLICK HERE
    BEtaMotor has gone a different way in 2017 with IFI? almost throttle body injection: CLICK HERE:
    The biggest hurdle to playing with these KTM's will be getting someone to reverse engineer the KTM ecu's algorithm's and map locations and more importantly share it.
    If KTM allowed the world to tinker with it the improvements would come much quicker. Unfortunately this won't happen.
  14. #26099
    21st March 2014 - 22:00
    Hanau, Germany
    EngMod Temps
    To all who have more experience with EngMod than I have:
    are the shown temps reasonable for a setup with a cooling water temp of approx. 50°C in the head (like in the RSA125)?
Name:	RSA125 Temps.jpg
  15. #26100
    Here is the file that gives good dyno correlation for the RSW.
