Page 1743 of 2775 FirstFirst ... 74312431643169317331741174217431744174517531793184322432743 ... LastLast
Results 26,131 to 26,145 of 41611
  1. #26131
    Are 'big bore' cylinders really that good?
    At Aprilia some of the boys working with me fitted big bore cylinders to their Rotax engined bikes.
    The result was always the same: less power.....
    Because of the big bore made a mess of the transfer ducts!
    likely true Jan an engine should be designed and engineered for its size, to limit space compromises.
    The class where i was discussing their racing use is NZ F3. (Yeah i know its not the name now)
    Due to a rule change a few years ago it now allows 2t multis up to 400cc as long as they have road based crankcases.
    GP bikes are only allowed to be 125's
    As most of the later 2T bikes are 250cc such as RGV250 or NSR250 this is why they go the big bore route.
    the 4ts they compete against are 450 multis old VFR400's bored out etc plus 600/4 with one cylinder disabled. \or 650 twins SV650 etc
    The RZ350 is one option Wob has done. He was also doing a NS400 with cr based cylinders for someone
    I think you might have gone with the RG400 which is the small bore version of the RG500.
  2. #26132
    7th December 2013 - 00:25
    Yamaha's
    Hellas
    Jan, can you tell us about the cylinder casting(aluminum type,casting procces,heat treatment after etc)?
  3. #26133
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Hi Jan, if you refer to the Polini cylinder for the Rotax 122 and 123 - the lower Power is caused by reduced port timings compared to Rotax barrels.
    The timings are still quite low when you combine the Polini for the 123 with a 56mm crank. Without spacering the head insert...
  4. #26134
    I can't see youtr picture but nsr125 heads don't bolt on to NSR250 even though the cylinders can be fitted to each other
    That was a PDF. Did work for me?!
    Anyway, this is the picture of the head I want to build.
    Would be interested if NSR250 is a match and I do not need to do the CNC Milling.
    Regards
    Tim
  5. #26135
    8th July 2013 - 11:01
    2001, Aprilia, RS250
    Oz
    Thats just silly much easier to use RG150 (i know the UK had them as Grey imports) ones or better yet modded Artic Cat ones
    Have you tried finding RG150 or arctic cat cylinders? Absolute hens teeth compared to standard RGV250 (especially as most people use the ones they already have on the bike)
    Off the shelf kits using 250 cylinders have been sold by a couple of places, 150 or arctic cat is all DIY.
    As I said, it's all a big compromise anyway, as it makes an already oversquare engine more so, and as Jan commented, takes a big chunk out of the transfer ducts.
  6. #26136
    30th November 2014 - 11:08
    69 kawasaki avenger
    brisbane
    Tza250
    Have you tried finding RG150 or arctic cat cylinders? Absolute hens tehieth compared to standard RGV250 (especially as most people use the ones they already have on the bike)
    Hi I had hoped that I could use to 350 Pistons in the spare cylinders on my tza 250 engine hoping it would have better torque for hill climbing or second choice big bore on my rev. I wouldn't modify the Tz cases so it could be reused for historic bike races.
  7. #26137
    Does anyone know of a TZ250G cylinder that is unusable.
    I want to section one up the Ex port to look at whats needed for to add Aux for a LSR engine.
  8. #26138
    I have a question: Does an owner of a Honda NSR250 cylinder or head may print this out
    Attachment 331151
    and check if bolt patern and other dimensions are a match?
    TeZee probably?
    Thanks a lot!
    Tim
    No they are not a match. See attached NSR250R MC21 cylinder and head gasket photos.
ID:	331177   Click image for larger version.
ID:	331178   Click image for larger version.
ID:	331179   Click image for larger version.
  9. #26139
    Google vincent crabtree rgv250 big bore
    http://www.apriliaforum.com/forums/s...-Kit-E-Mids-UK
    http://www.apriliaforum.com/forums/s...ankshaft/page4
    https://sites.google.com/site/vpcrab...ki-rgv250-vj21
    https://www.kiwibiker.co.nz/forums/s...post1130586696
    https://www.kiwibiker.co.nz/forums/s...post1131030948
    You were going to try modding a RG250 crank to go in a RGV weren't you?
    Yes just the cylinder to do. Though I have seen in Italy a fellow fitted RS honda cylinders. RM 125 would be a good start
  10. #26140
Name:	MC21 Cylinder Head.jpg
    MC21 stud pitch circle is 88mm, outside diameter 104mm with studs evenly spaced.
    The MC18 is different to the 21 and the NSR125 has an uneven spacing of the studs compared to the 18.
  11. #26141
    Have made a 288cc Rotax that was 6 hp/4 ft/lbs torque more than the 250cc that diminished down to the same peak power at the same rpm. A full 350 is under construction. Big bores tend to make way more mid range.
  12. #26142
    Contact Craig Stafford on FB his dad Don was a Yamaha dealer for many years and was recently selling a big box of that era TZ stuff
  13. #26143
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    Is it difficult to justify this?:
    https://www.dotmed.com/listing/ultra...be-3dx/2281218
  14. #26144
    Ebay is full of zrt600 arctic cat cylinders.
    for the RG150 cylinders try the asian countries where they were sold. Like Thailand
    NZ had quite a few, More than the 125's but the 150 streetstock racing class has swallowed them.
  15. #26145
    Oz
    A moot point, as I'm not interested in big bore kits. Just wanted to correct your assertion that RGV300 are usually done with 150 cylinders, when overwhelmingly, they are not.
